| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
Hey guys,
We just finished replacing a head gasket, and are putting the car back together, but can't remember where one of the vac lines goes from the throttle body. ![]() The vac line in question is the yellow one. It popped off while taking everything apart and we cannot figure out where it goes. Any tips? |
| Sponsored Links | ||
Advertisement | ||
I don't see a pic- just me?
The yellow goes here (on the left, horizontal position):
This is the missing?
![]() In red, before the throttle body In blue, after the throttle body ![]() David |
If you're here, visit this:
http://www.saab-tuners.com/en/hardwa...e-modification More detailed information (will need a translator): http://da95-saab.blogspot.com/ |
http://www.saab-tuners.com/en/hardwa...e-modification More detailed information (will need a translator): http://da95-saab.blogspot.com/ David |
![]() Th blue colored 'FESTO' line is. |
It is possible to improve the system:
saab-tuners.com "modification has been published by Nick Taliaferro" Normal operation: ![]() ![]() With changes: ![]() ![]() David |
Hi I was reading your posts here that means my vacuum lines are jacked up. I just got this car and I replaced based on what I saw and I think someone before me must have F***** up. Ok so where does the line that has the check valve from the valve cover connect to. Actually does anyone have photos of all the vacuum lines and their connections. No I have zero confidence in mine. No wonder it goes in limp mode immediately after I start it. It didn't do it before, but the lines were broken and leaky.
Referring on photo enclosed by yourself at the beginning: it's 'under' the yellow line connection into the TB. Check valves directions toward TB (if you disconnect the line at the valve cover you must be able to blow but not suck the air through it).
In graphic:
before ![]() after ![]() The 7 is the valve that goes offline. The tube before the throttle, is blocked: ![]() The tube coming from the valve: ![]() goes directly to the intake manifold, not the throttle. This image seems to go online in the tube (red), not so. ![]() Only need to touch the tube (blue), the red of the image No. David |
I am more confused. Does it go to the blue nipple or red nipple in the diagram that is enclosed above?
Sorry David, your drawings are very professional, but difficult to understand these and make confusions me too...
![]() The coming of the valve: ![]() The intake manifold: ![]() David |
Try to be clearer.
![]() 1. the tube is pulled out of depression (1), connect a short piece of pipe (5/6cm), cover the hole in the tube (eg a screw). 2. tube joins the point (2) to (3). 1/2/3 points standings: ![]() Done. David Last edited by Da95; 18-01-12 at 01:56 PM. |
With photos:
1 ![]() 3 ![]() 1-2-3 ![]() The idea is to make it as similar to the Trionic 5, without control by the ECU, preventing delays in throttle response. Trionic 5: ![]() David Last edited by Da95; 19-01-12 at 05:42 AM. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Throttle body hoses | MyGreenMachine | Saab 9-3 & NG900 Workshop | 2 | 01-11-11 03:34 AM |
| Throttle Body hoses | mitay | Saab 9-5 Workshop | 6 | 06-12-07 05:42 PM |
| throttle body hoses | saabrider | Classic Saab 900 Workshop | 9 | 20-02-07 08:51 AM |
| Coolant hoses on throttle body? | DanComden | Classic Saab 900 Workshop | 13 | 28-04-06 02:35 AM |
| Removing Coolant Hoses from Throttle Body | FlyPenFly | Saab 9-3 & NG900 Performance, Mods & Tuning | 5 | 31-05-05 01:57 PM |
