slow drivers window - SaabCentral Forums
Old 14-11-11
kev999 kev999 is offline
My Saabs: 95 se estate
Cool slow drivers window
hi
my 1999 95 estate drivers window is slow and does not shut right up ,it leaves a small gap on the top left of the window.could this be a problem with the little green rollers????
regards kev
Old 14-11-11
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
Yes green rollers...
Old 14-11-11
Norm95 Norm95 is online now
My Saabs: Buick Verano Turbo 45mpg,9-5 lll 44 mpg
Does the window make a smooth sound going up and down or down it sound like it's going down a rough road?
Old 14-11-11
rayodunne rayodunne is offline
My Saabs: 2000 9-5 Wagon 2.3t 5spd
If you do the rollers also check the rubber in the tracks as I found one on each door laying down in the bottom of the door. I used double sided sticky tape to secure them back in. I also found that if you spray the tracks with silicon spray it helps with less friction as the motor ages.
2000 9-5 2.3t TD04, Aero ECU, Aero Rear sway bar, Viggen 17" Rims.
Similar Threads
slow power window motor fix? S900t8v Classic Saab 900 Workshop 12 03-05-13 01:52 AM
super slow rear left window S900t8v Classic Saab 900 Workshop 20 26-06-11 04:39 PM
Rear Window defrost-slow Anbl0301 Saab 9000 Workshop 4 11-01-09 02:54 AM
Window Channel - drivers window crwchf01 Classic Saab 900 Workshop 2 12-12-08 10:08 PM
Passenger Window Slow? zero2sixty Saab 9-3 & NG900 Workshop 3 23-02-08 02:00 PM
