CIM module?? HELP- PLEASE - SaabCentral Forums
Old 8th March 2012
krbf krbf is offline
New Member
My Saabs: 2004 Saab 9-3
Exclamation CIM module?? HELP- PLEASE
I am new to this forums and REALLY NEED HELP. Bought my teenager a 2004 Saab 9-3. Developed a clicking noise when turning steering wheel. Dealer said needed a new CIM module which are hard to find. Got one, but now they say they need to know if it is sim tech 71.6 or T81PSG16. They say they can't program new CIM without this information. Everyone I have asked said there is just one part- part number 12805196.
I really need some help because car is really not drivable at this point. Everything works, but clicking is constant now, and they say airbags could go bad.
Does anyone have any information that could help me.
Thanks for any help or suggestions.
Old 8th March 2012
Saabless's Avatar
Saabless Saabless is offline
My Saabs: Saabless
If you go on youtube and search "airbag removal saab 9-3" there is a company that deals in CIMs for a fraction of the price @ dealer. You remove your CIM via removing airbag hence the video, and send it to them then they send you a new one programmed iirc. Never used them for thst just used the video to remove my airbag, but i filed it in my brain under "just in case my CIM fails" file. Hope that helps. Good luck!
Edit: i just went on Youtube theyre called Clearcom Technologies...
Cheers
Sent from my myTouch_4G_Slide using AutoGuide.com App
Old 9th March 2012
dzlsabe dzlsabe is offline
My Saabs: 06 93 TiD Combi, #2 TiD Combi Running
Always get a second opinion. Dealers know of only one way to fix any problem and its usually the most new parts intensive expensive.
You can exchange the noisy clockspring section in your original with the one from the replacement and not have to go thru reprogramming a new CIM. The only reason a CIM really needs be changed is lost keys. Wiper, turn switches, clockspring and steering angle sensor can all be removed and replaced fairly easily.
Only US diesel?? 03 93 Cosmic Blue
Also Black 06 93 Combi, White 89 900TCV
Old 9th March 2012
New Member
Default Cim
The problem is I have already purchased the CIM module, and now the dealer says he doesn't know what version it is in order to program. Says he needs to know if it is a simtec 71.6 or a T81PSG16. I have talked to lots of other mechanics that say it should just be able to be programed. Is there a version since it is a 2004? Any one know anything about either of these codes??
Thanks!!!
Old 9th March 2012
JordanEuroLover JordanEuroLover is offline
My Saabs: 2004 9-3 Linear, black, stock (for now)
Thanks!!!
i too have an 04 linear and just replaced my CIM module last month. Got it from goldwingsaab.com (located in NY) GREAT guys there and they really know their stuff! they found me a new CIM with 2 keys and put a one year warranty on it. Give them a call and see what they say! best of luck!
1 (800) SAAB-137 or (315) 668-5800
Fax: (315) 668-5805
Goldwing Saab
Rt. 11
Hastings, NY 13076
Old 10th March 2012
Saabless's Avatar
My Saabs: Saabless
Thanks!!!
Cant you return it? I mean its unprogrammed....maybe return it and call around and get the right one...
Old 10th March 2012
chris_de_ze's Avatar
chris_de_ze chris_de_ze is offline
My Saabs: '03 9-3SS Aero, I4, MT6, Maptun Stage 1
Thanks!!!
SIMTEC is the Siemens engine management system for the Saab 9-3ss 1.8i (1800cc non turbo).
Your car is definitely equipped with a Saab T8 engine management system (2.0 turbo).
founding member of the Greek Saab Forum
Old 10th March 2012
stolo stolo is offline
My Saabs: Saab 93 1.8t Vector
I do have a problem with my ESP. And they said I have to buy a new CIM, they also said that the steering angle sensor is the problem why my ESP turns off, and you say I could only switch something out ow a older CIM without programing and new keys?
Old 10th March 2012
If you get a used CIM is needs to come with at least one key from the car it was married too, then it can be used on your car. I have not heard of anyone not reprogramming their existing keys with a replacement CIM. hope this helps!
Old 10th March 2012
Yes I understand but I just want to find out if I only need to change the angle sensor if thats possible without changing the whole CIM to much money I thing
Old 10th March 2012
[QUOTE=stolo;2159060]Yes I understand but I just want to find out if I only need to change the angle sensor if thats possible without changing the whole CIM to much money I thing[/QUO
oh i see, and yes they are very expensive
Old 10th March 2012
Yes only the steering angle sensor can be changed. Also the turn and wiper switches as well as the clockspring.
Old 10th March 2012
and all this is inside the CIM ? Do I have to look for the same CIM as I have in my car or ?
Old 19th March 2012
New Member
Default CIM- Now steering column
Now the dealer says it wasn't the CIM, but needs a new steering column. They got one from salvage yard. Would you let your teen drive a car with a salvaged steering column- and mechanics that don't seem to know what they are doing???
Old 30th October 2012
pickawinner pickawinner is offline
My Saabs: 1994 Saab 900S, 2001 9-3 SE, 2003 9-3
A steering column from a salvaged car is fine. If its from a water damage salvage I probably wouldn't buy it, but other than that, there shouldn't be a problem.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Wanted: ABS module '00 9-3 + mirror, AC module mountain_tamer82 Parts for Sale/Wanted - North America 3 11th March 2012 07:52 PM
ECM (Electronic Control Module) vs PCM (Powertain Control Module) phaco 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 4 2nd March 2012 05:46 PM
ABS Module SaabDozer 9-5 Workshop 3 2nd December 2010 07:16 PM
abs module bethpoll23 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 0 2nd November 2010 07:29 PM
Where is the ABS module???? Renaemo C900 Workshop 8 25th February 2007 01:29 PM
