Throttle body vacuum hose - SaabCentral Forums
Old 20th April 2012
scoll7567 scoll7567 is offline
My Saabs: 2001 9-5
Default Throttle body vacuum hose
I spent the past hour searching this forum and can't find the answer. To what does the other end of the throttle bottom connect? Is it the oil trap? I noticed the oil trap had a small spigot with a connection.
Thanks
Old 20th April 2012
My Saabs: 2001 9-5
Nobody knows????
Old 20th April 2012
Lacju Lacju is offline
My Saabs: 99 9-5
I'm replacing the rest of my vacuum lines today, if not one responds by the time I am done I will look at mine and let you know.
Old 22nd April 2012
My Saabs: 2001 9-5
I'm accepting guesses now
Old 22nd April 2012
Paul in NM's Avatar
Paul in NM Paul in NM is offline
My Saabs: 6 former Saabs
It'd help to show a picture. The only hose in the rear hooks up to the evap system.
Old 22nd April 2012
My Saabs: 2001 9-5
Typo it is the vacuum line attached to the top of the throttle body. I'm not sure where the other end attaches
Old 22nd April 2012
Paul in NM's Avatar
Looking at the TB from the front of the car the vacuum nipple on the lower left connects to a solenoid underneath the black covered wire harness attached to the engine wall (to the right of the TB).
Old 23rd April 2012
My Saabs: 2001 9-5
Where does number 12 go in the attached photo?
Old 23rd April 2012
My Saabs: 2001 9-5
Does it attach to the top of the oil trap?
Old 23rd April 2012
Paul in NM's Avatar
#12 goes to a nipple under the hose that connects to the valve cover. There should be a check valve connected to it as well (part #7 in the pic below).
Old 23rd April 2012
My Saabs: 2001 9-5
I believe it does and I'm missing the check valve that goes between the two. My car is currently revving at idle. Is this correct?
Old 23rd April 2012
My Saabs: 2001 9-5
Oh, thanks Paul
Old 23rd April 2012
TankTak TankTak is offline
My Saabs: Elskerinne..'02 Saab 9-5 HBSaabs stage 3
Sounds like you might have the old pvc system, I would check and upgrade to pvc #6. It will help with a number of issues that can present themselves at usually the least expected times
Old 23rd April 2012
My Saabs: 2001 9-5
I thought the upgrade only applied to the 4 cyl I have the 3.0 6 cyl?
Old 23rd April 2012
twoturbos twoturbos is offline
My Saabs: Various
Information that would have helped at post 1
Old 23rd April 2012
Paul in NM's Avatar
Well that's a different ball game. This is all I could come up with pic wise...
Old 23rd April 2012
My Saabs: 2001 9-5
That is perfect, I hoping the check valve fell and I can find it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Need to replace Vacuum hose from throttle body to Purge valve? Thehenigan NG900 & OG9-3 Workshop 4 9th April 2012 03:41 PM
Throttle Body & Vacuum Pipe HeLp!!!!!!! moxonsaab 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 2 8th February 2012 08:19 AM
96 saab throttle body vacuum hose diagram demon06 NG900 & OG9-3 Workshop 2 25th April 2011 09:17 PM
Throttle body vacuum hose check valve 99S9-5BV6 9-5 Workshop 1 30th January 2009 07:15 AM
Vacuum hose on throttle body kennlopez C900 Workshop 7 16th February 2006 03:22 PM
