Wrong rotors ordered? - SaabCentral Forums
Old 2nd April 2012
maj28's Avatar
maj28 maj28 is offline
My Saabs: 2004 9-3 Arc w 72k
Question Wrong rotors ordered?
Hi folks, sorry about being a fair weather member, I gotta pop in more often, anyway, I think I got the wrong rotors from 'the rack' for the front of my '04 Arc.
This is the first time I've messed with my front rotors and I can't figure out if I've got the wrong rotors or if my hub and rotor are stuck together.
I loosened up everything except the larger E-socket bolts on the back and couldn't get the rotor off. Looks like to me that the factory rotor is one fully integrated part, and the new one is cut out in the center. What am I doing wrong?
Also, I have the E18 socket (the smaller one on the back), but I need the bigger one, what size is that?
TIA!
Pics of near rotor and current rotor:
http://dl.dropbox.com/u/11648864/201...-35-05_349.jpg
http://dl.dropbox.com/u/11648864/201...3-35-27_77.jpg
Old 2nd April 2012
Jblk059320t's Avatar
Jblk059320t Jblk059320t is offline
My Saabs: Jet Black 2005 9-3 2.0t L
Take the bolt with the Alan key socket off, there are also 3 16 mm bolts in the back to take the caliper mount off. If it still feels like its one piece then its rusted and needs to be worked off. That's the way it was for mine
Old 2nd April 2012
maj28's Avatar
Thanks for confirming it's not one single piece.
I'm certain however the bolts on mine are e-torx sockets, looks like the E18 is towards the center of the hub assembly and the two larger ones may hold the caliper bracket - maybe E20?
Old 2nd April 2012
jboogie's Avatar
jboogie jboogie is offline
My Saabs: 2003 9-3ss JZW Stage 2 TD04 Swapped
Its an E24, and make sure you have lots of PB Blaster because those suckers are on there
JZW TD04 Tune, TD04 Swap,Prosport Electronic Boost Gauge, Custom 2.5" Cat-back exhaust, Aero Injectors, Custom AEM Dryflow Air Intake
Old 2nd April 2012
maj28's Avatar
Thanks, but just found this video that says they're E20?
https://www.youtube.com/watch?v=yt-N4Kie95s
Maybe I'll just order a set of them.
Old 2nd April 2012
ddouble518's Avatar
ddouble518 ddouble518 is offline
My Saabs: 9-3ss , 9000 CDE
Make sure you use some heat on those caliper bracket bolts. Mine had red loctite on them.
Old 2nd April 2012
maj28's Avatar
Thanks, I'll see how it goes, rather not put heat near my CV boot if avoidable. Hopefully the 18" breaker will work.
-jason
Old 2nd April 2012
datonyb datonyb is offline
My Saabs: 93 aero 2004
just done mine
round the back are
two 7mm HEX caliper sliders these require removal to acess the pads and remove the caliper (the bit with the piston and fluid in) these are covered with plastic bungs
the caliper will come off now and pads
then there are two e20 torx head bolts
these are tighter than a jew in an arabic market
breaker bar time
when these are out the caliper bracket/support comes off
next theres a tiny little torx or hex headed bolt on disc face(where the wheel bolts go) its like 5mm hex of t25 ish torx
remove this and rotor/disc is free to come off
which is an oxymoron as you will probably find yourself smashing ten bales of crap outta it with a soft faced hammer (wear eye protection in case it shatters)
hit it at 3 oclock then toate 180 degrees and hit again
theres a full write up in the 'how to section'
Old 2nd April 2012
maj28's Avatar
Great to know! Better find my rubber mallet. And checking that section now, didn't find it before.
EDIT: Wow, it's like the first one, FAIL.
Old 2nd April 2012
yeah tough little cookie to find huh
never mind mate we all time to help guys that make an effort to fix cars themselves
its quite a good write up but i suggested the edit to say e20 bolts as they were on mine and i wasted a lot of cash getting a set to include the e24 i didnt need
make sure the face of old hub is uber cleaned of rust and debris so the new disc sit true on this or they wont bed in true
and will feel like and old set of crap discs/rotors that warped years ago
time is free friend spend it well!
copperslip lubricate the metal retaining edges of pads as well so they are free to slide in caliper bracket for a year or two
tighten the brackets back upto spec torque (think it was 140lbft please check) then tighten a further 30 degrees
Old 2nd April 2012
saabz saabz is offline
My Saabs: 2003 9-3 Vector
All good advice. It sounds like you're going through what I did with my '03 two years ago. The front rotors felt like they were welded onto the hub. PB didn't help here; there was too much surface to surface contact to penetrate. I then tried the rubber mallet -all it did was give me and the car the shakes. Then the sledge hammer - yes, worked. I was going to replace the rotors, so what did I care about beating the H out of the old rotors?? I even resorted to a brick-set for a few strategic blows.
Old 2nd April 2012
i have had to stitch drill a disc off before now
literally drill a line of holes from outside edge to inner hole by hub then crack her with a cold chisel
now that was a pain for sure
Old 3rd April 2012
remmyman remmyman is offline
My Saabs: 2003 93
Sledge hammer was also my solution to the problem. Since I always replace rotors when doing pads no big deal. I also use Anti sieze when fitting new rotors.
Tags
brakes, hub, pads, rotors
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Slotted rotors rotation in wrong direction. For those of you with slotted rotors... saab&engineer NG900 & OG9-3 Workshop 4 26th July 2011 01:49 PM
Ordered the wrong mats! Help me get rid of them REOSPDWGN 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 7 23rd January 2009 06:07 PM
Just ordered new pads and rotors Sanfi NG900 & OG9-3 Workshop 4 20th August 2006 06:59 PM
Just Ordered Viggen Rotors! aero1116 9-5 Performance, Mods & Tuning 1 4th February 2006 04:40 AM
Brembo Crossdrilled Rotors Ordered! Turbo 900 NG900 & OG9-3 Performance, Mods & Tuning 24 15th July 2004 06:10 PM
