2001 saab 9-5 Fuel pump replacement - SaabCentral Forums
Old 10th May 2012
sloan sloan is offline
My Saabs: 2001 Saab 9-5 2.3t
Question 2001 saab 9-5 Fuel pump replacement
On replacing the fuel pump on my 01 saab 9-5 can I just buy a replacement pump instead of the entire assembly? Does it switch out easily?
Old 10th May 2012
TankTak TankTak is offline
My Saabs: Elskerinne..'02 Saab 9-5 HBSaabs stage 3
yes, a lot of people just switch out the pump instead of the whole assembly
Heres a thread that can help:
http://www.saabcentral.com/forums/sh...d.php?t=190466
Old 10th May 2012
8pack 8pack is offline
My Saabs: 2001 9-5
You can just change out the pump. Look out for Chinese knock off Walbro pumps. They are even stamped Walbro. Research on Internet. Make sure it is a genuine pump. I ended up buying the whole pump assembly as it was around $100 more and I knew genuine.
My pump was fine. I did it as preventive maintenance. I will sell you my old working complete pump and assembly if you like, as I said, it was functioning fine. PM me if interested
Old 10th May 2012
photousa's Avatar
photousa photousa is offline
My Saabs: 2003 Saab 9-5 Aero Wagon 2.3T HO Manual
Here's where I bought mine: http://www.fuel-pumps.net/
It's been fine since installation.
2003 Saab 9-5 Aero Sport Wagon >>> My other home:
2.3T HO B235R Manual 157,000 miles
My Saab Mechanic in Chicago: George @ G&S (773) 637-8431
Old 5th May 2016
KLB KLB is offline
New Member
My Saabs: 2000 9-5 wagon 4 cyl turbo
I have a 2000 saab 9-5 wagon 4 cyl turbo. I ran some errands monday morning and got stuck in a parking lot. Its was turning over buked the spark plugs, fuses, and relay) Since then i have changed the fuel filter and fuel pump and it still not starting. Even tried jumping it. Sooo frustrated! Any help would b greatly appreciated.
Old 5th May 2016
try changing the CPS...Crankshaft Position sensor
Old 5th May 2016
Mariner Mariner is offline
My Saabs: 1999 9-5 SE 2.3lpt
It will be a little easier to give advice if you can provide added information. I translate from your post that you checked plugs, fuses, and relay(s)? Main thing to remember in basic starting is that air, fuel, and spark all need to be present.
Any check engine light (CEL) or codes? Since you changed out the pump and filter you probably checked this, but does the pump run for 2 to 3 seconds when the key is switched "on" but not to "start" ? When you turn to "start", does the starter crank (turn the engine over) ? AND when you do that, does the tachometer bounce showing the engine is cranking?
If there is no sound from the pump when "on", then check the voltage to the pump and the fuel pump fuse. If there is sound, the pump is at least running. If the engine cranks but the tach needle doesn't move, then CPS (crank position sensor) is a very likely culprit. See other recent posts on CPS.
If the pump runs and the tach moves, you need to diagnose further. My next step would be to check the DIC (Direct Ignition Cassette) and plugs. Look for any cracks / distortion on the under side of the unit where the individual spark coils and boots attach. The easiest thing is to try a known good DIC, if one is available. I don't trust non-SAAB (SEM) brand DIC's - failure rates are way too high, and they often fail with no CEL.
If that is not the problem, then I would check the actual fuel delivery at the fuel rail (there is a Schraeder valve with a cap), but you need a fuel pressure gauge for this, and it can be dangerous unless you take precautions. If you really had a bad pump but put in a new one and it runs but gives no pressure then be sure you removed the shipping seal from the pump pickup port.
Hope this will help,
Mariner
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
99 saab 93 gas gauge problem after fuel pump replacement syain NG900 & OG9-3 Workshop 4 4th February 2012 07:01 PM
Fuel pump fried on my 2001 9-3 hatch? Mathew40 NG900 & OG9-3 Workshop 8 30th December 2011 02:27 PM
For Sale: 2001 9-5 Fuel Pump for sale 8pack Parts for Sale/Wanted - North America 0 27th November 2011 09:24 PM
Saab 95 Fuel Pump replacement - Help! Matt_T 9-5 Workshop 18 12th January 2011 08:25 AM
SAAB 900S, 1996 Fuel pump replacement Russkii NG900 & OG9-3 Workshop 4 20th August 2003 08:09 AM
