tach gauge - SaabCentral Forums
Old 25-05-12
tiggerz tiggerz is offline
My Saabs: !997 900 SE Talledega
Default tach gauge
Wondering where the electrical connection is on the tach. Its not working and I have checked all fuses and connections besides going into the tach itself. Instead of taking the dash apart, I took the fuse panel off and have just enough room to stick my arm up and feel around the back of the tach. Cant find any connection.
Old 25-05-12
earthworm's Avatar
Saab Sage!
As best I remember, the lead(s) run in a harness from the ECU..I suspect cracked soldered connections at the cluster...
The earthworm
'96 900S, Automatic
Old 26-05-12
Saab.XG Saab.XG is offline
My Saabs: Saab 900S 2.3NA Talladega
Check my posts - '97 had the same problem - there are for pin connections from the tacho gauge to the printed circuit board. Martin (new Zealand)
Old 26-05-12
BobSaabit BobSaabit is online now
My Saabs: '97 NG900 'vert; '03 OG 9-3 'vert
Connection is through one large connector to the back of the cluster. There's no separate connector for the tach.
Old 26-05-12
I'm talking about within the cluster - 4 Connections from the tacho to the printed circuit board - Read my posts on the subject. I'm certain tiggerz problem is like the one I had - Martin
Old 26-05-12
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is offline
My Saabs: Black on black '97 Saab 3-door SE Turbo
According to the schematic that I have, the tachometer signal is on pin 6 (of the 56 pin connector); the green/red lead... Ron
Old 26-05-12
How are you going to fix that without pulling the cluster?
Old 27-05-12
I did take out the cluster and opened it up to expose the dry cracked solder joint - It is going ever since with no problems
Try this link http://www.saabcentral.com/forums/sh...d.php?t=135509
If you repair your own cluster then you retain your mileage reading
Cheers - Martin
Old 27-05-12
Yeah, sorry, mixed up the two tracks in this thread. I thought it was the OP trying to do a repair through the fusebox "portal".
Old 01-06-12
So I just drove to Denver (Im from colorado springs) and about half way there the tach and boost gauge both started working. Then when leaving they didnt work again. So Im guessing it is what you guys are talking about. Thats what Im going to get into this weekend. Ill post back to update on how it goes. Thanks for the info
Old 01-06-12
If you give a good slap on to of the dash above the cluster you maybe able to get it to come on or off. When you take out the cluster which is bit of a pain - remember to disconnect the negative battery cable. Good luck - Martin
Similar Threads
For Sale: C900 Gauge cluster 8k rpm tach tkjr5000 Parts for Sale/Wanted - North America 5 28-02-12 11:47 AM
LED Tach DustinS Classic Saab 900 Performance, Mods & Tuning 2 26-01-11 05:23 PM
8k tach look Dninty9 Classic Saab 900 Workshop 5 30-08-03 10:38 AM
8k tach Carl Hernandez Classic Saab 900 Performance, Mods & Tuning 5 09-05-03 05:51 PM
tach Homer Classic Saab 900 Workshop 2 25-08-02 11:09 AM
