Oil cooler lines ...which side??? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 19-04-12
Tony Rome's Avatar
Tony Rome Tony Rome is offline
My Saabs: 1994 Saab 9000 CSE
Default Oil cooler lines ...which side???
Hello ...me again. One of my last jobs in completing my engine reinstall is hooking up the oil cooler lines at the oil filter housing. I thought the connections were different sizes in order to dummy-proof them, but they're the same size. I'm not sure which side the short and long lines hook to. Mama said there would be days like this.
Anyone happen to know a place to get a replacement line or possibly a custom line made (braided stainless steel)? They are in "not available" status at Saabsite.com
Old 20-04-12
sp53 sp53 is offline
My Saabs: 1989 saab 9000 1992 9000 1993 9000
Around here we have some hydraulic shops that repair big truck and logging/earthmoving equipment hydraulic lines. I take my old Saab ones or triumph brake lines in and they replicate new ones with their crippling and bending equipment. I had my trany lines done on the Saab for 25.00. Anyway shop around your area for commercial trucking repair. they just need the fittings
Old 22-04-12
bmacb bmacb is offline
My Saabs: 2 96 9000s and 1 97 9000
I am not sure if that is what you are asking, but the longer oil cooler ends at the fitting nearest the oil filter.
I have no experience myself but I heard others recommend using a hydraulic shop to create "new" lines (reusing the ends) can be a qualify cost effective solution.
Old 23-04-12
KevinC's Avatar
KevinC KevinC is offline
My Saabs: sorted 9K Aero 1993, 9000R, 454 GMC
Thin if you try them they will only fit one way; from memory the longer one goes up top.
TBH though I doublt it makes much difference, under oil pump pressure, going to go thru the oil radiator, important thing here = no leaks. Most the hoses OEM I've seen are in bad shape, I'm doing an engine rebuild like you have done & am going the hyd hose shop rebuild route.
Old 23-04-12
Tony Rome's Avatar
Thanks for the help everyone! I believe I have this sorted out now. I was confused as to which line goes to the connection closest to he oil filter (answered above). I didn't want to get the lines reversed.
Yep, I'm going to build some custom lines, although my existing lines are in good shape. I just had one line with a male connection that was frozen. It would not spin to allow me to screw it into the oil filter housing. I hosed it down with PB Blaster and let it soak overnight. Then I took an impact gun (w/ deep wall 22mm socket) to it and gave it a few hundred spins to break up the rust. It works fine now.
Old 30-04-12
KevinC's Avatar
[QUOTE=Tony Rome;2184080]Thanks for the help everyone! I believe I have this sorted out now. I was confused as to which line goes to the connection closest to he oil filter (answered above). I didn't want to get the lines reversed.
/QUOTE]
Pulled an engine last week, and can confirm that as you look at the engine from the front or oil filter/exhaust side, the pipe on the RIGHT side of the oil filter goes to the TOP of the oil cooler.
No special pressure here, so any decent braided hose will work for a replacement.
Similar Threads
Leaky oil cooler lines. jwandhistools Classic Saab 900 Workshop 1 17-02-12 03:44 PM
Wanted: 16v oil cooler + oil cooler lines + oil cooler brackets - Australia or USA S900t8v Parts for Sale/Wanted - Rest of World 0 06-11-11 07:07 AM
Oil Cooler Lines lifeonloan3 Saab 9000 Workshop 1 15-05-11 02:25 PM
oil cooler lines help! goincb89 Saab 9-3 & NG900 Workshop 2 08-05-10 10:26 PM
One of my engine oil cooler lines let go on the hwy, please help!!!! 91900turbo Classic Saab 900 Workshop 30 12-02-08 04:26 AM
