| Saab 9-3 & NG900 Workshop Saab 9-3 & NG900 (1994 to 2002) Technical Forum |
Has anybody here mated the seat back from a three door to the seat bottom of a five door? Is it doable? I haven't completely pulled the seat from my 5 door yet, so I'm not certain. But, maybe somebody knows and can spare me the busted knuckles if it won't work.
And what on earth do I have to do to get that Torx head out? is it a T-50? |
| Sponsored Links | ||
Advertisement | ||
Are you doing the swap because of worn seat back side supports? In case, have a look at my faq contribution below with respect to the manufacturing defect on the seat steel frame. I replaced the seat foam/fabrics only. I would imagine that the back and bottom are well tied together for security reasons. Maybe riveted or welded. Have a look if the photos of the frame reveal any details, I may be able to see more details on the full resolution images so let me know.
http://www.thesaabsite.com/Saab-900-...al-removal.htm -Mario |
I suspect that this will be a messy job, as the entire hinge needs to come off. Whatever linkage there is to release the seat track lock so the seat can slide forward when the seatback is folded forward will get in the way. If you're talking about the seat track bolts, yes they are big Torx, and some are reluctant. Having spare seat track bolts means that you don'thave to put a half-stripped bolt back in (where it will become fully-stripped the next time you try to remove it). |
Yes, Ed, the side bolsters are in much better shape. I can see metal through the hole in my current seat back, the foam is gone, gone, gone. So, the old seat is toast.
But, I have a whole seat. Are the seat belt mounts plug and play? Because the one end for the three door must be on the B pillar, while the five door mounts on the seat itself. Is it really that easy to swap? Oh, BTW, I meant the the Torx bolts holding the back and bottom together. I have both sets of rails, the current seat will come right out. Just haven't had the time yet. Last edited by metalbender; 16-05-12 at 03:42 PM. |
I tried to take the hinge bolts apart myself, and soon gave up. (I was trying to troubleshoot failed seat heat.) Time for a trip to the junkyard. |
I've installed a set of leather upholstery and foam from a 9-5 4 door into a 9-3 3 door. The foam and leather fits perfectly. Just have to open up a couple wire rings and get the upper guides for the head rests off the seat. Yea, those are fairly large torx bolts, they have a spot of thread lock on them to complicate things but I've not really had any problems with them either. |
Done. 3 door seats work in a 5 door car. Total plug and play. The main part is the seat belt mount for the 5 door. Mounts just like the seat belt buckle on the other side, both are canted under the seat at around 45 degrees. Seems like it sits a smidge higher. But it sure is nice to have back bolsters!
Took a while to break it loose, those T-40s have red thread locker on 'em. I wasn't about to heat it up, for fear that I light the seat on fire! Thanks for the responses. Next up: window regulator.... |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hesitation/hiccup when attempting to accelerate on the highway | dporgan | Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop | 20 | 21-09-11 01:45 AM |
| Attempting Steering Rack Install | pbonaceto | Saab 9-3 & NG900 Workshop | 11 | 27-09-08 09:00 PM |
| attempting to remove sump | mike 9-5 | Saab 9-5 Workshop | 3 | 21-09-08 10:03 PM |
| Attempting to address leaks | 84Saab900TURBO | Classic Saab 900 Workshop | 6 | 05-01-06 07:24 PM |
| Attempting Headgasket - tools req? | Jamal Bryant | Saab 9000 Workshop | 13 | 15-04-05 09:10 AM |
