1999 Saab 9-3 stuck in park, shifter moves - SaabCentral Forums
Old 25th May 2012
budsstuff budsstuff is offline
New Member
My Saabs: Saab 9 3
Exclamation 1999 Saab 9-3 stuck in park, shifter moves
Hey guys !!
Thanks for any info
My wives Saab its a '99 convertible. She loves it !
Yesterday she stopped, turned off motor after putting it in park (automatic tranny) after waiting for a few mins she started up the car and pull the shifter into drive and NOTHING.
It will not come out of park. The shifter moves just fine but does not go into gear.
After some reasearch... Under the hood I located the shifter cable. You can see the metal part of the cable moving as you work the shifter.
Is there a linkage broke in there ??
Can you get to it ??
Any pics would be great !!!!
Thanks again
Old 25th May 2012
win_k win_k is offline
My Saabs: 99 S Coupe, 01 SE Vert
Yep, and the only mechanical linkage in the trans is for Park, everything else is hydraulic based on the solenoids and valve body.
Only way in is to drain the transmission, support the engine and transmission and remove both the front left mount and it's bracket.
Once that bracket is off, you can pull the front cover off the transmission to get to the solenoid valves and the park lever. You'll also need to remove the transmission oil cooler return line there on the front cover.
Just to confirm, the transmission remains locked in Park and won't roll?
Old 25th May 2012
New Member
My Saabs: Saab 9 3
Wow that was NOT what I wanted to hear !!
DANG !
Yes it is in park
Tags
9-3, saab, shifter, transmission
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
The plastic bit that moves with the auto shifter musky NG900 & OG9-3 Workshop 10 9th April 2012 08:56 AM
shifter is still in park sp53 9000 Workshop 1 9th August 2011 02:09 AM
Gearlever stuck in park Offcamber1 NG900 & OG9-3 Workshop 1 10th July 2011 07:31 PM
Manual shifter moves around brupoo NG900 & OG9-3 Workshop 4 22nd April 2011 03:23 AM
Transmision stuck in Park!! JLtarra 9-5 Workshop 2 17th October 2004 07:18 PM
