Lowering - What's your camber change? Camber Kits? - SaabCentral Forums
Old 24-01-12
BobSaabit BobSaabit is offline
My Saabs: '97 NG900 'vert; '03 OG 9-3 'vert
Default Lowering - What's your camber change? Camber Kits?
For those who've lowered their cars with an aftermarket spring set... anyone checked just how much their camber changed, front or rear?
Also, anyone installed a PFS camber kit to adjust it?
Old 24-01-12
jakejm79's Avatar
jakejm79 jakejm79 is online now
My Saabs: 1999 9-3 Convertible
I dont think you can install the kit, it is for when the strut is bolted to the spindle, it is all welded has one piece on the ng900/og9-3, I believe it is for the 9-5 and possibly 9-3SS.
This is from a 9-5, the kit replaces bolts #14.
Here is the same area of the og9-3, no where to put the bolts.
Old 24-01-12
Yeah... good point. I was envisioning it replacing the stanchion to control arm bolt #27, but now that I look at the illustration, it appears that it would only change caster since the control arm length is fixed.
The only way it might work is if it replaced the control arm to frame bolt # 28. That's not the intent now that I re-read the kit description. You'd need an eccentric bolt to replace #28... not sure what bolt size that would be but it would be a coincidence if it matched the 9-5 strut to spindle bolt size.
Still interested if anyone has measure the front / rear camber changes before and after or just after lowering.
Old 24-01-12
grkguy89's Avatar
grkguy89 grkguy89 is online now
Moderator
My Saabs: 97 900SE, JZW Stage HX35 w/m injection
Garage
IIRC the change in camber in the front from the basic lowering springs still stay withing factory parameters
rear toe and camber get excessive... but that's mostly due to the rear being an issue even before lowering
Christos (VA saab meet pm me?) JZW Tuned Stage 7
http://www.eurocarswmbg.com/
Old 25-01-12
saabkid37 saabkid37 is offline
My Saabs: 99 Viggen
i have eibachs. unlike other springs ive seen there was no noticeable change in camber.
also, it will only change in the back aka no reason to worry about it until you start eating tires, in which case you probably have a tweaked rear axle or some other larger problem.
Old 25-01-12
tkjr5000's Avatar
tkjr5000 tkjr5000 is offline
My Saabs: 900SE,9-5 Aero
The only way to adjust camber on the NG would be to install camber plates where the strut mount is.
Some plates bolt up(the Saab design would allow for this) and others need to welded in.
http://www.ground-control-store.com/...gory.php/CA=97
None for a Saab but I but you could find one that would work(these aren't necessary for a regular street car).
Nice location, Bob.
Old 25-01-12
I'm thinking that the front has to change. The bottom location of the knuckle is fixed horizontally. So is the strut top body mount . So, if you shorten the spring, then the distance from the knuckle to the strut top body mount (and since they are not directly on top of each other), then the angle of the strut has to add more negative camber to connect the two points, doesn't it?
I'm actually more concerned about the front... I know I can shim the rear if needed for toe & camber.
Also, I'd prefer to do it before I eat up $300 worth of tires :-)
Old 25-01-12
Nice location, Bob.
Yeah... I actually did a little custom slotting previously on the NG to correct a caster issue. The good news is that because of the length of the strut, it doesn't take much of a change. The bad news is that it's really kind of unnerving to dremel your unibody.
Similar Threads
Camber Issues When Lowering? BlackedOutSaab Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning 16 19-08-10 09:30 AM
Correcting Camber after fitting lowering springs handy_andy_100 Classic Saab 900 Performance, Mods & Tuning 8 19-04-09 10:22 AM
Are people buying front camber kits when lowering? the.hatter Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning 4 26-02-09 11:41 AM
Lowering and camber adjustment Chris 9-5 Saab 9-5 Performance, Mods & Tuning 5 10-02-05 05:32 PM
Lowering my 9-5 and negative camber XAAMOTTOMAAX Saab 9-5 Performance, Mods & Tuning 1 15-05-04 09:25 PM
