Clunking sound when turning - SaabCentral Forums
Old 23rd March 2012
pyrosaab pyrosaab is offline
My Saabs: 2004 9-3 aero
Question Clunking sound when turning
I'm getting a "clunk-clunk-clunk" (or a knock-knock-knock) sound coming from the front of my car when I turn right/left moving at slow speeds. It even happens when I turn in reverse.
I've been searching the forum and so far I'm not finding any clear answers.
Has anyone else experienced this or have any ideas?
Old 23rd March 2012
datonyb datonyb is offline
My Saabs: 93 aero 2004
cv joint
constant velocity joint
not really a saab problem just any front wheel drive
Old 23rd March 2012
Vision i.T Services's Avatar
Vision i.T Services Vision i.T Services is offline
My Saabs: 9³SS Aero BSR Stage 3
Could be the CV joint, but I doubt it.
It's more likely worn bushes (drop link or sway bar). Put the car on a ramp and check if there's any play in the suspension components. I've just replaced my drop links and sway bar bushes (65,000 miles) and it cost me £60 in parts.
You can fit drop links yourself with just a jack (and stands) and an 18mm socket. The sway bar bushes are slightly more difficult, as the subframe has to be dropped.
A good mechanic should be able to diagnose it quite quickly.
Old 23rd March 2012
mawingo mawingo is offline
My Saabs: 07 93 Aero SC
Possible Strut mount. My left one went out last summer. Easy fix, clunking went away.
Old 23rd March 2012
morinc1's Avatar
morinc1 morinc1 is offline
My Saabs: 2007 9-3 2.0T
The symptoms you describe appear to be a classic example of failing CV joints.
Old 23rd March 2012
Smile
Thanks for the replies, If it's my cv joints would I be better of just replacing my front axles?
Is there a DIY on this site for doing that?
Old 23rd March 2012
to cure cv joint cheapest way is to do just the joint
it will be the outer cv's as the inners would make noise all the time not just stressed on full steering lock
changing axle???
it dosnt technically have one mate
did you mean change the entire front driveshaft?
(this is the part that contains the cv joint)
Old 23rd March 2012
aerojon's Avatar
aerojon aerojon is offline
it could also be that the strut bearings are siezing up.
Is still running factory oe coils with Hirsch tune..
Old 23rd March 2012
@ datonyb right, I was thinking of my accord :/
Does anyone have the part numbers for the outer cv's? Is there a DIY on the site for this?
I'm also noticing a "clicking" sound coming from the front when I hit the breaks any ideas there? It only makes the sound once and happens intermittently. This car sure likes to make noise...
I've been reading more about the strut bearings, etc, the symptoms admittedly sound similar.
I'm going to take a look under the car and see if anything stands out with the cv joints first.
Old 24th March 2012
chris_de_ze's Avatar
chris_de_ze chris_de_ze is offline
My Saabs: '03 9-3SS Aero, I4, MT6, Maptun Stage 1
A friend had the same clunking sound when turning the steering wheel even when the car was at still.
The problem was due to worn strut top mounts (bearing+base).
Open the engine bonnet, have someone turning end-to-end the steering wheel, and listen carefully if there is any sound coming from the strut top mounts. It is very easy to spot it.
founding member of the Greek Saab Forum
Old 24th March 2012
Wynnston Wynnston is offline
My Saabs: Saab 93
Does it get worse with more throttle?
If yes. Most likely CV's.
It could also be a cracked spring, these cars are well known for springs cracking.
Old 24th March 2012
rhymesayers90 rhymesayers90 is offline
My Saabs: 2003 9-3 2.0t linear
Garage
im havin the same problem, i havent had it professionally looked at yet but i found no play in any of my suspension components so im assuming its my cv axle. i hate assuming though but as i cant afford a proper mechanic im goin with that first
Old 25th March 2012
I can't say it gets worse with more throttle. It only happens at slow speeds turning hard forward or reverse. (Starting to think it is the strut mounts as suggested above).
Funny thing is I went to troubleshoot yesterday and tried turning sharp slowly and now I can't hear the damn sound! Confused at best now!
Old 25th March 2012
you should hear a cv with wheel jacked up full lock and turn by hand
after doing my brakes today i hope its your strut bearing mate as its a doddle to remove struts (cant believe how simple the design is)
two bolts on lower strut and the nut on top mount !
even considering grabbing a set of eibachs now as simples to change springs on these cars
Old 26th March 2012
rochesta rochesta is offline
My Saabs: 2004 Saab 9-3 linear
Just had this exact problem, the clunk clunk, the slow speeds, everything. Strut bearing cap. Had them replaced ACDelco and had Monroe struts put in (why not when the whole thing is unbuttoned anyways and the original struts had 90k on them). Parts and labor ran about 400 total.
Old 3rd April 2012
Question
Finally got around to checking this out today. I jacked the car up nd turned the wheels. No sounds from the cv's but I believe you guys are correct, thre was a definite sound coming from the top of the struts!
Just looking online, are these the parts I'm looking for?
http://eeuroparts.com/Main/PartDetail.aspx?id=13270705 (out of stock )
http://eeuroparts.com/Main/PartDetail.aspx?id=13188763
http://eeuroparts.com/Main/PartDetail.aspx?id=13178464
Yeah, I might do the springs too, does anyone have any links for anything decent online?
Old 3rd April 2012
I ordered from these guys last summer.
http://www.autopartswarehouse.com/sk...gs+Best+Seller
Old 3rd April 2012
slosaab's Avatar
slosaab slosaab is offline
My Saabs: 2004 9-3 arc sedan
Garage
I ordered strut bearings from advance auto parts 2 weeks ago. Also Napa can get them as well.
Old 3rd April 2012
SaabMick's Avatar
SaabMick SaabMick is offline
My Saabs: 09 9-3SC Aero XWD 6MT - Stage 5
Garage
This is just the strut mount, correct? aka does it include the strut mount bearing?
1999 Saab 9-3 SE HOT - gone
2006 Saab 9-3 2.0T - gone
2006 Saab 9-3 Aero SportCombi - "the beast" JZW Tuned Stage 5 - RIP
2009 Saab 9-3SC Aero XWD 6MT - JZW Stage 5
Old 3rd April 2012
Yes, My clunking went away with just the mount. They have a bearing available as well.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Clunking noise when turning akamal C900 Workshop 9 17th June 2013 04:27 PM
Clunking sound unspoken 9-5 Workshop 22 22nd June 2011 03:10 PM
Front End Clunking When Turning Wheel kjd 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 21 6th June 2011 06:41 PM
knocking clunking noise when braking & turning from front wheel... zende NG900 & OG9-3 Workshop 4 18th October 2010 08:11 PM
Clunking noise when turning left NineFiveAero 9-5 Workshop 15 31st May 2007 03:31 PM
