P0033 - Wastegate Arm Seized ; 2005 9-3 2.0 little "t" - SaabCentral Forums
Old 15th February 2012
bje bje is offline
New Member
My Saabs: '05 9-3 Linear 2.0t
Default P0033 - Wastegate Arm Seized ; 2005 9-3 2.0 little "t"
Hello everyone! newbie here.
I recently had a P0033 code pulled after our 2005 9-3 2.0"t" illuminated the CEL and went into limp home mode.
The mechanic I brought it to claims he's inspected the vacuum hoses, solenoids, etc and found that the arm connecting the solenoid to the wategate itself is seized and is.."unserviceable". The kicker is he's claiming the only solution is a full turbo replacement
I've spent the better part of the last few hours perusing the threads to try and address my particular dilemma. I've found a ton on P0033 but have not been able to find anything relating to the "arm being seized".
I would appreciate any feedback the saab gurus here can provide. needless to say, I'm not interested in their 'recommended approach"
Thanks in advance for any advice you can send my way!
pacotaco's Avatar
pacotaco pacotaco is offline
My Saabs: 04 93 arc espresso black
The wastegate is held onto the turbo by two bolts and a coder pin if you want to check if it actually is remove the wastegate diaphram check to see that the arm will push back into the diaphram (there should bre resistance its spring loaded but it should not be seized). Then check the flapper valve its connected to on the turbo it should open with ease if its not then theres probably either a blockage or some damage that caused it to be stuck. If both of those are working then its not something mechnical.
Its really simple to do and itll save you money and if ur mechanic is wrong and trying to get you to do it maybe try another.
i <3 backroads.
i rule your internet.
bje bje is offline
New Member
Thanks PACOTACO unfortunately I've not seen it yet, but do understand that the end seized is the flapper valve on the turbo. If this is the case is my only option replacing the turbo? It sure seems crazy to me!
pacotaco's Avatar
What seems crazy is that seizing because the flapper has a stainless steel. Earing going though a cast iron housing and as long as that car sees daily use theres very little chance that its seized over sith rust verrrry slim. If it is actually seized you can either tear the turbo apart and bang the flapper with a hammer and heat to unseize it or buy a new one luckly an lot of 2.0t guys like to swaP their turbos for us bigger t's so u might be able to pick one up for cheap
i <3 backroads.
pacotaco's Avatar
Dbl post sry
i <3 backroads.
edusaab's Avatar
edusaab edusaab is offline
My Saabs: 9-3ss 2.0t vector/9000 CSE V6/900 cabrio
The issue, is the wastegate actuactor is broken or the wastegate(the valve integrated in the turbo) is the one broken or stuck?
If it's the wastegate actuator the one broken, it could be replaced, but you need to check at Garret the reference and ask for a new one. If the wastegate, let's say the valve that is integrated in the turbo is broken, due the axle that permits to open/close the valve is broken or similar, then you need to replace the turbo. It happened to me twice, one due the Abbott ECU upgrade I installed first, as they change the wastegate actuator for a smaller one it caused the wastegate to be forced and broke twice.
Another possible issue and common to this turbo, is the diaphragm valve, that usually breaks, and there is kit to replace it at SAAB.
regards
Saab is my God and Turbo its credo.
Saab 9-3ss MY2003 Maptun stage7, Aero suspension,Maptun front strut brace, AP Racing brakes, Forge Intercooler, Saab 9000 V6 CSE MY95.Saab 900 2.0T 16v cabrio MY92
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
2005 9-5 "time for service" clear? Nagamitsu 9-5 Workshop 7 7th December 2011 03:39 PM
2-din HU in SS 2003-2005 Is it real? Yes! Little "how to" inside Nickolay 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 35 23rd December 2010 02:25 PM
open wastegate vs no tubing connected "?" fetchitfido C900 Workshop 10 16th November 2007 11:12 PM
2005 "Pre-Wiring for Hands-Free Phone" ??? bowtie26 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 12 6th February 2005 01:05 PM
