Error code P0171 System Too Lean - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 29-04-12
erix920 erix920 is offline
My Saabs: 1997 Saab 9000 CSE
Default Error code P0171 System Too Lean
I am starting to get this error code more frequently now. I'm not sure if it has to do with the temperature change of spring or what it is.
Here's there freeze frame data:
http://i.imgur.com/vqLh6.jpg
http://i.imgur.com/XsIMn.jpg
Tune is stage 2 on a TD04 automatic '97. Could it be a bad injector or the stock ones arn't strong enough for 18psi out of the td04?
Thanks.
Old 29-04-12
Twinsen Twinsen is offline
My Saabs: 9000
Yes, it could be an injector. Unplug them at idle, one by one. Each should make an obvious difference in idle quality. If one doesn't, something is wrong with that cylinder, though not necessarily the injector. Bad ignition will send O2 through the exhaust as well.
It may also be an exhaust leak before the upstream O2 sensor, or the sensor itself.
Old 30-04-12
saabfan9's Avatar
saabfan9 saabfan9 is offline
My Saabs: 1996 AERO...1973 99 EMS...
long term adaptive at +25 map at 16 in why is the rpm's at 3000? is there a vaccum leak? (normal ranges: adaptives short/long should be as close to zero as poss and map is 18-21 in)
http://i.imgur.com/flLz1.gif
Old 07-05-12
There are two noises here in this video. One of which is the timing chain and the other I think is the injector (the one thats much shorter in duration but much faster). If so, should I use this as my excuse to get green giants.
I have yet to unplug the injectors though.
I don't think there's a vac leak. I get 20+ inches on vacuum with my foot off the pedal.
http://www.dropshots.com/erix920#dat...05-07/16:01:39
At 7 seconds you can hear it really well.
Similar Threads
P0171 System bank to lean (did a search) Tamatalon39 Saab 9-5 Workshop 1 06-04-12 06:36 PM
Check Engine Light P0171 - System Too Lean (Bank 1) brace up Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 16 13-03-10 01:35 PM
Running Lean - P0171 exotek Saab 9-3 & NG900 Workshop 3 26-10-09 11:17 AM
P0171, Lean mixture CEL code - Need some theories Jamal Bryant Saab 9000 Workshop 4 09-08-09 11:58 PM
CODE P0171, system too lean Sap Saab 9-3 & NG900 Workshop 4 22-01-07 03:26 PM
