A little help...shouldn't something be hooked to this? - SaabCentral Forums
Old 03-02-12
ophelious ophelious is offline
New Member
My Saabs: 2001 9-5 Wagon
Default A little help...shouldn't something be hooked to this?
I recently bought a Saab 9-5 Wagon, 2001, base model. It has low miles, 1 previous owner, and was mostly dealer serviced. I thought I was getting quite a good vehicle based on this, but the more I work my way around the car the more I am troubled (especially now that I know about the sludgeing issues common to these cars.
I understand that I should do the PCV #6 update. I also understand that I should remove the oil pan and clean out any gunk. My problem is that I am getting confused looking at the various diagrams of exploded engine views.
I am attaching 2 pictures of troubling things. The first picture I think is part of the original PCV system (I circled the parts in particular that troubled me.) The fatter hose near the top is literally crumbling apart. The white valve (at least I'm assuming it's a valve) broke apart as soon as I touched it to take a picture. Knowing this to be bad, can anyone tell me what this is so that I can order a new one? Or would this part come with the PCV upgrade kit?
The second picture is equally annoying. I know that something ought be hooked into that little output on the throttle body that I circled. From the diagrams the best I can figure is that it's something to do with the turbocharger. I know it does SOMETHING because I can feel air coming out of it . So my second question would be, of course, what is supposed to be hooked in there? I am assuming it's more vacuum hosing but I don't know where it is supposed to end up or if there is supposed to be anything in-between the two spots. Any help in figuring out what it is so that I can order a new one would be of great help, and if anyone knows what the consequence is of leaving it open like it is now I'd be curious to know.
Overall I really enjoy my "new" Saab (I had a 92 900 for a while about 10 years ago and loved it as well) but it seems like all the tubing behind the valve cover is a rotted mess. It doesn't look too difficult to replace, but I'm not entirely sure what I'd need to do the job. Would the #6 PCV upgrade kit (as commonly sold) contain most of these parts? Any help would be great!
Old 03-02-12
N.E. Swede N.E. Swede is offline
My Saabs: 92 c900 4dr 89 c900 vert (t5) 87 c900t
pic 1: nothing goes there on a 9-5
pic 2: should be a vacuum line there that runs back to a valve (bcv) on the firewall near the brake booster (it'll attach to the port that faces left)
Old 03-02-12
Breau's Avatar
Breau Breau is offline
My Saabs: 2000 9-5 Aero Wagon HOT
http://www.saabcentral.com/forums/sh...d.php?t=147490
There's a pic that should help with the vacuum hose. It does go to the vacuum switch on the firewall that the rest of the hoses are attached to so there should be one hanging off. If not then you need to connect the two with a new vacuum line.
Old 03-02-12
Norm95 Norm95 is offline
My Saabs: 9-5 JZW lll 44 mpg, 9-5 SC stg IV 39 mpg
You'll need to replace all of the 3.5-4mm hosing in that area with silicone.
Personally I'd skip pcv 6 unless you never see more than idling around town, driving for coffee, ketting your car warm up, or hauling the kids to school. My car smoked on cold start if it was previously shut off after a couple of minute cold start. After my 120 daily hwy commute lososen things up no more smoking. Must have been coked oil around the bearings.
Pvc 6 has been known to cause oil consumption in some cars.
Old 03-02-12
Breau's Avatar
You do not need to change the vacuum hoses to silicone unless you want to, you can just zip tie the lines if they keep popping off. And you should get the pcv update if you don't have it already.
Old 03-02-12
New Member
Thanks for all the great comments and references. It looks like hooking the line back up to the throttle body should be pretty easy. Can anyone tell me what the impact has been of NOT having it hooked up?
From what I understand, the latest PCV retrofit mostly stopped the excessive oil burning issue...correct? It isn't that expensive of a kit and I'd rather be safe than sorry. That said, my question about the first picture perhaps wasn't clear. The part I circled is actually the white valve itself...what kind of valve is that so that I know what to buy? Also, the other thing I circled is a wider hose that has, from what I can tell, transformed into the properties of styrofoam (you can see in the picture some cracking.) That doesn't look like a small rubber or silicone tube (unless it's covered with insulation or something.)
Old 03-02-12
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
That hose should be connected to the vacuum valve; CEL, loss of power, loss of compression some of the things that can happen with that line off replace your vacuum lines uses 5/32 tubing about 8' should do it for the 4 cylinders.
That Valve, is the PCV valve; make sure the arrows on the valve are pointing towards the Throttle Body when you install the new one.
PEOPLE WHO TEST DRIVE A SAAB
USUALLY BUY ONE
Saab Owner/Driver since 1985,
Tags
missing hose, pcv hoses, pcv update, vaccum hoses
Similar Threads
I'm hooked.... Sleepy7666 Saab 9-3 & NG900 Workshop 24 08-08-08 12:18 PM
So I am hooked... sagedil Classic Saab 900 Workshop 17 07-12-07 04:15 AM
OK, so I am hooked.. sagedil Saab 9000 Workshop 1 05-12-07 11:20 PM
got my iPod hooked up jcooper Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 1 23-04-06 02:56 PM
It didn't take long before I was hooked... EskimoNamedJEBUS Saab 9-3 & NG900 Workshop 1 20-11-04 11:14 AM
