Genuine saab engine mount question - SaabCentral Forums
Old 11-03-12
selebrin selebrin is offline
My Saabs: '96 900 Turbo
Default Genuine saab engine mount question
do i have to run a genuine saab passenger side engine mount with a matching transmission mount or can i just run a genuine saab engine mount with a stock transmission mount? i have a manual.
thanks!
Old 11-03-12
Pontius DIO's Avatar
Pontius DIO Pontius DIO is offline
My Saabs: 99' 9-3 SE GT2560 62 Trim Comp.
You can just run the GS rear mount. If the other mounts are original, they are probably bad as well and will need replaced eventually. Both the trans mount and the passenger side mount's rubber crack rather easily.
I'm running a rear GS "Sport" mount with the soft insert. Only thing I'd suggest is always back up gently as they don't seem to like being put into reverse. The top ring with the 2 tabs that bolt the insert in, is rather weak. Mine was actually bowing and wasn't entirely flush with the base. The insert was pressing up on it (they sent it to me like that with the "Hard" insert, soft insert did the same thing). It's an OK mount, but definitely double-check that it's seated correctly. Only fixes would be to weld a thicker ring to the GS unit's, or weld 2 more tabs so you can add more bolts to tighten it better. Design flaw on their part.
Old 11-03-12
i'm replacing just the passenger side engine mount. (at least for now) thanks!
Similar Threads
Genuine Saab V6 Engine Mount Inserts Install ERP Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning 21 09-12-11 04:37 PM
Question about Engine Mount ?? Toeblacke Saab 9-3 & NG900 Workshop 4 22-05-11 11:07 PM
Genuine Saab Poly Trans Mount Maine Saab 9-5 Workshop 26 27-10-10 09:54 AM
For Sale: Genuine Saab Sport Trans. Mount AUTO! zachc Parts for Sale/Wanted - North America 12 09-10-09 11:23 PM
last engine mount question screamingreen97 Saab 9000 Workshop 11 17-03-06 03:03 PM
