Universal Sway Bar Bushing Replacement - Page 2 - SaabCentral Forums
Old 21-01-12
Phikshin Phikshin is offline
My Saabs: Saab 93
Did these on mine this morning. 04 Arc. Mine were in much better condition than yours and just made a creak when its cold over larger dips in the road. The bolts that go in the front of those brackets (the front of the engine) you can get with a ratchet and a deep 13mm. The rears you just need to loosen a few turns then push on the sway bar and they slide out. Its a bit finicky but easily do able.
Old 21-01-12
Ilya's Avatar
Ilya Ilya is offline
My Saabs: 2006 Saab 9-3 2.0T
Hey guys! Quick question. I have a 2006 Saab 93 2.0T. Which size would I need? I plan on replacing these along with my Sway Links at the same time! Thanks ahead of time! And how easy are these to do?
Old 21-01-12
IAmTodd's Avatar
IAmTodd IAmTodd is offline
My Saabs: 2006 9-3 Aero VTuner Stage 0
I believe they use a 24mm bar.
Old 22-01-12
Ilya's Avatar
So when I go to AutoZone just ask for 24mm sway bar bushings?
Old 23-01-12
EuroStyle's Avatar
EuroStyle EuroStyle is offline
My Saabs: 2006 9-3 Aero Convertible 2.8TM, Vtune 0
Since you only loosened the back set of bolts, does this mean you used the OEM brackets with the new poly bushings?
Sean
2006 Saab Cars, N.A. "Top Gun"
Saab Aero Academy Alumni
Old 23-01-12
Ilya's Avatar
I can't wait to do this repair. I plan on getting new brackets and bushings. Feels a little better.
Old 06-02-12
JHZR2's Avatar
JHZR2 JHZR2 is offline
My Saabs: 2004 9-3SS 2.0t (MT)
So does the subframe need to come down or not? Mine is FWD. My suspension is silent except over speedbumps and similar situations when below freezing. Greasable is nice...
A little worried this will not fix it, I had them done a few years back and was suprised to hear the crunch (no pop or anything like that, just a crunchy noise) this weekend out in the cold...
Old 06-02-12
kanundrum's Avatar
kanundrum kanundrum is offline
My Saabs: 2011 Saab 9-4x
Mine was replaced (Forgot to ask if the subframe had to come out or not) and it didn't make much diff. I still get crunching noises in compression and rebound.
New Whip 2011 9-4x Aero XWD
My TurboX 02/08/2009 - 8/26/2012 RIP
3" Downpipe and Midpipe: http://www.youtube.com/watch?v=wZ3nPLrEeRk
Old 06-02-12
derekwilkinson derekwilkinson is offline
My Saabs: 2006 Saab 9-3 2.0T JZW Stg 3
One of my sway bars was loose and caused a bit of noise... but the best thing to get rid of the noise, and especially the crash, was no struts/springs
BSR Intake, JZW Stage 3 Tune, Magnaflow Muffler, Tinted Windows, GS Strut Brace/Bushings/Downpipe, Koni Yellow Struts, Vogtland Lowering Springs, 25mm H&R Rear Spacers, Custom Leather Dash, Galaxy Tab 7, Hardwired V1, Boston Acoustics SE35, Sony Xplod 6x9s, Infinity Reference 6.5", Dual Kicker Comp 12"/Planet Audio 2500W Amp = Awesome
Old 07-02-12
Jplipper's Avatar
Jplipper Jplipper is offline
My Saabs: 2004 9-3 SS Linear
Anyone think it could be the subframe bushings making the noise? Im about ready to give up and live with it
Old 07-02-12
kanundrum's Avatar
Im replacing my endlinks just for giggles to see if that makes a diff. will let you know. I get that crunching sound. seems to go away when its not cold though.
Old 08-02-12
zinfandel's Avatar
zinfandel zinfandel is offline
My Saabs: 04 9-3 Aero SS, 08 9-3 Aero SC
Hmmm... eeuoroparts list both 24.2 and 25.2 as the correct bushing for a 2004 Aero SS. Anyone know which is correct?
http://www.eeuroparts.com/main/parts...tcategory=2130&
Currently 2004 Aero Expresso Black and 2008 Aero SC Fusion Blue. I have owned
2000 900T ,1996 900S , 1972 SAAB Sonnet, 1986 900S,1978 99T,1975 99 Hatch,1973 99 .
At least one SAAB in the household since 1973
Old 08-02-12
kanundrum's Avatar
You have to look your car up in EPC to find out. FOr a 04 I would guess 24mm though
Old 09-02-12
IAmTodd's Avatar
Aero should have the larger bar.
Old 10-02-12
zinfandel's Avatar
OK, I have the poly grease fitting bushings on their way.
But no one seems to talk about the rear bushings (19MM?) and whether they should be replaced. I know I don't hear any noise that I think comes from the rear.
And since we are in a suspension thread, do most people replace the strut bearings when replacing struts (107K miles on my 2004 Aero)?
Old 10-02-12
zinfandel's Avatar
Bump, need to make a decision on whether to buy more parts for the suspension overhaul
Old 11-02-12
kanundrum's Avatar
front endlinks should be good for the overhaul as well. Im about to change mine out tomorrow.
Old 05-05-12
meisme33's Avatar
meisme33 meisme33 is offline
My Saabs: 03 9-3, BSR Stg 1, Optiflow, FSDs
Garage
I guess I'm still a bit confused how to solve the loud creaking over speedbumps from the front suspension. I thought it was going to he be control arm bushings, but I just had those replaced with the GS uprated ones, and the noise is still there. The mechanic said my springs and strut mounts were in good shaped when my new struts went in... Sway bar bushings next? What else do I need to look for?
Sent from my Autoguide iPhone app
Old 05-05-12
kanundrum's Avatar
I have replaced the sway bar bushings first and my noise is still there (sounds like your noise as well).
The tech at my local dealership told me he things my Stock Shocks are going.
Old 05-05-12
meisme33's Avatar
Garage
In my case I just put in new Konis. Maybe my springs are going?
Similar Threads
Bushing replacement help cobra989 Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 2 02-02-11 01:56 PM
Control Arm Bushing Replacement Maineguy Saab 9-5 Workshop 3 03-11-10 05:18 PM
GM Major Guard - Sway Bar Bushing ? d4rkf1br Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 3 22-01-10 06:09 AM
sway bar bushing change baseballfan Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 15 13-05-09 06:42 PM
Front end noise... sway bushing? bcroft Saab 9000 Workshop 10 24-05-08 06:45 PM
