Transmission dipstick? - SaabCentral Forums
Old 11th January 2012
2003saab93 2003saab93 is offline
My Saabs: Black 2003 saab 9-3, 5 speed, Td04 turbo
Default Transmission dipstick?
I have a 2003 saab 9-3 Linear 2.0T, I just bought the car so I am taking a look through all of my fluids to see what needs changing and what doesnt. I can not find the transmission fluid dipstick for the life of me, some help please? thanks!
Old 12th January 2012
JMarkert's Avatar
JMarkert JMarkert is offline
My Saabs: 2004 9-3 linear
Do you have the automatic? If so, it's bright green and you can see it if you look straight down sort of behind the radiator, maybe just to the right of the center of the car. It's held on with a 10 mm hex nut, I think. I can only get to mine by putting the car on ramps and reaching up from underneath. I think I have a picture somewhere, I'll try to post it...
Edit: There's a picture in this thread http://www.saabcentral.com/forums/sh...d.php?t=140361
Old 14th January 2012
i have a 5 speed manual transmission, is it any different?
Old 15th January 2012
JMarkert's Avatar
Ah, yes. I got confused, partly 'cause many of the manual transmissions are six speeds, we auto folks are perhaps the more common 5's.
Anyhow, I believe that you don't have a dipstick if you have a manual. Someone please correct me if I'm wrong. My ng900 had a manual, and it only had one of those inspection plugs to check the level, no dipstick.
Htedagem Htedagem is offline
My Saabs: 05 93 2.0t
yeah you're right, manuals don't have dipsticks. ( thought that was common knowledge )
Old 16th January 2012
so is there a way to check it without putting more fluid in? like is it possible to put ur finger inside and see if u can feel the fluid?
genman genman is offline
My Saabs: Jag XF + Aero 2.8 XWD Auto
the 5 sp has an allen key bolt / plug just behind and a little higher than the driveshaft...this is the fill level, so if the car is raised nice and level the oil should just be at the lip of the whole.....at the bottom of the casing is the drain plug.
Access to it is by removing the left wheel...most likely a bit tight so try to use good quality allen tools to minimise the chance of wrecking the bolt / plug
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Transmission Dipstick on 2.8 V6 jimbenton 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 3 8th December 2007 06:48 PM
Transmission dipstick on 2004 9-3 pzumbahl 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 3 2nd April 2007 11:18 AM
Automotic Transmission Dipstick Boyd042873 NG900 & OG9-3 Workshop 4 2nd March 2007 05:44 PM
transmission dipstick? rutter001 C900 Workshop 4 27th October 2005 06:31 AM
My Transmission Dipstick... MonkeyMan C900 Workshop 4 23rd November 2003 10:34 PM
