OBD-II codes - SaabCentral Forums
Old 03-03-12
valgov3001 valgov3001 is offline
New Member
My Saabs: 2002 Saab 9-5
Default OBD-II codes
So I had some OBD codes on my car recently and I looked them up. I had trouble finding the Saab specific codes, so I just used GM codes, as my 9-5 was 2002(Sedan Linear), well within the GM era. However, I found a site, greatly due to the help of this site, that gives Saab specific explanations for codes, and they make a lot more sense together now. However, I still would like a little advice on how to proceed. My codes are as follows:
P0113-Intake Air Temperature Sensor 1 Circuit High Input
P1107-Charge Air Absolute Pressure Sensor Circuit Short To Ground/Open
P1110- Charge Air Bypass Valve - Performance Problems
P1334- Combustion Detection Cylinder 3/4 Open Circuit / Short to B+.
In response to some noise I was hearing under boost, I had already changed the diverter valve, which is what I assume it's referring to in P1110. As for P1334, when I first looked it up under GM codes, it said something about the DIC, so I still think there's a chance that could be the issue here. My questions are:
Where is the Intake Air Temperature Sensor on my car so I can clean it with some mass flow sensor cleaner?
And Where is the Charge Air Absolute Pressure Sensor.
Also, I wanted to share the site where I got these Saab specific codes as they were invaluable to me:
http://iequus.com/Dtc.
Thank you in advance!
Old 28-05-12
SpongeBob's Avatar
SpongeBob SpongeBob is offline
My Saabs: 2001 9-3 Convert. 2000 9-5 Aero
Great link!
Tags
charged air sensor, iat, intake air temperature, obd saab definitions, trouble codes
Similar Threads
air box codes? ...what do i need to do? xjasonblackx Saab 9-5 Workshop 5 14-03-11 09:26 AM
is these codes mean right?? Ryo Saab 9-5 Workshop 11 21-07-08 07:26 PM
CEL Codes mzvi3 Saab 9-5 Workshop 4 29-01-08 08:57 PM
OBD II Codes MATT C Saab 9-3 & NG900 Workshop 1 15-12-07 09:52 PM
how to get codes douglas Saab 9-3 & NG900 Performance, Mods & Tuning 2 29-10-07 03:50 AM
