climate control only blows on windscreen - SaabCentral Forums
Old 04-05-12
mrspudulike mrspudulike is offline
New Member
My Saabs: 9-3 TID1.9 Linear
Question climate control only blows on windscreen
Hi all
1st post! Have a December 2008 9-3 saloon linear TID1.9.
So, had a problem with the drivers window not going all the way up, so I disconnected/reconnected the connector in the door hinge.
Sorted the window.
HOWEVER, I now have another problem which may or may not be related.
When I have the ACC on, the air only blows through the windscreen vents....
Now, I turn off auto, and select the button for front vents, and that works perfectly, but of course, lose climate control.
At least I know there is nothing wrong with the fans.
Do I need to reset the system or something to get the air to blow out of all vents?
Thanks in advance!!
Old 04-05-12
chris_de_ze's Avatar
chris_de_ze chris_de_ze is offline
My Saabs: '03 9-3SS Aero I4, MT6, Maptun Stg 1
DO you have the temp adjusted to LOW?
If yes, adjust it a reasonable temp number.
Also disconnect for 1 min the negative battery post to reset the system.
founding member of the Greek Saab Forum www.saabforum.gr
Old 10-05-12
New Member
OK, so an update:
* When on cool / cold, air comes from all vents as expected
* When on warm (23 degress Plus), onl;y blows through windscreen vents
* Have disconnected battery for a few minutes and did not help
* Tried the ACC reset trick by pressing AC and off button at once, but
* Nothign happens (do not have digital display on ACC on my car)
Really annoying me now.
Similar Threads
Steering wheel volume control & climate control screen. 93Se93Se Saab 9-3 & NG900 Workshop 6 09-03-12 02:51 AM
Auto A/C climate control to Manual control? SpongeBob Saab 9-3 & NG900 Workshop 5 21-11-09 11:49 AM
Auto Climate Control - Vent control problem desmoboy Saab 9-3 & NG900 Workshop 3 11-03-06 06:55 PM
Climate control: LO blows hot? Matt Phelps Saab 9000 Workshop 8 19-07-05 10:15 AM
Windscreen wiper control. Guest Classic Saab 900 Workshop 10 07-12-01 01:15 PM
