B204L vs B204R - SaabCentral Forums
Go Back   SaabCentral Forums > Saab NG900, 1994-1998 and OG9-3, 1999-2002 & '03 Convertible (NG=new gen/OG=old gen) > NG900 & OG9-3 Performance, Mods & Tuning
NG900 & OG9-3 Performance, Mods & Tuning Covers Tuning & Performance modifications for the NG900 (1994 to 1998) & OG9-3 (1999-2002) & '03 Convertible
Old 1st November 2011
iNEEDaSAAB iNEEDaSAAB is offline
My Saabs: 1996 SAAB 900 SE auto
Default B204L vs B204R
I did a little searching, but nothing 100%.
From Wikipedia it looks like the 204L has less boost/psi than the 204R.
My question is, with a stage 1 tune on a 204L will i be at the same chp/whp as a 204R with the same tune?
BobSaabit's Avatar
BobSaabit BobSaabit is offline
Saabista
My Saabs: '97 NG900 'vert; '03 OG 9 'vert
First, the only year that will have a 204R is the '99 9-3 "HOT". After that the 9-3 uses the 205 motor. I believe the '99 204R was done entirely with an ECU tune.
So, to answer your question... yes, you could tune a 204L to have the HP of a 204R. In fact, it would perform better than a 204R since Saab leaves torque caps in place in their tuned engines and you won't get as much boost as fast with a 204R as with a stage-1 tune.
Sounds good, and your right, i'm comparing a 97 900, to a 99 9-3. i'm just wondering if i should hold out for a 99 9-3, since it comes with 15 more hp stock, i didn't know if that mattered after i tuned it.
edit: so ya, excuse my ignorance, but on jzw's site. stage 1 says +40hp. so i'm wondering if it'll be 185+40? as apposed to 200+40. or if the tune will bump a 204L to stage 1, 204R levels.
BobSaabit's Avatar
Saabista
Makes little difference. You can do a little tuning and get to the same place. Most of the guys around here would tell you that the HOT tune in the 9-3 is irrelevant. Given the choice, I'd go with the '99 9-3, but that's not based on the motor.
ok, so why a 99 9-3 then? is it that much better than a 900?
AZR Racing AZR Racing is offline
My Saabs: 1997 saab 900se
Garage
i own a 97 900, and back when it had a stock turbo, what little money i put in it, well it flew. i have literally beat the crap out of this car (although kept up on maint) and it takes every bit. never left me stranded, ever.
900 SEC 2.xT, custom 3inch exhaust, GT35r BB turbo, custom log manifold, tial Q bov, autometer phantom boost,oil,WB, JZW full custom tune, siemen 60# injectors, aeromotive 340 intank, want fried rice?
Old 2nd November 2011
BobSaabit's Avatar
Saabista
Please note that I own a '97 NG900. Nothing against them, they're great cars, but in general, I'd always opt for the newer car due to less corrosion and aging.
Also, on the 9-3
- Hydraulic Clutch
- Hydraulic top if we're talking 'verts
- wide selection of lowering springs (only one for NG900... perhaps two if you could pull off a direct euro order to Eibach).
- many parts interchange through 2002/2003 so newer replacements are available at the junkyard
- steering wheel audio controls
- revamped security system, no radio codes
- adjustable speed intermittent wipers
On the downside, the 9-3's have SIDs and ACC units that eventually need repair.
kennygee's Avatar
kennygee kennygee is offline
My Saabs: 2001 93
+1
And why no T7 love?
BobSaabit's Avatar
Saabista
Originally Posted by kennygee View Post
+1
And why no T7 love?
He's looking at a '99 9-3.
TwinCam TwinCam is offline
My Saabs: '99 9-3
+1
And why no T7 love?
Because T5's rock
mike saunders's Avatar
mike saunders mike saunders is offline
Saabista
My Saabs: Tuned NG900, stock 99 9-5
+1
And why no T7 love?
T7 engine management is great...
The engines themselves, not so much.
97 NG900 SE, B234R, GT3071R, (~340 WHP, 400 WTQ)
RIP: 99 9-5 SE, B234R, stock commuting sled
Family's past Saabs: 84 C900T, 86 C900T, 88 C900 8V, 89 9000T, 90 9000 NA, 91 9000T, 97 NG900T (2), 99 9-5 SE (2), 04 9-5 Aero
lowbudgethero's Avatar
lowbudgethero lowbudgethero is offline
My Saabs: 2x 1999 saab 9-3se stage 3
Garage
This comes up often, the engine itself is not different but 3 things make it different
ECU tune (17psi limit which is good for MBC people), viggen style intercooler, and a stiffer wastegate actuator. If you have MBC set to 15 or 16ish you'll be pushing 220-230hp
personally I just like the trim of the SE HOTs anyway and i like to be well within safety limits of the stock pistons ie (T5)
2009 BMW 135i, 2x 1999 saab 9-3se HOT both are stage3, 1986 Honda Interceptor, 1998 BMW M roadster (RIP), 1993 audi 90cs (sold), 1992 dodge dakota (sold)
BobSaabit's Avatar
Saabista
I used to be an MBC fan due to cost, but you can buy a stage 1 ECU from Genuine Saab for this for $100 now so that's a much better choice IMO.
MyGreenMachine's Avatar
MyGreenMachine MyGreenMachine is offline
My Saabs: 9-3 Conv
Amen to that! although I've been stranded. . . .faulty alternator
kennygee's Avatar
My Saabs: 2001 93
Oh.
Originally Posted by TwinCam View Post
Because T5's rock
Oh.
Annnnd oh.
Damn the ecopower.
Because T5's rock
pretty much
been looking for a new car, i am not very mechanically inclined so i was looking at something that is somewhat easy to upgrade. T5 seems to be where it's at.
Old 3rd November 2011
BobSaabit's Avatar
Saabista
pretty much
The only real differences are:
1. If you plan to go up over 300HP
2. If you want to by a T5 ECU from GS for $100 vs. (typically) more for other T7 tunes
Other than that, I don't see a big difference in tuning, except that you can get a newer T7. You do need to be selective or check to make sure there's no sludge problem.
Old 6th February 2013
matt_bullock matt_bullock is offline
My Saabs: 99 9-3 HOT, 96 900 SE
i just want to confirm that the internals on the B204L and the B204R are the same. i have a 96 900 and have read they can take a beating in terms of hp. im thinking of buying a 99 9-3 hot as either a parts car or to fix up, i just want to make sure that engine can take the same amount of abuse. thanks guys this forum has helped me so much since ive gotten my 900.
Old 7th February 2013
rabbit's Avatar
rabbit rabbit is offline
My Saabs: 2002 Vig BCB Stg2+
Yes!
Also I your in need of a tune, I've got 10% off tuning coupon code out there. It's 'fuknsweet'. Use it at checkout!
Sent from AutoGuide.com App
My Vig >> 345ftlbs 300hp <<
Old 11th February 2013
Garage
Depends. If that 99 is a t7 they are different pistons and rods.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
How to I know if I have the B204R or the B204L serenity_music_life NG900 & OG9-3 Workshop 3 5th August 2011 12:44 AM
1999 9-3 se b204r p $2600 DubChub Cars for Sale - North America 0 29th December 2010 12:12 PM
For Sale: B204L head p&p'd wannaB Parts for Sale/Wanted - North America 4 13th September 2010 08:30 PM
Wanted: 99 B204L redtop for 9-3S redciv1 Parts for Sale/Wanted - North America 3 30th August 2010 07:38 AM
WANTED: B204R engine neutron Cars for Sale/Wanted, Parts for Sale/Wanted - Rest of World 0 22nd February 2010 06:59 PM
