only half boost under load - will not spool fully - SaabCentral Forums
Old 11-04-12
1995NG900S 1995NG900S is offline
My Saabs: 1995 NG900
Default only half boost under load - will not spool fully
Hello All,
I did my best to try and find an existing or old thread to answer this question but to no avail...so...I have sold my 1995 900s and finally got a turbo jet- 2004 9-3 linear
the person I bought it from said that it would never spool up fully and the gauge would never go past the "o" on the turbo gauge. He was right. I though i could replace the Boost control solenoid and that would fix it....WRONG..it will still not go past 3/4 boost.
I checked the air intake, the fan fuse, and still no dice..HELP!
If only i could make you RWD and put a 400 small block in you
Old 12-04-12
smut smut is offline
My Saabs: 99 93 stg.3
Default Boost?
When you say 3/4 boost what do you mean or how do you know its 3/4 boost?
Old 12-04-12
Default performance
I feel like it is not getting full boost under load b/c
- the gauge never gets close to the orange ( could be broken though)
- You never hear the turbo (i have never owned a turbo saab so maybe you are not supposed to be able to hear it?)
- it has the same performance as my last car NG900s 2.3 na.
- I figured that a 2004 with a 100k and a turbo should be able to take on the on-ramps better than a NA 900s with 175K
I really do not think it is the gauge
- the shop down the street hooked it up to their computer and they said it was the BCS, which i replaced but that did not do squat.
Old 12-04-12
Default Re
Have you recycled the ECU ,you may be running on base boost?
Old 12-04-12
Default Bone Stock
The car is bone stock - no modifications ever
I am thinking that it may be a blocked check valve or loose hose
The gauge will also not go all the way down to read zero boost either - is that normal? it stays at like 1/4 boost than eventually goes up to 2/3 or 3/4 bosst but never into the orange
Old 14-04-12
Default Reset ECU no help
So I disconnected the battery and buffed my terminals and it was like I had a new car!!.....full boost and better throttle response....for about an hour than the check engine light came on and it was back to granny mode.....WTF?
I think their might be a vacuum leak or something
Old 14-04-12
aerojon's Avatar
aerojon aerojon is offline
get the code/s read then post them up,otherwise were just guessing..
ICM3 13sp system now with bluetooth audio streaming..
Old 15-04-12
Default OBD Linking Error
I tried to link my OBD2 code reader up and it said linking error...I tried to run it with the car on, car off, key in the on position but car not fully, and it still said linking error....is there a specific software update that i would need to download for it to work?
Old 15-04-12
aerojon's Avatar
is your reader canbus enabled/compatible..
Old 15-04-12
genman genman is offline
My Saabs: 9-3 Turbo X + Aero 2.8 XWD
is your car not the older OBD system....so the reader needs to match.
could be a sticky wastegate valve not allowing the boost to be controlled properly.
Old 15-04-12
aerojon's Avatar
Sent from Sinclair Spectrum 48k..
Old 15-04-12
Question Boost Control Valve
So I went to advanced auto who reads code for free -- my actron 135 code reader just did not want to co-operate..and yes the car is OBD2 - and car made after 1996 is required by law to be obd2
anywhooo...its spit out the code P0033 - Bypass valve control circuit open
so the boost bypass control valve is broken which is the exact part as the boost control solenoid..same part # and everything..
Im getting a new one from http://www.goldwingsaabparts.com/
ill let you all know how it goes...unless you think there might be a deeper problem
Old 15-04-12
******did not proof read that last post and I kinda sound like precocious d#ck..appologies
Old 21-05-12
Default All Valves replaced and light still came back on!!!! WTF!!!
I replaced both the Turbo Bypass Control Valve and the Boost Pressure Control Valve, had the code cleared and the check engine light still came back on with the same error.
Any suggestions?
Old 17-06-12
ItsALoveHateThing ItsALoveHateThing is offline
New Member
My Saabs: 2004 Saab 9-3 Aero SS
Im having the exact same problem with my 04 9-3 Aero, except my car is not throwing any cel lights. Please update if you find a fix, and I will do the same!
You sound like your from London!
Old 17-06-12
BadBrains's Avatar
BadBrains BadBrains is offline
My Saabs: '02 9-3 SE, '06 2.0T 5spd VTuned
This could be a problem in the wiring itself, not necessarily the part at fault. Be sure the connector terminals are clean and have the circuit tested for continuity. Open circuit is usually due to a bad connection or broken wire.
Old 17-06-12
New Member
So, even though my car didnt throw a cel, i plugged in the obd2 reader and it read code p0244. So i checked the boost control cyliniod? And cleaned the plug the put it back on very snug and now the car is fully boosting again. Ill update again if anything changes!
Similar Threads
Only getting half boost YouFounDonon Saab 9-3 & NG900 Workshop 6 07-03-12 12:24 PM
inconsistent - won't boost fully - help colm Saab 9-5 Workshop 10 20-04-10 05:40 PM
Boost gauge only show half boost and AERO is dog slow SpoolinUpBlue Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 11 03-04-10 07:38 PM
Spool, spool, spool - psssht! Spool, spool [etc] ragtopcav The Lounge 12 01-11-06 07:05 PM
Car will NOT boost fully! 85 SPG Classic Saab 900 Performance, Mods & Tuning 16 23-08-06 07:23 PM
