Evap code P1444 - SaabCentral Forums
Old 16-03-12
SAABotaged900S's Avatar
SAABotaged900S SAABotaged900S is offline
My Saabs: 86 9000 Turbo
Default Evap code P1444
I bought an 02 9-3 SE, can't register it until it passes New York state inspection, but MIL is on. Code is P1444 "Canister close valve circuit open/short to ground" nothing at work has anything on it, and I can't even find a proper wiring diagram to check the ground. When the light is cleared it comes back within minutes. Anyone else run into this issue? Any help is appreciated!
Tim
2002 Saab 9-3 SE
2000 Nissan Frontier XE 218k miles
Old 16-03-12
earthworm's Avatar
Saab Sage!
I hate these codes, the language is nearly incomprehensible....
As a guess, check the operation of the purge valve and , of course. all the vacuum lines..
http://www.saabcentral.com/forums/sh...d.php?t=223790
hope this helps
Also do the full battery and charging system service....If this has not been done recently.
The earthworm
'96 900S, Automatic
Old 16-03-12
Thanks, I read somewhere else too that the purge valve can get stuck closed and cause weird codes. My boss at work doesn't think so and says the language of the code seems like an electrical fault for a solenoid. Maybe we'll warm the car up and see if we hear the valve click and operate, if it doesn't I'll try cleaning it. The battery was replaced in January 2012.
Tim
2002 Saab 9-3 SE
Old 4 Weeks Ago
saabalfa saabalfa is offline
New Member
My Saabs: 2 9-5s, '84 900, '78 99EMS
Default P1444 fix help
I have a P1444 code on my Saab 9-5.
I found the Youtube video https://www.youtube.com/watch?v=GWf60guK8gk
very helpful in understanding how to fix the problem with my evap purge valve electrical problem.
Old 4 Weeks Ago
YamahaDT YamahaDT is offline
My Saabs: 01 Saab 9-3
Might not be your situation but when I had the code I found a squirrel or other creature chewed up the wires running to the valve. Once I repaired them the code went away. That was 4 years ago now.
Old 4 Weeks Ago
BobSaabit BobSaabit is offline
My Saabs: '97 NG900 'vert; '03 OG 9-3 'vert
According to the WIS the actual issue is that the ECU didn't get a signal above 2 volts for over 1 second. So, either the wiring to the valve is damaged or the valve is not working properly.
Similar Threads
P1444 OBD 2 code Manufacturer specific saab95.99 Saab 9-5 Workshop 7 25-04-12 11:43 PM
evap code and throttle code 039-3arc Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 0 20-10-11 02:01 AM
1999 9-3 Emissions Code P0455 Evap Leak foothill Saab 9-3 & NG900 Workshop 32 09-09-11 10:25 PM
Code p1444 & stumbling after gear shift metrognome Saab 9-5 Workshop 2 16-05-10 07:38 PM
Harsh jerking, rattling, maybe misfire? But throws EVAP code... Tailspin Saab 9-3 & NG900 Workshop 6 19-02-09 09:44 AM
