| Saab 9-3 & NG900 Workshop Saab 9-3 & NG900 (1994 to 2002) Technical Forum |
Has anyone ever had the check engine light come on for a few days then go off for a few days then come back on again? This has been the cycle on my 9/3 Saab for the past 2 weeks.
| Sponsored Links | ||
Advertisement | ||
Perhaps something is marginal and intermittently exceeding parameter limits. Try putting an OBDII scanner on it and getting a code out of it and that should point you in the direction of the problem.
This has happened to me about 4 times now and when I bring it to Auto Zone to have the code checked it is the oxygen sensor. Just last week my light came on (I had almost no gas if that matters), I filled the tank, and when it got to a 1/2 tank a few days later the light went off.
I had an intermittent- turned out to be the DIC slowly going bad. Eventually it turned into a hard failure. If possible, run diagnostics at your local parts store when the light is on.
Just went through that with my Viggen, it was a bad thermostat.
The light was on today when I came home, if the light is still on tomorrow I will go to advance auto parts or autozone down here and have them check for codes. Can theses auto stores run a thorough diagnostic, do they have the equipment to run a complete diagnostic? I thought you needed a tech II for this? Thanks for the info. Joel
iirc the sensor is at the driver side (US) end of the cam closest to the cabin. Wherever it is, I'd check that it is clean and well connected (wires to plugs and plugs to each other) before throwing replacement parts at it. It could be the sensor but try the cheap/easy fix first...
'01 Black on Black Viggen Convertible '98 Volvo V70 T-5 Highly Modified '03 Tahoe Modified '92 Pathfinder Modified Prosperity, SC, USA |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Check Gearbox / Check Engine Light Mystery | NYSaabGuy | Saab 9-3 & NG900 Workshop | 7 | 07-12-10 09:09 PM |
| check engine light, check gear box light | dcsaab gal | Saab 9-3 & NG900 Workshop | 1 | 12-07-09 11:10 AM |
| Check Engine Light, Check GearBox Light | dcsaab gal | Classic Saab 900 Workshop | 2 | 12-07-09 09:49 AM |
| Check Gear Box/Check Engine Light + Limp Home Mode! | eggloaf | Saab 9-3 & NG900 Workshop | 2 | 16-07-08 10:44 AM |
| Check Engine light ***AND*** Check Gear Box lights came on! | sunnydude | Saab 9-3 & NG900 Workshop | 7 | 02-02-04 12:20 PM |
