Welch / Core / Freeze plugs - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 1st March 2012
king_joolian king_joolian is offline
My Saabs: '99 9-5 HOT, '88 900 Aero, '93 9000 CSE
Default Welch / Core / Freeze plugs
Q: Does anyone know what size the welch plugs are in a 1993 9000 CSE with a red engine block?
All the info I can find doesnt relate to this car.
A: 36mm, there are 6 of them in the block.
Old 1st March 2012
sp53 sp53 is offline
My Saabs: 1989 saab 9000 1992 9000 1993 9000
I am not sure either, but if you want something not stock, but that will work. You can put in those rubber ones that you tighten done to expand.
Old 1st March 2012
chengny's Avatar
chengny chengny is offline
My Saabs: 96 9K CSE, 97 9K CS, 96 9K CS, 94 9K CSE
More Images
List Price: $9.33
Our Price: $7.91
You Save: $1.42
Quantity:
DORMAN EXPANSION PLUG, STEEL -- Cup type; 1.1 in. diameter, 0.34 in. H, 1.1 in. closed end diameter, 1.12 in. open end diameter; A high quality, direct fit OE replacement expansion plug; With lifetime Dorman limited warranty. Fit Note:CarWarranty:Lifetime Dorman limited warrantyQuantity Sold:Sold individually
Fits the following 1986-1998 Saab 9000 submodels:
  • 1998-1998: CSE Turbo; 4 Cyl 2.3L; "GAS, FI, B234R, Turbocharged, VIN R"
  • 1993-1998: CSE Turbo; 4 Cyl 2.3L; "Gas, FI, B234L, Turbocharged, VIN M"
  • 1995-1997: CS; 4 Cyl 2.3L; "GAS, FI, B234E, Turbocharged, VIN U"
  • 1993-1997: Aero; 4 Cyl 2.3L; "GAS, FI, B234R, Turbocharged, VIN R"
  • 1993-1997: Aero; 4 Cyl 2.3L; "Gas, FI, B234L, Turbocharged, VIN M"
  • 1993-1994: CDE Turbo; 4 Cyl 2.3L; "Gas, FI, B234L, Turbocharged, VIN M"
  • 1993-1994: CDE; 4 Cyl 2.3L; "GAS, FI, B234I, Naturally Aspirated, VIN B"
  • 1993-1994: CS Turbo; 4 Cyl 2.3L; "Gas, FI, B234L, Turbocharged, VIN M"
  • 1993-1994: CS; 4 Cyl 2.3L; "GAS, FI, B234I, Naturally Aspirated, VIN B"
  • 1993-1994: CSE; 4 Cyl 2.3L; "GAS, FI, B234I, Naturally Aspirated, VIN B"
  • 1991-1994: CD Turbo; 4 Cyl 2.3L; "Gas, FI, B234L, Turbocharged, VIN M"
  • 1990-1993: CD; 4 Cyl 2.3L; "GAS, FI, B234I, Naturally Aspirated, VIN B"
  • 1992-1992: CD Griffin Edition; 4 Cyl 2.3L; "Gas, FI, B234L, Turbocharged, VIN M"
  • 1991-1992: Base; 4 Cyl 2.3L; "GAS, FI, B234I, Naturally Aspirated, VIN B"
  • 1991-1992: Turbo; 4 Cyl 2.3L; "Gas, FI, B234L, Turbocharged, VIN M"
  • 1990-1992: S; 4 Cyl 2.3L; "GAS, FI, B234I, Naturally Aspirated, VIN B"
  • 1989-1990: CD; 4 Cyl 2.0L; "Gas, FI, B202L, Turbocharged, VIN L"
  • 1987-1990: S; 4 Cyl 2.0L; "GAS, FI, B202I, Naturally Aspirated, VIN D"
  • 1986-1990: Turbo; 4 Cyl 2.0L; "Gas, FI, B202L, Turbocharged, VIN L"
  • 1989-1989: Base; 4 Cyl 2.0L; "Gas, FI, B202L, Turbocharged, VIN L"
Sorry, didn't think it was going to be so big.
Old 1st March 2012
Superaero Superaero is offline
My Saabs: 1997 Aero manual
Something isn't adding up. 1 inch is 25.4 mm. 1.12 inch is less than 29 mm. The measurements reported are inconsistent with the measurements on this parts list. Something is not right.
Old 1st March 2012
chengny's Avatar
Dorman Freeze Plug List Price: $9.33
Our Price: $7.91
You Save: $1.42
Dorman Freeze Plug List Price: $8.81
Yeah, I noticed that - I think they switched the specs on these two plugs. It's Dorman...
The one on the bottom is probably what he needs. That one is 1.64/1.65 OD. 41mm = 1.62''. Makes for a nice interference fit.
Old 2nd March 2012
The right size, by process of elimination is 36mm, they jam in perfectly, and there are 6 of them, 3 in the front, 3 in the back (+ one other plug type thing),
35mm is too small, 1-1/2" (38mm) is too big, 1-5/8" (41mm-ish) is waaay too big.
Mystery solved
Old 2nd March 2012
There may be one block plug that is designed for easy removal. If so then this will be for the optional engine block coolant heater required for climates like the one where I live. At minus 35C it is necessary to use a mains type plug in heater to heat the coolant jacket, if one still uses conventional oil. With synthetic oil you can still start a frozen SAAB down to about minus 40C. At that point the gasoline starts to wet out on the plugs if the engine isn't heated. In NZ or OZ this is not a relevant consideration.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Welsh/core/freeze plugs frankgue C900 Workshop 5 9th November 2011 06:26 AM
Welch plugs in block + head - what size? DrewBedelph C900 Workshop 33 24th September 2011 04:31 AM
Core, freeze or welsh plugs nats C900 Workshop 4 17th June 2008 10:28 AM
core / freeze plugs Dninty9 C900 Workshop 1 22nd July 2003 01:41 PM
Freeze plugs / core plugs Dninty9 C900 Workshop 1 13th June 2003 04:06 PM
