Submission For APRIL'S SAAB OF THE MONTH - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Of The Month > SOTM Submissions & Voting
SOTM Submissions & Voting Submit your car for voting & vote for your favorite Saab.
Old 20-03-12
grkguy89's Avatar
grkguy89 grkguy89 is offline
Moderator
My Saabs: 97 900SE, JZW Stage HX35 w/m injection
Garage
Default Submission For APRIL'S SAAB OF THE MONTH
The rules are posted in the sticky in the main section for SOTM Submission & Voting
(here's the link just in case; SOTM, Rules and other need to knows.)
Open for entrants!!!! Will close on the 26th
follow this template
***EXAMPLE***
The Silver Sled (1988 900 Aero)
Specifications
Engine
Brand new Saab B202 2.0 Litre 16 valve crate engine (installed November 2010)
Rebuilt Bosch distributor
Stock Bosch electronic ignition
SPG9 AID (Advance Ignition Diaphragm) with timing at 20˚BTDC
Bougnicord spark plug leads
NGK BCP7EV plugs
Aquamist 1S water Injection using 0.9mm injector
Aquamist DDD (digital dash display) for water injection output
Crank case ventilation catch-can
Exhaust
2.5 inch from cat converter back with hi-flow racing cat
4 inch chrome semi-oval tip
Hi-flow dynomax stainless steel muffler and rear resonator
3 inch JSP stainless steel split down pipe off turbo to cat
Turbo
Mitsubishi TE-05 16G: with 16G compressor wheel with 10˚ clipped vanes, upgraded thrust and is rated as a 300HP turbo
Wastegate running 7psi base boost
Stage 2.5 SPG9 APC running to 18psi boost
Jak Stoll Performance Talon high-flow side mount intercooler
8 inch Davies Craig thermo pull fan mounted on reverse side of intercooler with manual switch inside cabin
Saab C900 1990+ aluminium turbo intercooler ducts
Stratmosphere Forge bypass valve
K&N filtercharger
Plastic intercooler top air dam
Fuel System
Bosch 3.0 BAR fuel pressure regulator
Trionic 5 34lb injectors
Jak Stoll Performance Stage 2 ECU chip
Fuel pressure gauge situated in-line on fuel rail
Suspension
Stock Saab Aero springs and shocks
Stock Saab Aero road handling kit including front and rear sway bars
Polyair inflatable air bags inside rear springs
Wheels & Tyres
16" x 6.5" Saab Super Aero rims
Goodyear Revspec Ducaro 205/50/16 tyres
Other
Stock Saab Aero factory whaletail
Saab Aero vent covers (factory colour coded silver to match duco)
AutoMeter 30"hg to 30psi boost guage
AutoMeter air/fuel ratio guage
Saab factory rear decor panel
SaabSavior short shifter
Saab Momo leather steering wheel
3.5mm blue silicon vacuum hose
Saab Aero original Alpine surround sound 5 speaker stereo
Aero kit factory colour coded silver to match duco
Output
Estimated 190kW (250hp) at front wheels (need to do another dyno once new crate engine is run in)
Christos (VA saab meet pm me?) JZW Tuned Stage 7
http://www.eurocarswmbg.com/
Old 20-03-12
pacotaco's Avatar
pacotaco pacotaco is offline
My Saabs: 04 93 arc espresso black
swedspd (2004 saab 9-3)
engine
custom intake
intercooler
hard piping
synapse synchronic BOV
atp block off plate
higher heat range iridium plugs
JZW stage 3
exhaust
3in downpipe
3in modified jt exhaust
fully vbanded for cat and test pipe
stock exhaust accepted
turbo
stock 14t
ported turbin
suspension/brakes
d2 coilovers
front sway bar removed
custom alignment
brembos brakes
ceramic brake pads
custom made stainless steel lines
ATE super blue fluid
brake ducting
wheels
17x7 aero dual spokes
225/45/17 continental extreme contact DW's
17x7.5 aero 5 spokes
225/45/17 continental extreme contact DWS/ extreme contacts
other
GS billet brake cap
harness bar
Takata harness
stripped interior
prosport digital oil pressure
prosport digital boost pressure
custom made 14point7 afr gauge
aux port
aero front lip
fog lights
boston acoustic speakers
8k hids
i <3 backroads.
i rule your internet.
Old 22-03-12
siffonen siffonen is offline
My Saabs: saab 9-5 2.3t 1998 manual
"Whitey" (1998 Saab 9-5 )
Specifications
Mileage
110k and counting
Engine
B235 with Wössner forged pistons
Garrett GT3071R .86
630cc Injector
Maptun Individual stage
T5 camshafts
Forge bypass valve
Custom air intake
Exhaust
BSR 3" dp + 2.5" Cat-back
Fuel System
Walbro 255 LPH Fuel Pump
Suspension
D2-Coilover kit
Wheels/Tires/Brakes
Zero ZE05 Black 19"
235/35/19 Falken FK452
National Performance grooved front discs (Ksport 356mm coming)
02 Aero 300mm Ventilated rear dics
Interior
Stock except boost gauge
Exterior
Realcar 02-> front bumper
Clear side indicators
Black emblems
Body trims painted to bodycolor
In Car Entertainment
- Alpine CDA-117Ri
- Alpine PXA-H100
- Rainbow SAX 265.20
- Pioneer ts-a6911
- Pioneer ts-w3004spl
- Carpower d-rex D-Rex/1202 + Carpower hpb-1002
Output
365whp & 465nm
Old 22-03-12
pacotaco's Avatar
I dont think you can list something thats not on or ready for the car.
i <3 backroads.
Old 23-03-12
Sorry for that, i did notice that after i sent that
Old 25-03-12
MR.SAAB's Avatar
MR.SAAB MR.SAAB is offline
My Saabs: TD04 swapped stg4 9-3SS
"Claire" 2005 9-3
Specifications
Engine
stage 3 JZW tune
CX racing front mount
Aero fuel injectors
BSR intake
Custom Block off plate
Synapse Synchronic BOV
Exhaust
JT 3 inch Catless turbo back
Turbo
Garret GT2525
Fuel System
Aero/Arc injectors (upgrade from linear)
Suspension
KAW racing springs 45/55mm drop from an opel vectra
Adjustable Koni Yellow struts and shocks
Wheels & Tires
17" sparco Assetto Garas
Good Year Eagle GT all seasons
Other
State of 9 carbon pillars
Aero Front lip
Sprintbooster
Genuine saab oil and brake cap
Prosport boost gauge (evo edition)
Prosport Oil Pressure gauge
3000K (yellow) fog lights
7000K (white) head lights
Infiniti Kappa Speakers all around
Aero ICM2 radio
Ultra Gauge
carbon wrap on orange reflectors
city light delete
Output
250 Horsepower
280 ft/lbs
jzw stage 1 tune, Bsr optiflow intake, SPRINT BOOSTER for auto tranny, led headlight strip, tail light tint, prosport digital boost gauge, infinity speakers all around
Old 27-03-12
saabhutter's Avatar
saabhutter saabhutter is offline
My Saabs: 2011 Volvo C30 R Design, 1992 900T 'Vert
Garage
Nice entries so far guys, I'm having a hard time deciding who to vote for!
Old 28-03-12
pacotaco's Avatar
vote for me because i have ice block tails
i <3 backroads.
Old 10-04-12
rev_pat rev_pat is offline
My Saabs: 1978 Saab 99 Turbo, 2001 SE & 1999 Conv.
Default 1978 Saab 99 Turbo
1978 Saab 99 Turbo. Seriously, all stock, shall I say more?
Old 10-04-12
Matt1488's Avatar
Matt1488 Matt1488 is offline
My Saabs: 9³ It go PSHHHH at stage 3
Garage
ummm aprils SOTM has been picked
If you're not outta control, then you're not in control.
Old 12-04-12
"Open for entrants!!!! Will close on the 26th."
I thought this was April 26th not March. My fault. Oh well, I tried to snipe a win.
Old 12-04-12
Matt1488's Avatar
Garage
Nooooo, but hey try for June. end of april should be the entry for it.
Old 12-04-12
Default April winner
Will do. I have another pic I want to enter..
Old 15-04-12
thestranger66 thestranger66 is offline
My Saabs: 1999 LB Viggen coupe stg 3+
Default 1999 Viggen Coupe
1999 Lightning Blue Viggen Coupe
Power:
GS open air intake
GS 3in Downpipe w/race cat
BSR 2.5 in exhaust
ETS intercooler
Stg 3+ custom tune
3.5 bar fuel regulator
Handling:
New control arms
22mm anti sway bar
GS Steering rack clamp and brace
Poly Bushings all around
Koni sport suspension kit
Camber alignment shims
9-5 aero rear brakes
Hawk HPS pads all around
Other:
Sony Xplod headunit
Sony Xplod 700w amp
Alpine/Kenwood Speakers
Undecipherable SID
Recently repainted the front end
139k miles
~300+ bhp 330 ft/lbs.
Old 15-04-12
pacotaco's Avatar
the polls are closed i won.
i <3 backroads.
Old 18-04-12
gtp's Avatar
gtp gtp is offline
My Saabs: 07 9³ 2.0T BSR - Sold
One of the best Saabs ever made, possibly the best
Similar Threads
Submission For MARCH'S SAAB OF THE MONTH grkguy89 SOTM Submissions & Voting 4 06-03-12 09:28 PM
Submission For FEBRUARY'S SAAB OF THE MONTH grkguy89 SOTM Submissions & Voting 6 23-02-12 10:29 PM
Submission for DECEMBER'S Saab Of The Month grkguy89 SOTM Submissions & Voting 10 14-12-11 09:55 AM
Submission for NOVEMBER'S Saab Of The Month grkguy89 SOTM Submissions & Voting 15 15-11-11 03:21 PM
Submission for OCTOBER'S Saab Of The Month grkguy89 SOTM Submissions & Voting 15 27-09-11 12:02 AM
