T25 Pre-turbo intake piping - SaabCentral Forums
Old 06-12-11
dougwentzel dougwentzel is offline
My Saabs: 96 900SE - Stage 3+, 3" GS v2 DP + more
Garage
Question T25 Pre-turbo intake piping
So, on EricSaabSite (http://www.ericsaabsite.com/Upgrades.../PreTurbo.html) there is instructions on how to make your own less restrictive pre-turbo intake piping. Since I still have the stock T25 turbo, my question revolves around the bottom portion of his pre-turbo piping instruction page where it says:
"The best/easiest solution is to cut the inlet pipe just above the 90 degree bend and attach a larger pipe from there to the air filter. This allows the crank case breather to remain untouched so the only other modification required is to use a blow off valve instead of a bypass valve."
I have the plug for the stock intake piping, so does this just mean cut the stock intake piping after the plug and attach a mandrel bent pipe to my K&N cone filter setup? Or am I missing something?
Thanks!
Old 06-12-11
lowbudgethero's Avatar
lowbudgethero lowbudgethero is online now
My Saabs: 2x 1999 saab 9-3se stage 3
Garage
essentially yes, power increase will probably be minimal as you already have a pretty unrestricted intake anyway
2009 BMW 135i, 2x 1999 saab 9-3se HOT both are stage3, 1986 Honda Interceptor, 1998 BMW M roadster (RIP), 1993 audi 90cs (sold), 1992 dodge dakota (sold)
Old 06-12-11
markyboy75's Avatar
markyboy75 markyboy75 is offline
My Saabs: 1999 9-3 turbo s stg 2
I just purchased this from eBay
http://www.ebay.co.uk/itm/1507135665...84.m1438.l2649
Plus my cone filter. Should all be here in a few days. Should I cut my intake piping right back so I can use most of the stainless steel tubing.....
Mark.
Old 06-12-11
BobSaabit BobSaabit is online now
My Saabs: '97 NG900 'vert; '03 OG 9-3 'vert
Since there's no restriction in the stock intake until you get over 300HP, you might want to take an easier route.
Cut off the stock snorkle and fit a 3" PVC pipe fitting in its place. Get a 3" air cleaner pipe from some place like Autozone and clamp it to the PVC fitting. Get a V shaped gutter collection fitting and fit it in the other end of the air clear hose. Run it down by the rear headlight area.
Install a K&N filter.
You'll get all the turbo whine you want, and the total cost will be under $20, plus whatever you pay for the K&N.
Old 07-12-11
Garage
This is kind of not what I was going after. If you look at my link to ericsaabsite.com, you will see that I'm talking about the flexible rubber hose that goes from the turbo to the air filter. It is not a smooth pipe and is not long enough to take my cone filter to where I want to put it (in the place of the stock airbox) without some sort of bend and reducer. I am just asking what is the diameter of that rubber tubing from the turbo so I can simply get a small mandrel bent pipe to connect from the where the stock rubber hose ends to where my K&N cone filter begins. I will need like a 45 or 60° bend I know, but I just don't know the sizes or the best place to look right now.
Thanks!
Old 07-12-11
markyboy75's Avatar
Thanks!
If you look at the link I posted m8 you'll see that the stainless piping comes apart and has a right angled bent pipe. That is the piece your looking for I think lol. You don't have to use use all the pipe..
Old 07-12-11
jakejm79's Avatar
jakejm79 jakejm79 is offline
My Saabs: 1999 9-3 Convertible
You will need 2 3/4" pipe to fit in the hose, though I was able to take a 3" mandrel bent piece of exhaust and squeeze it in there.
Old 11-12-11
20009-3t 20009-3t is offline
My Saabs: 2000 9-3 2.0
http://www.ebay.co.uk/itm/150713566573?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1438.l2649
Mark.
Just wanted to add that if you scroll down to the bottom of that ebay page, they have one of those electric superchargers LMAO!!
Old 11-12-11
markyboy75's Avatar
what ya tryin to say dude lol. Is that coz I've only got an lpt. Will be ok when I get the HOT conversion done.
Old 11-12-11
AZR Racing AZR Racing is offline
My Saabs: 1997 saab 900se
Garage
HOT conversion? psh go big or go home. ill sell you the gt4082
900 SEC 2.xT, custom 3inch exhaust, GT35r BB turbo, custom log manifold, tial Q bov, autometer phantom boost,oil,WB, JZW full custom tune, siemen 60# injectors, aeromotive 340 intank, want fried rice?
Old 12-12-11
markyboy75's Avatar
I'm not after making my saab into a race car just wanna get it out of lpt mode lol.
Old 14-12-11
Dr Kenneth Noisewater's Avatar
Dr Kenneth Noisewater Dr Kenneth Noisewater is offline
My Saabs: The Blue Waffle. MY00 9-5 Aero Stage 3
Mark. I'll say it again. Dead easy. Get £50, give to mapper (I know plenty), mapper gives you stage 2 ecu. Put new Ecu in lpt and leave those shameful days behind you. Enjoy 225 bhp on tap. Now stop being a silly boy and get it done.
Old 14-12-11
markyboy75's Avatar
I know Phil. That will be gettin done after crimbo m8. Just wanted to change a few other parts that wouldn't cost a fortune before hand.
Similar Threads
For Sale: 9-5 Air INtake piping str8tdubbed Parts for Sale/Wanted - North America 0 23-03-10 11:33 PM
Intake piping Scooty814 Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning 0 10-09-05 12:13 PM
Aluminized piping for intake to the turbo, safe? JABM Saab 9-3 & NG900 Performance, Mods & Tuning 3 15-03-05 09:00 PM
Intake piping Sacko Saab 9-3 & NG900 Performance, Mods & Tuning 47 18-02-05 12:14 AM
Pre-turbo intake piping 96Turbo Saab 9-3 & NG900 Performance, Mods & Tuning 7 19-01-05 04:31 PM
