| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
hi. i have had quite a few problems with my saab..but recently its sputtering when trying to get it to cut on..i realized today that i have a tear in the hose that goes from the engine to the radiator ( the kinda of fat one) is this jus a tear or is it possible that its a pressure build up? my fan stays on for periods of time after i cut my car off..and im jus looking for advice. do u think my thermostat is sticking and that whats caused the hose to split???
| Sponsored Links | ||
Advertisement | ||
Take a photo and post it here, if you don't have a camera, find a friend or relative who can help you, then have them help you post it here..
You don't to drive a car with split or cracked hoses.
2003 Saab 9-5 Aero Sport Wagon >>> My other home: http://saabworld.net/forum.php 2.3T HO B235R Manual 132,500 miles http://youtu.be/TZDGk5NXdh4 |
Where in NJ are you. If you are nearby I will take a look if you want. PM me or tell me here how to reach you if you want help....
i live in bloomfield..my cell is 434.713.1673 my name is louis feel free to call
replaced the upper radiator hose and bought a thermostat..but am unsure of where the thermostat housing is...i also realized i have about an inch crack in the plastic of my radiator. im going to buy some epoxy today and attempt to fix it it..but there must be an underlying problem..matter fact when i crank the car water comes out of the crack more profusely what could this be?
Thermostat is in the bell housing where the upper radiator hose is connected. You have to move the mess of wires as much as you can to get to the bolts. It is on the drivers side on the back side of the engine. Your thermostat sounds like it is stuck closed you need to get that replaced. I tried repairing the radiator with epoxy but it didn't work. Here is a solution but I haven't tried it?
http://www.instructables.com/id/Fixing-a-cars-radiator/ Here is another solution make sure you pay attention to make sure the crack is dry part or it will not work. http://www.doityourself.com/stry/pla...astic-radiator |
Crazy. You are about an hour away. A little far for me to come check it out. Not sure trying to repair the cracked radiator is going yield good results....
Good luck. |
ok..i found the thermostat and replaced it and it did seem to be sort of stuck closed..i jump started my car and finally got it to cut on but the crack in my radiator was spewing water and there was a lil bit of white smoke coming out of my muffler..i cut my car off and it wouldnt crank back up wats the posssiblilities?? could it be a bad DIC??
First off, if there's coolant spewing from your radiator, you need to get it fixed or replaced before you can go anywhere or you'll run out of coolant and overheat your engine.
But it sounds to me like you might have a blown head gasket, as white smoke in the exhaust can be a signal that coolant is leaking into the cylinders. It would also make it hard to start, and if you had overheated your engine (from a stuck thermostat or bad coolant sensor) it could damage the head gasket causing a leak. I believe another reason for white smoke is if your turbo is bad. I'm not the person to ask on how to fix this though. One more thing... you should probably replace your coolant temperature sensor as well, as I just had a problem with it causing my engine to overheat because it was reading low. This part is much easier to replace than the thermostat. Oh, and make sure you connected the ground cable to the thermostat housing correctly; if it's a bad connection it can prevent the car from starting (I just had this happen yesterday) |
I would agree with Ducka.. To burst the hose and or crack radiator means that it most likely overheated and your blew the head gasket and hopefully not the head.
I think you are up against a list of things. Check compression, visually check if you can see any leaks around head. Slight chance your head bolts are loose but if so and if you overheated you should change the head gasket anyway.
'01 9-5 Wagon 2.3. '00 9-5 Wagon 3.0, 1999 9-3 Conv. 1990 900 3 dr RIP, 1985 900 2 dr coupe RIP 1986 900 4 dr RIP 1976 99 2 dr RIP, 1977 99 5 dr RIP 1973 Sonett Gone but not forgotten |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| A question for the saaby,please help! | PA.Saab.Chic12 | The Lounge | 8 | 13-11-11 07:26 PM |
| Finally my newest Saaby.... | 9-3Anniversary | Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop | 19 | 14-03-11 09:54 AM |
| Pictures of my meh saaby finally | FireStorm | Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop | 7 | 20-03-07 11:46 PM |
| New Saaby Needs Advice | piguru | Saab 9-3 & NG900 Workshop | 0 | 11-07-06 02:25 PM |
| Alternator Belt Broke, Help ASAP! | ot0tot | Saab 9000 Workshop | 8 | 17-10-05 10:41 AM |
