cross flow intercooler - SaabCentral Forums
Old 23-11-11
96saabse's Avatar
96saabse 96saabse is offline
My Saabs: 99 93 vert, 94 9000 aero
Exclamation cross flow intercooler
So i have a cross flow viggen intercooler on its way with all the plumbing i need.. My car is a 99 9-3 vert 5 speed.. Saabsport exhaust, intake.. WIll i see any difference over stock intercooler??
Old 23-11-11
KaMiKaZi_t0M's Avatar
KaMiKaZi_t0M KaMiKaZi_t0M is offline
My Saabs: 93 C900T vert, 95 9K Stg3+, 96 GOOSE
If you're car is untuned, then no. That intercooler is really needed when the turbo is producing more boost, and up in the RPM's, becuase these small turbos turn into hairdryers.
Old 23-11-11
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is offline
My Saabs: Black on black '97 Saab 3-door SE Turbo
You will see some more power as the outside air temp decreases, but in the spring those increases will go away... Ron
Old 23-11-11
96saabse's Avatar
Soooo... with the mods i have will the taliaferro stage 1 ecu make a big difference? Or should i go another route? Suggestions? My goal is to have a car that will walk new stock gt's, 350z's, etc.... What other mods do i need??? Thanx alot guys!!!
Old 24-11-11
bogan's Avatar
bogan bogan is offline
My Saabs: 97 900se Talladega stage 5
Garage
Your gains will be minimal, But you wont loose as much power thru heatsoak.
Your IC upgrade is not to gain power. It is to prevent loss of power.
B.L.T.H.....Brake late Turn hard
Old 24-11-11
Jeremy R.'s Avatar
Jeremy R. Jeremy R. is offline
My Saabs: 1997 900SE Talladega coupe
I thought that just adding a cross-flow intercooler (Viggen, in my case) added quite a bit to the car. It felt a little more powerful, and the turbo spooled up faster. At the time, it was $300 well spent. They used to say that a Viggen intercooler was worth 10 to 15 hp. The Sport Exhaust was supposed to be good for another 10 or so. The intake's another thing that gives you noticeable improvements. Replace the intake pipe with a piece of 3" plastic sewer pipe from Home Depot or Lowe's. If you haven't done it already, the aluminum elbow that bolts onto the throttle body has a very sharp edge where it connects to the rubber sleeve. Smooth that down with a Dremel tool so the air has a smooth transition from the rubber sleeve to the aluminum elbow. The way it's made, the air hits a sharp edge and it introduces turbulence. Your throttle response will be much smoother after this mod. That and the 3" air box mod were the two cheap things that everyone did to their NG900 when I bought mine 10 years ago.
Old 24-11-11
bogan's Avatar
Garage
Yeah, I agree
Old 24-11-11
BobSaabit BobSaabit is offline
My Saabs: '97 NG900 'vert; '03 OG 9-3 'vert
I agree too... I think the turbo silencer will come out when you change hoses for the new IC, but if it doesn't, be sure to pull it.
If you're creative, you can also "port match" the delivery pipe where it meets the TB. There's a sizeable mismatch there too.
Old 24-11-11
96saabse's Avatar
ok thats some good info.. ill do all the above. Anybody used the taliaferro stage 1 ecu??
Old 24-11-11
Not me, but I'd buy one with confidence. Nick knows his stuff well, few better.
Old 29-11-11
20009-3t 20009-3t is offline
My Saabs: 2000 9-3 2.0
Yes the silencer does come out with the new hoses, Spooling up sounds much better too...
Old 30-11-11
markyboy75's Avatar
markyboy75 markyboy75 is offline
My Saabs: 1999 9-3 turbo s stg 2
If you wanna reduce heat soak you could also remove your hood insulation. This also makes your bov nice and loud lol.
Old 01-12-11
Pontius DIO's Avatar
Pontius DIO Pontius DIO is offline
My Saabs: 99' 9-3 SE GT2560 62 Trim Comp.
That Stage 1 with the cross-flow intercooler is said to make 10 more HP on the description on Taliaferro's site. Totaling at 230 HP. Otherwise, it'll make 220 HP. When the car is cold, HP won't be much different as heat isn't high. Please update with how the car runs with the Stage 1 as I was looking to purchase this as well after winter and some sensors have been replaced. In my case, $100 for 25-30 HP is a good deal as I have the 200 HP variant.
Is there a turbo silencer on 99' SE models? I haven't seen one. Is it only on the lo HP turbos? Also, you can reposition your blow-off valve downwards (disconnect from intake, plug intake) or add some hose to it to redirect where the sound travels as well as exaggerate it's overall sound by getting creative.
Old 01-12-11
Messinian900S's Avatar
Messinian900S Messinian900S is offline
My Saabs: 1995 900SE white 3-door
If you have a HOT car (205hp) then you do not have a turbo silencer. its only on cars that didn't that didnt have a xflow IC, but yours does.
-David
Similar Threads
Wanted: Hoses for Turbo (T25) to Cross-flow Intercooler galaendewagen Parts for Sale/Wanted - North America 5 11-03-12 01:30 PM
For Sale: 2001 9-3 Parts - Doors, Gas Tank, Cross Flow IC Hoses w Rad Hose, Control Arms, +More brentjj Parts for Sale/Wanted - North America 0 20-11-11 09:36 PM
For Sale: JZW Stage 3 for t5 and cross flow intercooler with hoses dangit Parts for Sale/Wanted - North America 5 28-10-11 09:31 AM
x-flow intercooler screamingreen97 Saab 9-3 & NG900 Performance, Mods & Tuning 6 24-04-07 06:22 PM
WHY does my car have a cross flow IC? Palmer1980 Saab 9-3 & NG900 Performance, Mods & Tuning 8 07-05-06 03:50 PM
