Steering column and wheel vibration - SaabCentral Forums
Old 16-02-12
Mike Brennan's Avatar
Mike Brennan Mike Brennan is offline
My Saabs: (4) 2 01 95's; an 08 95 & a 09 93
Default Steering column and wheel vibration
01 9 5 Aero 2.3 135.000 miles.
I know the previous owner installed a motor mount, transmission mount, torque rod, transmission mount, belt and all pulleys, and a vibration damper. At this time the steering column and wheel has a distinct and rapid vibration at idle in gear and not in neutral. I do not feel the vibration on the shift lever or anywhere else on the car. I believe this be motor mount related. can anyone tell me which mount is the culprit?
I understand if the engine under load with the foot on the brake the motor will lift up if the mount under the battery is bad and if the engine sags the upper right is bad. This according to a prior post
Old 16-02-12
rayodunne rayodunne is offline
My Saabs: 2000 9-5 Wagon 2.3t 5spd
Subframe bushings might be worn out
2000 9-5 2.3t TD04, Aero ECU, Aero Rear sway bar, Viggen 17" Rims.
Similar Threads
9-3 Steering wheel/column movement Sweedishmeatball Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 6 30-09-11 02:18 PM
Telescoping Steering Wheel Column - help! a total slaab Classic Saab 900 Workshop 15 15-08-08 08:48 PM
Steering Column Vibration! ntmarsh Saab 9-3 & NG900 Workshop 3 30-12-07 10:25 AM
stuck steering wheel column!!! rktek Saab 9-3 & NG900 Workshop 9 13-06-06 04:51 PM
Can the steering wheel be moved on the steering column? tonyw Classic Saab 900 Workshop 4 26-05-06 05:02 PM
