Rear Camber Issue on my 06 Wagon - SaabCentral Forums
Old 25-12-11
LEGage's Avatar
LEGage LEGage is offline
My Saabs: 2006 9-5 Sportcombi/2003 9-3 Arc
Default Rear Camber Issue on my 06 Wagon
Hello All,
I figure seeing how I am not the only one who has had the rear camber issue with our 9-5 wagon I would share how I am going about trying to solve it.
Here is a diagram of our rear suspension.
Attachment 26887
My rear suspension still seems to be fine, so I am going to milk the rear shocks and springs for another year at least. Doing that though still leaves me with the rear camber issue, and how best to go about fixing it before I put on new tires. I spoke with my shop(Ellis Imports) and they informed me they have seen this issue on multiple wagons they have tried all sorts of solutions, from new shocks and srpings, shims etc...
What they learned from calling around is that the source of the camber issue is not the springs or shocks, but seems to be the rear steering knuckle bushings wearing out. So I had my shop replace the rear steering knuckle bushings, and then had an alignment done. The result was I got really close, but as others have found out my car will still need the shims. My car is still out .5° on the left rear, and still out .6° on the left rear. I will use a .6mm shim on each side to fix the issue before I get my next set of all seasons in a few months.
A side note I found out my right front is out .4°, so I will need to get the Front Suspention Bolts also.
My Car: 2006 9-5 SportCombi ----- Wife's Car: 2003 9-3 Arc
Old 25-12-11
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
Originally Posted by LEGage View Post
Hello All,
Attachment 26887
Uhh it woudl help if you told us what part number in the digaram you are calling "rear Steering knuckle bushings"
And are you talking about front or rear camber being corrected by fixing the front?
Old 25-12-11
Norm95 Norm95 is offline
My Saabs: 9-5 JZW lll 44 mpg, 9-5 SC stg IV 39 mpg
You'll have to replace all rear bushings, only replace some bushings and insteall spacers(see saabnet) or replace some and plan on lower springs all around.
I didn't replace any bushings on my sedan and slotted the upper bushing alond with Eibachs.
Old 25-12-11
LEGage's Avatar
The rear bushings I am referring to as the rear knuckle steering bushings are #12.
To fix the rear camber on my wagon. My first attempt is to replace the rear knuckle steering bushings, and use shims. Maybe this will help others maybe not.
Seems to have resolved the rear camber issue on my car. Many ways to do something, just sharing what seems to have worked for me.
As for the front I will need go with the bolt mod. Which has nothing to do with the rear.
Old 25-12-11
LEGage's Avatar
Old 26-12-11
Yes cross stay bushings, steering knuckle kind confused me the back does nto steer at all...
Sometimes ( but not often ) repalcing all the bushings will help camber but lots of thinds can send it out
Similar Threads
Bending rear axle for rear camber... ejenner Classic Saab 900 Performance, Mods & Tuning 14 01-11-12 03:53 PM
Stiff Rear Suspension/ Rear Camber Problem Hoffman720 Saab 9-5 Workshop 1 16-12-11 09:29 AM
Broken Rear Camber Bolt Issue Jplipper Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 3 12-05-11 12:24 PM
Adjustable camber on a 9-5 wagon Zensis Saab 9-5 Performance, Mods & Tuning 2 31-07-10 05:36 AM
Rear camber valbowski1980 Saab 9-5 Workshop 4 22-02-09 09:37 PM
