Replacing the Jalousie - SaabCentral Forums
Old 30th March 2012
Cartmn192's Avatar
Cartmn192 Cartmn192 is offline
My Saabs: Saab 9-5
Garage
Default Replacing the Jalousie
So today i tackled on the project to replace my broken jalousie. I found what seemed to be the best instructions on how to do so.
Now for the truth, in the process of following the instructions, I ended up breaking a couple of small pieces such as tabs, my sport button and all. My shifter (auto) does not also feel the same after putting it back together. So my question is, does ANYONE HAVE GOOD INSTRUCTIONS ON HOW TO REPLACE THE JALOUSIE?
Old 30th March 2012
photousa's Avatar
photousa photousa is offline
My Saabs: 2003 Saab 9-5 Aero Wagon 2.3T HO Manual
try saabworld.net
2003 Saab 9-5 Aero Sport Wagon >>> My other home:
2.3T HO B235R Manual 157,000 miles
My Saab Mechanic in Chicago: George @ G&S (773) 637-8431
Old 30th March 2012
unclemiltie's Avatar
unclemiltie unclemiltie is offline
My Saabs: 9-5 Aero's - 01 Wagon, 03 Sedan
Garage
it's not hard, there are some instructions in here that you can follow.
Take rubber surround from the shift plate off
take the torx screw out of the shifter handle, it's in front above the lock-out handle and is hard to find. Don't drop it!
separate the shifter pieces, unsolder the sport mode button (there is no connector)
take the circlip that holds the lockout handle on out, don't drop it! remove the handle
take the front of the shifter off, pull up.
take the shift plate out
change the pieces, reassemble in reverse. Tape or lightly glue the torx screw to the screwdriver in order to get it in. that's the hardest part.
The only thing that is a pain is that there is no connector on the sport mode button and you have to unsolder and resolder it. But you have to take the front part of the shift handle off since it's notched into the jalousie and makes it move.
Old 30th March 2012
Route 17 Route 17 is offline
My Saabs: 2006 9-5 2.3T
The instructions:
Removal of trim pieces is the same as replacing the light bulb that illuminates the gear selector bulb.
Click on the hyper link and scroll down the page until you see ALL the pics.
http://www.twinsaabs.com/9-5_repair/...?nsteps=1#lock
Removal of the gear selector handle
http://saabworld.net/f29/saab-9-5-ge...on-system-667/
Good Luck!
Old 31st March 2012
SaabDozer SaabDozer is offline
My Saabs: '05 9-3 2.0t / '99 9-5 V6
Garage
What the hell is a Jalousie?
Old 31st March 2012
vividly's Avatar
vividly vividly is offline
My Saabs: 2000 9-5 SE (Sold), 2009 Ford Focus SEL
The black plastic piece that goes around the auto shifter - it slides with the shifter to cover the mechanicals inside. Breaks from time to time. I bought a new one and installed it by slitting the plastic and slid it around the shifter rather than taking everything apart. I can't even tell.
Old 1st April 2012
Garage
Ahhhhhh.
Old 1st April 2012
Alain93's Avatar
Alain93 Alain93 is offline
My Saabs: 2000 9-5 wagon 2.3t
Garage
Wow, good idea! I think I'm going to do that.
Where did you split it?
Old 1st April 2012
vividly's Avatar
I snipped it on one side where it would slide around the shifter (the narrow part). I can't take credit for the idea though. I probably read it here.
Old 1st April 2012
Alain93's Avatar
Garage
Thanks
Old 23rd April 2012
billy2008 billy2008 is offline
Broken jalousie. Read that later yr 9-5 S button not soldered on. I have a 2005 -- can anyone confirm it is clipped & not soldered?
Do people recover and glue back the broken portion of jalousie ? Mine is from the lower end.
Any pics of walk through for cutting/fitting new jalousie to avoid soldering?
Thx!
Old 23rd April 2012
Alain93's Avatar
Garage
Hi,
I followed Vividly advice to cut the Jalousie at its narrow part (see pic).
I used a sharp knife, and it works perfectly.
Old 23rd May 2012
Bub1958 Bub1958 is offline
My Saabs: '04 9-3 Convert.
Europarts has this on long backorder. Is there any other place where I can get one?
Old 23rd May 2012
srmoose srmoose is offline
My Saabs: 01 9-5 2.3l 00 9-5 3.0, 88 900 2dr 2l
I had that same question but I used the process of elimination and finally figured it out.
I sandwiched some brushes from a black brush into the shifter, looks like the E Brake opening.
'01 9-5 Wagon 2.3. '00 9-5 Wagon 3.0, 1999 9-3 Conv.
1990 900 3 dr RIP, 1985 900 2 dr coupe RIP
1986 900 4 dr RIP 1976 99 2 dr RIP, 1977 99 5 dr RIP
1973 Sonett Gone but not forgotten
Old 23rd May 2012
Found it under another name - "Blind Cover." About $33 delivered.
Old 23rd May 2012
inteller inteller is offline
My Saabs: 2006 9-5 2.3T w/ Sport Package
another question is how do you properly care for your jalousie so it doesn't break? replacing looks like a bear.
Old 23rd May 2012
I think the replacement will be easy enough using the "slit" method, but now I'm wondering if the piece that's missing is broken off but hidden from view towards the back end. If so, when I put the new one in, it won't have enough room to slide backwards. Any ideas about this?
Old 9th June 2012
saabstory27 saabstory27 is offline
New Member
My Saabs: 9-3 hatchback 2002
I had my jalousie/tambour broken by the driver at a car wash last week. Mine's a 9-3, but I keep being told it's impossible to replace the part. Where did you get yours and how long did it take?
Thanks!
Old 10th June 2012
Thanks!
Haven't bought it yet...waiting for my mechanic to decide what to tackle all at once. Here's an Ebay listing.... a little more expensive:
http://www.ebay.com/itm/251050480348...84.m1423.l2649
Can't recall the other places I found it, but if you can find a new shifter you'll find all the parts that go with it, and this part is sold separately.
Old 10th June 2012
New Member
Thanks! I just made the purchase. I had also found it at a dealer in Georgia, where the parts manager told me about the new U.S. company that will be up and running this week to start the flow of parts from Sweden to the U.S. again. That would take at least another 10 days to 2 weeks and it was about $20.00 more.
I really appreciate the info and the assist.
Good luck to you as well!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Replacing shifter(auto) "blind"/"Jalousie" microq 9-5 Workshop 3 24th October 2010 12:38 PM
Replacing an ES2 with an ES3/4-7 Vision i.T Services 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Tuning/Modifications - ALL ENGINES 0 19th August 2010 11:34 AM
Replacing Tensioner and Pulley on 9.5 when replacing Timing Belt Silvermb 9-5 Workshop 7 27th November 2007 02:12 PM
Replacing the oil pan largo77 NG900 & OG9-3 Workshop 8 30th August 2005 07:06 AM
Replacing a tie rod end the Cheese C900 Workshop 10 6th June 2005 01:00 AM
