| SOTM Submissions & Voting Submit your car for voting & vote for your favorite Saab. |
The rules are posted in the sticky in the main section for SOTM Submission & Voting
(here's the link just in case; SOTM, Rules and other need to knows.) Open for entrants!!!! Will close on the 15th follow this template ***EXAMPLE*** The Silver Sled (1988 900 Aero) Specifications Engine Brand new Saab B202 2.0 Litre 16 valve crate engine (installed November 2010) Rebuilt Bosch distributor Stock Bosch electronic ignition SPG9 AID (Advance Ignition Diaphragm) with timing at 20˚BTDC Bougnicord spark plug leads NGK BCP7EV plugs Aquamist 1S water Injection using 0.9mm injector Aquamist DDD (digital dash display) for water injection output Crank case ventilation catch-can Exhaust 2.5 inch from cat converter back with hi-flow racing cat 4 inch chrome semi-oval tip Hi-flow dynomax stainless steel muffler and rear resonator 3 inch JSP stainless steel split down pipe off turbo to cat Turbo Mitsubishi TE-05 16G: with 16G compressor wheel with 10˚ clipped vanes, upgraded thrust and is rated as a 300HP turbo Wastegate running 7psi base boost Stage 2.5 SPG9 APC running to 18psi boost Jak Stoll Performance Talon high-flow side mount intercooler 8 inch Davies Craig thermo pull fan mounted on reverse side of intercooler with manual switch inside cabin Saab C900 1990+ aluminium turbo intercooler ducts Stratmosphere Forge bypass valve K&N filtercharger Plastic intercooler top air dam Fuel System Bosch 3.0 BAR fuel pressure regulator Trionic 5 34lb injectors Jak Stoll Performance Stage 2 ECU chip Fuel pressure gauge situated in-line on fuel rail Suspension Stock Saab Aero springs and shocks Stock Saab Aero road handling kit including front and rear sway bars Polyair inflatable air bags inside rear springs Wheels & Tyres 16" x 6.5" Saab Super Aero rims Goodyear Revspec Ducaro 205/50/16 tyres Other Stock Saab Aero factory whaletail Saab Aero vent covers (factory colour coded silver to match duco) AutoMeter 30"hg to 30psi boost guage AutoMeter air/fuel ratio guage Saab factory rear decor panel SaabSavior short shifter Saab Momo leather steering wheel 3.5mm blue silicon vacuum hose Saab Aero original Alpine surround sound 5 speaker stereo Aero kit factory colour coded silver to match duco Output Estimated 190kW (250hp) at front wheels (need to do another dyno once new crate engine is run in)
| Sponsored Links | ||
Advertisement | ||
Dag (1995 900 SE)
Specifications Engine Original unmodified B204L Taliaferro Poly transmission mount Taliaferro Poly rear engine mount Maptun Silicone IC & coolant hoses Blue painted valve cover Exhaust Maptun 3" stainless downpipe and race cat Stock silencers Turbo Original Garrett T25 Crossflow intercooler Silicone vacuum hoses Forge FMDV006 billet recirc valve Fuel System Stage 3 T5 suite remap with T7 APC conversion Knock LED AEM uego wideband with live datalogging Suspension Taliaferro 22mm rear ARB Powerflex Poly TCA inner & outer bushes & rear axle bushes Eibach 35mm lowering springs Bilstein B4 shocks Wheels & Tyres 17"x7" Saab 3 spoke quads (aka Garry Fishers) 225/45/17 Uniroyal Rainsport 2's on the front & Michelin PS2s on the rear Other Stack 2 bar boost gauge Permanent canusb connection for T5suite Alpine 7915M old school deck (running Alpine 3 way active system) Talladega front lip spoiler Talladega leather door cards & chrome handles Sand beige leather Walnut dash & gear knob Stack 2 bar boost gauge Saab Decor panel Saab Headlamp protectors Smoked Repeaters Output Estimated 265hp 300lb.ft (dyno'd at 240hp 247lb.ft whilst stage 2)
1995 900 SE turbo, Eucalyptus Green Last edited by Kei; 07-01-12 at 01:49 PM. |
Saabhutter's Aero (2007 9-3 Aero 6MT)
Engine 2.8L V6 Turbo Wester's Garage Stage 1 Exhaust Stock Turbo Twin-scrolled, water-cooled TDO4-15TK Suspension Stock for now, car will be dropped in the summer as per picture. Wheels & Tires Stock Aero Five Spokes, plastidipped matte black. Kumho Ecsta SPT Tires Interior Saab Rubber Floor Mats, State of Nine Custom Logo Mats. Exterior Tinted tails, 30% tint on rear windows, E-codes, Chrome turning bulbs, smoked repeaters. Output ~300 hp ~380 lb/ft
1990 Talladega SPG
Mods Engine 2.0L 16v Turbo 5spd. Blue series injectors 3.0 bar Red box apc High pressure bypass valve 18 psi wastegate CAI Fuel chip Performance wires FMIC 15+ psi of boost Exhaust Catless starla exhaust Suspension Lowering springs Bilstine shocks Interior Black leather, red door inserts. Boost gauge on the A-pillar Full sound system Exterior Talladega SPG with window louvers
Isint the point of SOTM to post an ''actual'' picture of the car and not a P-shop?
I don't have any other decent pictures, my car has been in the shop for over a month and I've owned it for less than a year. If the stakes were higher than a little picture beside my avatar I'd try to find something else.
I'm a sucker for C900's, but Kei I've always loved your NG900; that car is MINT. Love the color, love your photography. Good luck!
1998 Saab 900 SE Turbo 5Dr Auto
Specifications Engine Original B204L with 223,XXX miles Repainted Valve Cover Black and Polished Saab Emblem Replaced Vac Lines with Blue Silicone BPCR7ES-11 Spark Plugs Thermotec Wrapped Delivery Pipe Exhaust Stock except exhaust dumps after rear axle, (i.e. No rear muffler) Turbo Stock Garret T25 Stock Wastegate-7psi base boost with Helper Spring Added Heat Shield with custom Turbo Snail Emblem Smartperformance MBC set to 13psi to help limit spiking Stock Dual Pass Intercooler Forge Twin Piston BOV GenuineSaab OAI Fuel System Stock Suspension Stock Gold Painted GenuineSaab Basic Subframe Brace Wheels & Tyres 16" x 6.5" Gold Saab Viking Rims Michelin Harmony All-Season 205/50/16 tyres Other Stock Hatch Spoiler Rallyarmor Mud Flaps Hella 500 Rally Lights vvme.com 10,000K Bi-Xenon HID Kit Stock Foglight Bulb Sliver Fender Repeaters Clear Corner Mod De-rusted and Painted Matte Black Hood Mesh Grille Removed Slats in Front Bumper Center Tail light Reflector painted Body Color LED License Plate Lights Upgraded Stereo with JVC Deck, Pioneer S-Series Speakers all around and Tweeters in the rear deck lid Glowshift Tinted Series 30/30 Vac/Boost Gauge Scangauge displaying Intake Temp, Coolant Temp, Volts, and Engine Loop Output Not Much Above Stock maybe around 200-205 on the Butt-Dyno. It will beat my uncles 9-3 SE HOT in a race so its atleast 200 hp.
My Saab's Lug Bolts require more TORQUE then your Honda makes! |
project belguim beauty (1988 900s )
Specifications Engine rebuilt Saab B202 2.0 Litre 16 valve red k&n cone air filter, and breather filter for crankcase ngk type r spark plugs accel 8mm wire set red valve cover, fuel rail, fpr deleted a/c, cruisecontrol Exhaust 2.25 autosports catback exhaust system headerwrap to muffler Fuel System Bosch 3.0 BAR fuel pressure regulator bosch jetronic fuel system Suspension billstien shocks front sport springs with trimmed coils rear custom coilovers, and dampers misc. prothaine bushings hawk brake pads Wheels & Tyres 15" factory sunburst wheels Michelin tyres Other stock rear hatch spoiler black grill black on black racing checkard flag headliner black leather door card inserts short throw shifter leather shift boot with red sticking to match interior leather b&m shift knob euro plates satan black bumpers prancing moose stickers original autobauhn window stickers 89', 90' upgraded cd player, with aiwa speakers Output notsure
1998 900 SE 2.0 Litre Turbo
Specifications Engine 2.0 Litre 4cyl Turbocharged Auto Exhaust Stock Turbo Stock Fuel System Stock Suspension Stock Springs Wheels & Tyres 16" Factory Alloy Firestone Firehawk Other Factory Grill painted black with wire mesh inserts HIDs headlights & Fog Lights License Plate Frames & Covers Keepin' it stock to keep it classic Last edited by grkguy89; 16-01-12 at 12:11 AM. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Submission for DECEMBER'S Saab Of The Month | grkguy89 | SOTM Submissions & Voting | 10 | 14-12-11 09:55 AM |
| Submission for NOVEMBER'S Saab Of The Month | grkguy89 | SOTM Submissions & Voting | 15 | 15-11-11 03:21 PM |
| Submission for OCTOBER'S Saab Of The Month | grkguy89 | SOTM Submissions & Voting | 15 | 27-09-11 12:02 AM |
| Submission for SEPTEMBER'S Saab Of The Month | grkguy89 | SOTM Submissions & Voting | 19 | 10-09-11 04:09 PM |
| ugh! bad SAAB month | valbowski1980 | The Lounge | 31 | 02-10-06 06:09 PM |
