Height (Spring) Survey - SaabCentral Forums
Old 22-10-11
BobSaabit BobSaabit is offline
My Saabs: '97 NG900 'vert; '03 OG 9-3 'vert
Default Height (Spring) Survey
We get a lot of questions about actual height of various spring combinations, so I thought I'd start a thread to document heights.
We need to know the measurements shown below from ground -> hub and to ground -> fender lip in order to figure out where various combinations of model & spring will sit. It's really the difference that counts in evaluating where the springs make you sit, so do the subtraction if you like. Measure just to the bottom of the sheet metal for the Fender lip and do your best to get hub center right. Accuracy within 1/8" would be good for us.
What model and MY is important along with age since springs tend to drop... especially new installs. If you actually have info like Saab spring color codes feel free to add that or any other details in you think are important. Those who cut coils obviously need to add that in. Add a side photo if you want. Tire specs might help with understanding any funky ground to hub measurements.
I'll add my own info in the post following this. Put your rough vehicle specs in the subject to make it easy to search the thread. Here's the diagram:
Old 22-10-11
Default '97 NG900 SET 'vert & 2003 9-3 SE 'vert - Stock Springs
Spec for a 1997 NG900 SET Convertible, and also my 2003 9-3 SE Convertible. both with stock springs (they are almost identical in height). Roof closed in both cases. One is on 205-55-16's, the other on 215-45-17's, both at 35lbs.
Stock Springs:
FH - 11.75"
FF - 26.125"
Net Front Spring Height (FF minus FH): 14.375"
RH - 12"
RF - 26.75"
Net Rear Spring Height (RF minus RH): 14.75"
Old 22-10-11
markyboy75's Avatar
markyboy75 markyboy75 is offline
My Saabs: 1999 9-3 turbo s stg 2
Will post mine in the morning m8
Old 22-10-11
From my buddy's 2002 Viggen 'vert, stock 245-45-17 tires, no mods:
Stock Viggen Springs:
FF = 11.5625
FH = 25.975
RF = 11.975
RH = 26.375
Net Rear Spring Height (RF minus RH): 14.437"
Old 23-10-11
Kei's Avatar
Kei Kei is offline
My Saabs: 1995 900 SE stage 3 @ 181k
Garage
1995 NG900 SET 5 door with eibach springs fitted just over 1 year ago. Tyres are 225/45R17. (boot is laden with amps, sub, spare and toolkit, fuel tank is at 1/4")
FH = 11.6" (295mm)
FF = 24.8" (630mm)
Net Front Spring Height (FF minus FH): 13.2" (335mm)
RH = 12.4" (315mm)
RF = 25.2" (640mm)
Net Rear Spring Height (RF minus RH): 12.8" (325mm)
Old 23-10-11
900Talladega's Avatar
900Talladega 900Talladega is offline
My Saabs: 1998 900 S Talladega
Ooooh this will be interesting
My NG900 (Currently in for smash repairs D: ) Has a full set of Koni/Vogtlands that are only a couple of months old.
Will post measurements when it gets back hopefully this week.
- Saab 900 S Talladega B234I
Old 23-10-11
jakejm79's Avatar
jakejm79 jakejm79 is online now
My Saabs: 1999 9-3 Convertible
1996 900SE 2.0T, Koni's, Vgotlands (rear cut 1/2 coil) & 215/45R17 tires.
FH: 11 7/8"
FF: 24 5/8"
Net: 12 3/4"
RH: 11 7/8"
RF: 24 3/4"
Net: 12 7/8
Old 24-10-11
markyboy75's Avatar
1999 9-3s on standard springs, wheel size 195 60/R15 88V. Both wheels on 34 psi.
FH 11.4
FF 26.0
Net 14.6
RH 11.4
RF 26.5
Net 15.1.
Should be a lot lower with the 3 kids and the dobby in the back lol.
Last edited by grkguy89; 25-10-11 at 10:32 AM. Reason: uhh there was a format to follow
Old 24-10-11
markyboy75's Avatar
Shouldn't everyone's ground to hub measurements be the same, depending on wheel size and tyre pressure. Mine is 11.4 front and rear. Sorry if I'm wrong on this one lol.
Old 24-10-11
jakejm79's Avatar
Mark you are correct, they should be the same, assuming same size tires and PSI (front to back). It is possible that the front or rear is under more/less load causing the tire to 'squish' a bit. But differences of almost an inch seem questionable.
Old 24-10-11
markyboy75's Avatar
That's what I thought lol. I mean mine is totally standard at the moment, even my wheels are only 15's for now. Only thing in my motor with any weight on it would be my fusion sub and amp. So shouldn't make a difference on tyre depth. But an inch is more than questionable I think lol
Old 24-10-11
happyeds happyeds is offline
My Saabs: Viggen Conv.
Default Viggen Conv ride height
2001 Viggen convertible, changed suspension at 66K miles, stock verses Eibachs Pro & Bilstein Sports - Ride height (w/1/2 tank fuel) stock FF 26", RR 26.75" - w/Eibachs FF 25.50", RR 25.50" Ride is actually more civilized, and control is a little better. Not as much dive on stopping and weight shift in corners is not as pronounced. A very good daily driver combo for those not wanting to mess with making adjustments to shocks. Personally Bilstein does the research for what is best for your ride and we benefit by it. Bilstein fronts PE3-3105-H0 and rears are BE5-2758-H0. The Eibachs are 7807.14
Old 24-10-11
But if there are different wheels/tire combo's fitted, or different inflation pressures, or new vs. very old that could definitely have an effect... Even without oddbal sizes you could easily see a variation of 1/2 inch. That's substantial when we're talking spring height changes of roughy an inch range.
We could actually just go with the hub center to fender height, but it's nice to get an overall view, especially if there's a photo to look at.
Old 24-10-11
markyboy75's Avatar
I see your point m8, I'll try and post a side on pic of mine when I get the chance.
Old 24-10-11
falcon21's Avatar
falcon21 falcon21 is offline
My Saabs: 1996 SAAB 900 SE 2.0t
I should measure all my spring heights, I think my car sits slightly on an angle.
What is the standard tire aspect ratio for the stock 205 R16 rims? I have 205/50R16 tires.
96 SAAB 900 SE 2.0t
Old 24-10-11
jakejm79's Avatar
I see your point, I guess I just rotate my tires and replace 4 at a time, so the wear should be even. I think Marks point (and mine too) was that each car should have the same hub to ground measurement for front vs. rear, i.e. unless you are running heavily worn tires at one end or different wheels/tires on the front vs. the back the radius (which is effectively what the FH or RH measurement is) should be the same on the front or the back.
Not that all our cars with the same size wheels should have the same measurement.
Old 24-10-11
I think inflation and load makes a big difference there... my car has equal pressure and brand new tires all around but it's got 1/4" variation in ground to hub height. Same for my friend's Viggen.
Old 24-10-11
jakejm79's Avatar
I agree that there can be a small difference can be attributed to load and tire pressure, but for example Kei's is 0.8" (20mm) difference.
On a sidewall that is only meant to be about 100mm (225*45%) tall that is a significant difference front to rear.
Old 24-10-11
markyboy75's Avatar
You said exactly what I've been thinking lol, I just couldn't think how to word it without coming across as being offensive. But that's my point bob. Cheers Jake.
Old 24-10-11
Kei's Avatar
Kei Kei is offline
Garage
Part of the difference there may be down to the fact i've got different tyres on the front axle vs the rear. The fronts are also newer with about 8mm of tread vs the rear only having just under 6mm. The tyres should be evenly inflated to 30psi. I did measure mine on a slight hill which may well make some difference. (car facing down it)
Similar Threads
Using SAS spring spacers to correct rear ride height c900 Classic Saab 900 Performance, Mods & Tuning 5 20-09-10 09:27 PM
This damn spring!!!! - Brak Caliper Spring Nightmare! Saabboy93se Saab 9-3 & NG900 Workshop 1 17-05-10 02:39 PM
Suggestions needed: To spring or not spring....that is the question. PaneraiGuy Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning 19 02-06-06 11:49 AM
Spring replacements and the saab spring compressor muhawalter Classic Saab 900 Workshop 6 08-08-05 05:08 PM
JD Powers survey jangler64 Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 2 29-07-03 01:02 PM
