oil leak from the engine "front cover"??? - SaabCentral Forums
Old 02-02-12
nittaya nittaya is offline
New Member
My Saabs: 03 9-5
Default oil leak from the engine "front cover"???
So apparently the oil leaking from my car is from the engine "front cover". I was told that to fix this leak the engine has to be completely removed, which will cost a pretty penny.
Anyone had this problem? What does it take to fix a leak from the "front cover" of the engine? About how much should it cost?
Thanx
Old 02-02-12
unclemiltie's Avatar
unclemiltie unclemiltie is offline
My Saabs: 99 9-5, 03 9-5 Aero, 67 Volvo 1800S
Garage
which engine?
Old 02-02-12
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
Front cover; meaning the head gasket or the valve cover gasket that was recently replaced? If it's the head try doing a head bolt re-torque on the head bolts this could solve that problem.
PEOPLE WHO TEST DRIVE A SAAB
USUALLY BUY ONE
Saab Owner/Driver since 1985,
Old 02-02-12
MI-Roger MI-Roger is offline
My Saabs: 2008 9-5 Aero Sedan, 2006 9-3SC 2.0T
Default Also depends on what is causing the leak
Worn water pump bearing have been known to let the pulley wander into the front cover and wear a groove all the way through. In this case you need to replace the water pump, and you can seal the front cover with JBWeld or similar product,
2008 9-5 Aero Sedan
2006 9-3SC 2.0T
2000 9-5 lpt Sedan, Retired at 318,000 miles
Similar Threads
For Sale: Custom "Saab Power" Valve Cover SPG RACECAR Parts for Sale/Wanted - North America 3 21-05-12 11:54 PM
PN Needed: "Y" Vac line fitting off valve cover. Mucci Saab 9-3 & NG900 Workshop 2 13-10-10 10:11 AM
Help - "Door Mirror Cover" removal ichorid Saab 9-3 & NG900 Workshop 5 27-12-08 05:51 PM
How Much "Play" Is In Your Front Bumper Cover? bumperquip Saab 9-7X 6 17-04-07 07:59 PM
" too remove rear bumper cover" low_down_dirty_saab Saab 9000 Workshop 4 10-01-05 11:50 PM
