Engine Motor Mount Test - SaabCentral Forums
Old 03-06-12
Fox Fader's Avatar
Fox Fader Fox Fader is offline
My Saabs: '98 900SE Manual
Question Engine Motor Mount Test
I do know that the transmission mount is bad, it was an easy check with the floor jack... The shifter moves around quite a bit upon acceleration, but there's no problem getting into any gear.
What's the best way to check the other two mounts for their condition? (98 900SE Manual)
Old 03-06-12
AZR Racing AZR Racing is offline
My Saabs: 1997 saab 900se
Garage
when the passenger side goes bad, you can look through the passenger side wheel well (after all the plastic has been removed) see if the allen head has dropped out of view. also alot of times the oil pan will sit on the subframe. drivers side you can look and see when its bad. the rubbed dry rots, and then the mounting point sits in the bottom of the housing.
900 SEC 2.xT, custom 3inch exhaust, GT35r BB turbo, custom log manifold, tial Q bov, autometer phantom boost,oil,WB, JZW full custom tune, siemen 60# injectors, aeromotive 340 intank, want fried rice?
Old 03-06-12
jonathans jonathans is offline
My Saabs: '97 900s 5dr, '97 900s conv
the fluid that leaks out of the passenger side mount also smells absolutely disgusting, and will leave a trail running down the bracket and the plastic guards. you really can't mistake it for oil.
if the passenger one fails the visual test:
http://photo.platonoff.com/Auto/2005...Old_vs_new.jpg
...may as well replace the rear one at the same time.
Old 03-06-12
Fox Fader's Avatar
Yeah, I figured with the car being 14-15 years old that I may as well do the all. No need to be cheap the car isn't gonna cost me much.
Old 03-06-12
BobSaabit BobSaabit is online now
My Saabs: '97 NG900 'vert; '03 OG 9-3 'vert
What's the floor jack check?
Old 03-06-12
Fox Fader's Avatar
I jacked up the tranny and I could see the inside of the mount easily and freely move around.
Old 03-07-12
Fox Fader's Avatar
Yeah mine were pretty shot. I did the 3rd one too, but I'm thinking I should have gotten the GS tranny mount as the engine and tranny seemed to move around still more than I like. Is this normal??
Old 03-07-12
EdT EdT is online now
My Saabs: 1997 Saab 900 2.3 Coupé
My rear mount was same as yours, split all around. I put in a stock mount and called it a day.
I'd rather have a rubber bushing that's designed to give, give, than fatiguing or breaking other parts.
Similar Threads
Lower motor engine mount[s] question Turboy Saab 9000 Workshop 2 23-04-09 05:26 AM
Check Engine Light after Motor Mount & Belt Replacement eggsngrits Saab 9-5 Workshop 4 18-12-07 10:43 PM
Missing motor mount... engine banging... looking for quick fix Momentum57 Saab 9-3 & NG900 Workshop 10 06-01-07 06:37 AM
Revisiting the left motor (engine) mount MSOEMiller Classic Saab 900 Workshop 9 26-11-04 08:43 PM
Bolts to mount 16V 900 Motor to Engine Stand - What Size? BurnsSide42 Classic Saab 900 Workshop 0 05-08-04 10:07 PM
