took out the radio now car wont start - SaabCentral Forums
Old 30th January 2012
pascettaa pascettaa is offline
My Saabs: 05 9-3
Garage
Default took out the radio now car wont start
Hey today i took my cd changer apart because there was a cd stuck in it i got the cd out re insalled the cd changer in the car now it wont start and it says immobilizer failure on the screen so i disconected the batt for awhile and still nothing
My Saabs: 05 9-3
Garage
sorry the car is a 2005 9-3 base model 4 door 5 speed
9-3tea's Avatar
9-3tea 9-3tea is offline
My Saabs: 2005 9-3t JZW Stage 3
Garage
You should make sure all of the cables back there are in properly, because if your head unit is unplugged it would cause the immobilizer failure.
cc93 cc93 is offline
My Saabs: 03 9-3 SS
Garage
you know for the hell of it check your battery too i see they get weak and they get that error message sometimes
Old 31st January 2012
brownpower brownpower is offline
My Saabs: 2006 9-3 Aero
Garage
all buses i p o can bus lines run through the deck. its a vital function of the cars electrical system. if you plug the deck back in it should turn on
My Saabs: 05 9-3
Garage
so i just took it all out to ensure all wire are connected and they are . when i turn the car on it wont start alos cd changer lights and climat controle lights wont come on . am i getting this faulire because of both units not working . if so dosnt anyone know how much saab chagres for a new cd changer and climat controle
My Saabs: 05 9-3
Garage
my next step is to talking it to a saab dealer wich i really dont want to do
My Saabs: 03 9-3 SS
Garage
I don't even know if you can get those parts anymore I know I have those parts use and are there any dealers open where you are
My Saabs: 05 9-3
Garage
the only dealer is far away from me i called them this morning
jcm jcm is offline
My Saabs: 08 93, 07 93, 03 93, 01/95
The multi disc changer has 3 plugs on the back. Check carefully. I've switched keys before with an immob failure showing to start a car.
Something sounds loose. The CD is the only thing that you changed so it should be solvable w/out dealer involvement. You may want to check the climate control or other wire hook-ups in back. Try employing a auto wand mirror with a flashlight. More work: Try removing dash starting with center & left vents along with 6 screws. Work your way down the stack to be sure everything is connected. Further, check fuses to see if you popped one.
SaabMick's Avatar
SaabMick SaabMick is offline
My Saabs: 09 9-3SC Aero XWD 6MT - Stage 5
Garage
Is this a new unit? I know there are certain components that need to be married to your car, which would have to be done via tech II at a dealership (or if you're lucky an independant garage).
EDIT: re-read your first post and it doesn't sound like it's a new unit, but like the others have said, check the connections again.
1999 Saab 9-3 SE HOT - gone
2006 Saab 9-3 2.0T - gone
2006 Saab 9-3 Aero SportCombi - "the beast" JZW Tuned Stage 5 - RIP
2009 Saab 9-3SC Aero XWD 6MT - JZW Stage 5
My Saabs: 05 9-3
Garage
thank you everyone for your replays youve helped alot. it turns out i overlooked a fuse and it was blowen replaced the fuse started first shot
thank you for all your input
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
flashers wont turn off, car wont start, battery at 12.1V Turboy 9000 Workshop 1 27th August 2010 09:14 PM
Radio wont accept radio code valorius NG900 & OG9-3 Workshop 1 26th October 2009 06:21 PM
Bought a radio and GS Kit, radio wont turn on Slaab04 NG900 & OG9-3 Workshop 2 25th October 2009 11:21 AM
The radio wont shut off after the car is off ritzsupra98 NG900 & OG9-3 Workshop 4 20th December 2008 02:41 PM
Cough & splutter on start up. Cuts out. Will/wont re-start. GONE FISHING 9-5 Workshop 3 6th August 2008 05:10 AM
