Head Bolts: Just re-torque or replace? - SaabCentral Forums
Old 18th January 2012
pokeyjoe's Avatar
pokeyjoe pokeyjoe is offline
My Saabs: 2000 9-3 Base Coupe
Default Head Bolts: Just re-torque or replace?
The tightening instructions (30 ft/lb, 44 ft/lb, then 90) leads me to believe that these are stretch bolts and should be replaced, however the Saab service bulletins just say to re-torque.
Thoughts?
John
"Where am I going and why am I in this hand basket?"
BobSaabit's Avatar
BobSaabit BobSaabit is offline
Saabista
My Saabs: '97 NG900 'vert; '03 OG 9 'vert
Saab specified "re-torque" because they had thousands of cars to do and it took far less time/money to re-torque and replace only those that would not hold properly.
I did it once without replacement and several of the bolts felt very uncomfortable, even just determining that they were stretching ad infinitum. The second time I did a car I ordered a new set of bolts. It's only $50 and it feels much better.
fsavard fsavard is offline
My Saabs: '01 9-3 2.0
What's the proper way to do it?
30/44/90 on the first bolt then go to the second one, etc.
or
30 on the first bolt, then change the second one, etc.
44 on the second pass
90 on the final pass?
pokeyjoe's Avatar
These are the service bulletin instructions.
John
Old 19th January 2012
redrum's Avatar
redrum redrum is offline
My Saabs: 1997 900SE 2.0t
I'd say a retorque once is fine, I would buy new ones if they'd been retorqued in the past.
signature here.
Cm452 Cm452 is offline
My Saabs: T5 Suited Stg T28++ 9-3
Several '99's that I've seen had a retorque in their service history. Mine did and I bought new bolts. The horror stories of people snapping them in the head was sufficient deterrent for the cheapo solution of retorquing.
-cm
tkjr5000's Avatar
tkjr5000 tkjr5000 is offline
My Saabs: looking for a 99 Turbo
What CM said. Replace them, for 50 bucks it's a no brainer. That's a lot cheaper than paying someone to remove the broken piece out of the head after you spend 6 hours cursing everything in sight and not getting anywhere.
BobSaabit's Avatar
Saabista
or
One bolt at a time. See the TSB at the genuinesaab.com site.
lms's Avatar
lms lms is offline
First question, why do you think you need to do this?
pokeyjoe's Avatar
Well, the Saab TSB, for one. Why would they bother to issue it if there wasn't a problem? The TSB pretty much states that either they weren't tight enough when they left the factory or they stretched more than anyone thought they would and they need to be re-torqued.
John
pokeyjoe's Avatar
Originally Posted by BobSaabit View Post
One bolt at a time. See TSB at the genuinesaab.com site.
This is incorrect. That's not the TSB. The actual TSB specifically states:
3 Back off bolt number 1 and tighten it again. Repeat this in the order shown. Tightening torque 40 Nm (30 lbf ft).
4 Tighten bolt number 1 to a torque of 60 Nm (44 lbf ft). Tighten the other bolts to the same torque in the order shown, see illustration.
5 Tighten bolt number 1 an additional 90 (1/4 turn). Tighten the other bolts similarly in the order shown, see illustration.
Here is a link to the actual TSB on Townsend's site.
John
lms's Avatar
lms lms is offline
But you have a 2000, correct?
I was wrong, I thought it was up to 99 years.
BobSaabit's Avatar
Saabista
There was another TSB that superceeded the original TSB. If you want to argue that it doesn't cover pre-99 2.0 liter motors, or that the '96 and previous motors covered by the TSB you posted, you can, but I'd bank on it being intended to cover ALL 2.0 motors:
http://www.genuinesaab.com/psi/files/headretorque.htm
pokeyjoe's Avatar
Well, I just spent a lot of time searching for that newer TSB and couldn't find one. Anyone have a link? The Talifero link (genuinesaab.com) is the only place I've seen that procedure listed like that. Thesaabsite quotes the TSB as I did above. I did discover that none of the head bolt TSBs even apply to a 2000 9-3. Much ado about nothing, perhaps?
I think there are enough posts about headgasket failure to justify doing it just for peace of mind.
John
BobSaabit's Avatar
Saabista
There is this for the 9-5, 205 & 235 motors '98 to '01 : http://www.saabnet.com/tsn/bb/9-5/index.html?bID=98292 which you can read fairly well, and this for the 9-3 http://www.saabnet.com/tsn/members/g...7&memberID=112 which is a little harder to read because the guy who runs saabnet is a dickhead.
pokeyjoe's Avatar
Thanks, but both of those links echo the procedure listed above in the actual TSB (not the genuinesaab link). Oh,well.
John
BobSaabit's Avatar
Saabista
Well, does address the point of whether the MY 2000 is covered.
As to the tightening sequence, I don't think GS made up that procedure, and I think I saw it in a TSB before. But, you could email Nick and ask to be sure. The TSB you cited is dated 1996 - it's definitely dated.
Either way, the GS listed procedure seems like a better choice to me. The GS TSB has the head under uneven torque for a minimum period of time.
pokeyjoe's Avatar
Assuming that all the torque values are about right to begin with. If not, the other way makes more sense (get them all to 30, then finish the process).
John
BobSaabit's Avatar
Saabista
That's the best assumption... if they are uneven then it's still probbaly the best approach since we don't know the conditions.
If you like, you can start by checking bolts 10, 9, and 6 for reasonable torque, then run through the procedure of swapping bolts.
I have no idea where that info came from. WIS and ELRING both have a torque diagram with the torque down beginning in the middle of the head and all bolts progressively getting more and more tightened down. Do you tighten just one lug nut on your wheel to peak torque at a time? NO! Everything that I've ever worked on had a progressive torque increment in a pattern that evenly distributed pressure. Maybe I misunderstood, but this is what I meant:
http://www.swedishwrench.com/head.htm
-cm
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Timing Diagram and Torque #'s for Head bolts and Cam bolts Iluvatar04 NG900 & OG9-3 Workshop 4 29th March 2015 12:03 PM
Doing a re-torque on head bolts. What else? cptnjosh 9-5 Workshop 4 21st July 2011 09:45 PM
bolts for the torque sp53 9000 Workshop 2 19th June 2011 01:52 PM
head bolts torque specs blue900s NG900 & OG9-3 Workshop 14 14th November 2007 03:31 PM
Need to re-torque head bolts? Oz David NG900 & OG9-3 Workshop 4 16th September 2007 06:39 PM
