Power Steering Pump Question - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 5th February 2012
jskrebs jskrebs is offline
My Saabs: 93 9K CSE, 85 900T 3dr
Default Power Steering Pump Question
When I pulled the motor from my 9K I did not pay total attention to the power steering line. I actually let the guts fall out.
Need to know if know how the inner most piece is oriented.
Inlet Fitting
Spring
Shuttle valve - Nut in or out???
chengny's Avatar
chengny chengny is offline
My Saabs: 96 9K CSE, 97 9K CS, 96 9K CS, 94 9K CSE
Not sure what you're talking about, but here is a diagram of the control/relief valve. It discharges to the steering gear:
Looks similar but I am looking at the pump not the rack.
When I removed the line from the pump prior to pulling the motor. I undid the outer fitting which held the pictured pieces into the pump. The pressure line to the rack would exit to the right.
10 Google Searches later found it.
Old 6th February 2012
chengny's Avatar
Same component - different view. Just that the one I posted is more "schematic" than real life.
Yea, thanks. Glad to be certain. To undo a wrong installation after buttoning up the rest of the motor would be a ton of work.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Power steering pump Russell NG900 & OG9-3 Workshop 2 9th June 2010 08:47 PM
Power Steering Pump Xeo01 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 12 17th April 2009 11:52 PM
Quick Power steering pump question. St3mpy NG900 & OG9-3 Workshop 3 22nd December 2008 12:36 PM
Power Steering Pump TSB? killerniceguy 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 3 16th February 2008 11:53 PM
Power Steering Pump or Power Steering Hose?? ConvertibleMike C900 Workshop 2 30th June 2002 01:34 PM
