| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
I need to get a new turbo. Would like to up grade. was wondering if the only difference in the engine in a 2000 Saab 9-5 2.3Lt and the Saab 9-5 2.3L Aero is the turbo the only thing different
| Sponsored Links | ||
Advertisement | ||
Been discussed in here a lot
On the turbo the water supply and return lines are different. The Banjo bolt in the turbo end is larger so you will need the TD-04 turbo, the banjo bolts, the copper seals and the pipes. Cost new for the extra stuff is about $100, if you'r buying a used turbo you might be able to get the parts from the yard, but often they cut them when they take the turbo off. The ECU is different, but it will work from your LPT version. the TD-04 has a heavier turbine in it so it spins up slower. the AERO ECU takes this into consideration, the non-AREO doesn't. It also will give you the most benefit from the higher boost to have the AERO ECU, but you don't have to have it and the car will run from what I'm told. You can also reprogram your ECU using the T7 ECU tools. never done it, but others in here have. All in all, depends on what you'r trying to get. A CHRA for the GT17 is about $400 all in if you install it yourself and it should last at least 100K if you take care of the car. The Mitsu has a better longevity record, but if you go for a used one to get all of the right bits, will it outlast the GT17 rebuild? |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1999 9-5 4cyl turbo, replaced vacuum lines, now turbo doesnt work | ghallgrimson | Saab 9-5 Workshop | 1 | 14-10-11 09:07 PM |
| For Sale: Turbo from a 1999 9-3 SE High Output (SOLD: 3" Down Pipe, but not the turbo) | steviethev | Parts for Sale/Wanted - North America | 9 | 07-06-11 05:58 PM |
| 1989 Saab 900 Turbo- Using Turbo at Hi RPM's Blow My bRake Ligth Fuse | petersenpak | Classic Saab 900 Performance, Mods & Tuning | 4 | 08-04-10 09:51 AM |
| 1989 Saab 900 Turbo Convertable- Brake Light Fuse+Turbo | petersenpak | Classic Saab 900 Workshop | 0 | 06-04-10 10:51 PM |
| O Turbo, Turbo, wherefore art thou Turbo? | dazw101 | Saab 9-3 & NG900 Workshop | 9 | 18-07-08 03:05 PM |
