Only one fog light working - SaabCentral Forums
Old 14th May 2012
DM114 DM114 is offline
My Saabs: 2004 Silver 9-3 Aero
Default Only one fog light working
I just replaced both of my fog light bulbs two days ago. I put them in one by one to make sure they worked. Before I did this my passenger side always gave me problems like not turning on until i tapped the bumper or tapping the splash shield. I just thought it was loose or something. I put the passenger side fog light in, turned the lights on to see if it worked and it came on. So i moved over to the driver side put the new fog light in, turned the lights on to see if the driver side would turn on. it did but to my surprise the passenger side wouldnt come on, even thou it did a few minutes before. Im not sure what it could be at this point. It seems like everytime I personally touch my baby to do something other than drive it something breaks.smh
Can somebody point me to the right direction.
Old 14th May 2012
lexington01 lexington01 is offline
My Saabs: 07 9-3 SS Aero BSR (RIP). 2012 Wrangler
If you have to tap on it to get it to work, it's got to be the contacts or the harness. Did you clean the wire harness and area where the bulb snaps in when you put the new bulb in?
Old 14th May 2012
I wiped the connector off to see if it would help but noting. I just used a wired brush similar to what you would clean battery posts off with and nothing. The old bulb that I took out looked burned
Old 14th May 2012
flipmoe88's Avatar
flipmoe88 flipmoe88 is offline
My Saabs: 04' 9-3 aero sedan
Garage
a couple of months ago i had the same type of problem. I pulled the bumper off and found that one of the wires was broken and not making contact. Easy fix. Not saying that's what it is but, easy to investigate.
Old 14th May 2012
gtp's Avatar
gtp gtp is offline
My Saabs: 07 9 2.0T BSR - Sold
Did you try using an electrical contact cleaner? I had this problem with a marker light and fixed it by cleaning the connector
Old 14th May 2012
thanks I'll try using the contact cleaner and tell you guys how it goes. While im down there I mind as well check the harness too
Old 14th May 2012
gtp's Avatar
gtp gtp is offline
To get a good look at the harness its best remove the bumper, its not has hard as is seems, 3 screws on each side of the wheel and then 5 or 6 screws underneath the bumper and it comes off.
Old 18th May 2012
Ok its a couple days later and my fog is still out. Used contact cleaner and no dice. So I had a friend check to see if I was still getting power to the connector I was, but he thinks I have a bad ground. Is this possible i thought the ground for the headlight and fog light was the same?
Old 18th May 2012
HuNtS's Avatar
HuNtS HuNtS is offline
My Saabs: Steel Grey '03 ARC 6MT
Garage
Please post up if you figure this out. I have the same issue, though if I replace the burnt out side, the other side will pop. They both work fine for a day or two in between whichever bulb decides to go out next
Old 18th May 2012
Gs04aero's Avatar
Gs04aero Gs04aero is offline
My Saabs: 2004 VTuned Aero
How is the metal where the bulb attached? Mine got wet last year and corroded the terminal. I had the retrofit projectors because the terminal was unusable and shorter out. Check to see if that's your problem.
______________________________________________
2004 9-3 Aero
Old 20th May 2012
are you talking about that metal square where the bulb sits if u are then its burnt to tell you the truth, but could this be causing my problems?
Old 20th May 2012
Gs04aero's Avatar
That was my problem. The whole thing was burnt up and was causing a short so it wouldn't work at all. Thought it was the bulb, changed it and it didn't work. I wired a socket to the power wires and it worked so I knew it was the connection area.
2004 9-3 Aero
Old 21st May 2012
any suggestion on to how I can get my light working? I hate when something thats supposed to work doesnt on my car.lol
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Dome light not working duklaa NG900 & OG9-3 Workshop 11 2nd January 2014 08:34 PM
Trunk light, reverse light, license plate light all not working together min-va 9-5 Workshop 5 13th December 2011 07:16 PM
light not working eric's900 C900 Workshop 2 19th May 2009 03:10 PM
tcs light not working!! want a 9000 NG900 & OG9-3 Workshop 0 5th June 2008 02:11 AM
TCS light not working want a 9000 NG900 & OG9-3 Workshop 1 4th June 2008 10:26 AM
