Saab 93 - 2006 Convertible (Airbag malfunction. Contact Service) - SaabCentral Forums
Old 16th February 2012
adams adams is offline
My Saabs: Saab 9-3 Vector - convertible 2006
Default Saab 93 - 2006 Convertible (Airbag malfunction. Contact Service)
Hello guys.
I've got 2-3 things I would like to ask and maybe somebody can give me an advise. Last Sunday morning I had the warning message 'Airbag malfunction Contact service' appearing on my screen. This came minutes after the starting up check which showed everything was ok. I've driven on the motorway for 100 Km and kept coming up several times. When switching off the car and restarting it came up once and then no more. It's been 3 days now with no warning coming up (even though I also driven on the motorway for an hour) and this morning when starting the car this message came up again repeatedly. Switching off and restarting and driving for a few kilometers more it didn't appear.
I read somewhere that airbag might be linked to the seats position (?) That Sunday morning I got the warning for the first time, we moved forward one of the seats so that a friend seats at the back. Maybe we touched something we shouldn't? :-) Can the airbag system be so sensitive though?
Has anybody got a clue what this might be? I read the manual and it's written somewhere that in the event you get this message you have to contact service immediately and that airbag can erroneously open (?) Is there any risk it opens out of the blue while driving? Maybe my questions sound stupid but I wanted to share them with you. Is there something I can check?
Thanks a lot n advance.
jcm jcm is offline
My Saabs: 08 93, 07 93, 03 93, 01/95
Schedule a 1/2 hour Tech 2 service and ask them to pinpoint the sensor that is talking. I had one airbag sensor that was at issue. Replacement cured event.
Transformer Transformer is offline
My Saabs: 2003 9-3 2.0T
brave man, had airbag warning light on my lincoln navigator turned out to be a common fault. While getting mine checked out a lady with a neck brace on was their getting hers put back in with the same fault...
SO.. Either take it to have it checked out by a resonable mechanic, or get a neck brace lol
Old 17th February 2012
smallt smallt is offline
My Saabs: 2003 Saab 9-3 2.0t
The air bag sensor is located under the passenger seat. there is a black box under the seat and it might of disconnected. I got that error when i was trying to remove onstar. So check under the passenger seat to make sure everythings connected.
Old 12th September 2013
Blue_Steel's Avatar
Blue_Steel Blue_Steel is offline
My Saabs: 2003 linear 9-3 Turbo" 2006 Saab Vert
Garage
Wink
same thing happened to me i have a 2006 saab 9-3 aero convertible... I was checking things out under my seat on the drivers side just to see what was under (i found lipstick and previous owners drivers license under there haha) well I moved the seat all the way forward and then all the way back.. after i finished checking things out i decided drive somewhere and when i started my car up I got the airbag malfunction cantact saab dealership. I was like WTF O NO WHY!!! and then I thought.. I probably caused something to disconnect from moving my seats because it was fine before I started messing with my seats. There are wires under the drivers seat I found this little black plastic thing laying on the carpet and I was wondering were did this come from.. and then I found this loose black cable thing that was just loose well I started messing with the little black thing seeing where it came off from. which actually it had to go clipped on to the loose wire so I believe that black plastic thing was a sensor. I started my car up and the air bag malfunction contact saab dealership message went away! well that fixed the problem im sure I caused but now I have a loose cable with the airbag sensor all loose dangling under my car seat i have no idea where it suppose to be attached to like the seat or onto another sensor but it did get rid of my air bag malfunction message... That had me scared for about a day till i figured it was just the sensor that had to be reconnected to that loose black wire. I wish I knew more about my car. Well it is my second saab. Im a
previous owner of a 2003 saab 9-3 sedan
Z-m0k35
Old 13th September 2013
indy500's Avatar
indy500 indy500 is offline
My Saabs: '04 9-5, '04 9-3, '06 9-3, '07 9-3
Originally Posted by Blue_Steel View Post
... There are wires under the drivers seat I found this little black plastic thing laying on the carpet and I was wondering were did this come from.. and then I found this loose black cable thing that was just loose well I started messing with the little black thing seeing where it came off from. which actually it had to go clipped on to the loose wire so I believe that black plastic thing was a sensor. ...
That is a seat position sensor. It detects if the seat is close to the steering wheel or not based on the seat track position. If close to the wheel, then the front airbag will be depowered since the driver is so close to the airbag. I'm not positive of Saab's settings, but it is most likely set up so that if the sensor is faulted, then it assumes that the seat is forward and defaults to the lower inflation rate for that airbag.
BTW, the plastic sensor itself should be attached to the side of the seat rail. If not, then you have a problem in that it is always going to read the same seat position, no matter what the seat position is.
Old 15th September 2013
Daz944 Daz944 is offline
My Saabs: 9-3ss Aero convertible
Just to add in here, if your car is fitted with a battery disabling switch on the positive terminal of your battery then please go to: http://www.saabcentral.com/forums/sh....php?p=2679049
If no disabling switch then please disregard this. As said it could most likely be the seat position sensor anyway.
Old 16th September 2013
Blue_Steel's Avatar
Garage
Default Cool
Thanks a lot it looks exactly like that on the picture. I will put it back to its original place.
Z-m0k35
Old 23rd September 2013
Blue_Steel's Avatar
Garage
Cool 2006 Saab Airbag Malfunction Drivers side problem
well now for the second time I got the saab airbag malfunction contact saab dealer ship.
just right after i messed with the black cable trying to put it back inplace one thing i read was I should've of disconnected the battery first before messing
with the cables under the seat. that would of helped not getting the code to pop up(will try next time if i have to)
i made sure all cables were connected right.. After 4 days of driving and restarting the car the message went away.. weird its been over 2 weeks or so that the message hasn't displayed.. im sure there is no problem with my airbag .. its just me messing with under neath the seat that gave me problems, those things down there are sensitive if messed with. not again will i mess with it..
Z-m0k35
Old 16th December 2014
berkeleydojah berkeleydojah is offline
My Saabs: 2011 Saab 9-3 turbo4 convertible
Default Airbag malfunction 2011 9-3 convertible
This morning I got in and turned on the car and the airbag malfunction, contact service. Came up on the SD. Never had it before. Anyone can help?
Note: I haven't touched any wiring.
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
Had the Airbag light last week... 1/2 hr tech II Labor and they found nothing and referred to it as a Ghost code.
I pulled the F2 fuse and it's gone now
indy500's Avatar
There are 65+ wires in that system. It's very difficult to guess. You need a code to go on and to tag it you likely have to go to a dealer, or we need some more more specifics on when the lamp cones on and goes off.
Old 8th April 2015
diava diava is offline
New Member
My Saabs: 2003 93
Jonv please inbox me when you get this. I tried sending you a private msg but it did not allow. I live in nyc and have a question regarding replacement keys. Thanks.
Old 8th April 2015
Diggs's Avatar
Diggs Diggs is offline
My Saabs: 2003 9³SS Linear
I'll PM him. What is your question?
The answer is almost always....Tech2
Old 8th April 2015
New Member
My Saabs: 2003 93
I live in nyc and I noticed one thread where he paid around $100 for a key.. I need a copy and everywhere I call they see me coming. I have a Saab 93 2003..I was hoping he would give me the name of the place he used... Thank you very much.
Old 8th April 2015
Diggs's Avatar
He may have paid $100 for a key but I doubt he got it programmed and laser cut for that price. I'll PM him and point him to this thread.
Tags
airbag, malfunction, warning message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
2006 SAAB 9-3 Aero Airbag Malfunction Warning thodder 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 12 18th April 2013 09:57 AM
SID: Airbag Malfunction Contact Saab Dealer LimeYellowBoost 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 9 5th July 2012 11:06 PM
"Gearbox Malfunction. Limited Performance. Contact Your Saab Dealer." melissav223 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 4 20th August 2008 03:53 PM
2006 Saab 93 Aero Warning, Gearbox malfunction limited performance. Contact dealer. DemiGuru 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 21 29th March 2007 06:53 PM
Help - Saab Warning, Gearbox malfunction limited performance. Contact saab. Does any skos 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 5 14th September 2006 10:52 AM
