Submission for NOVEMBER'S Saab Of The Month - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Of The Month > SOTM Submissions & Voting
SOTM Submissions & Voting Submit your car for voting & vote for your favorite Saab.
Old 21-10-11
grkguy89's Avatar
grkguy89 grkguy89 is offline
Moderator
My Saabs: 97 900SE, JZW Stage HX35 w/m injection
Garage
Default Submission for NOVEMBER'S Saab Of The Month
The rules are posted in the sticky in the main section for SOTM Submission & Voting
(here's the link just in case; http://www.saabcentral.com/forums/sh...d.php?t=217629 )
Try to keep a similar style format
Open for entrants!!!! Will close on the 26th
follow this template
***EXAMPLE***
The Silver Sled (1988 900 Aero)
Specifications
Engine
Brand new Saab B202 2.0 Litre 16 valve crate engine (installed November 2010)
Rebuilt Bosch distributor
Stock Bosch electronic ignition
SPG9 AID (Advance Ignition Diaphragm) with timing at 20˚BTDC
Bougnicord spark plug leads
NGK BCP7EV plugs
Aquamist 1S water Injection using 0.9mm injector
Aquamist DDD (digital dash display) for water injection output
Crank case ventilation catch-can
Exhaust
2.5 inch from cat converter back with hi-flow racing cat
4 inch chrome semi-oval tip
Hi-flow dynomax stainless steel muffler and rear resonator
3 inch JSP stainless steel split down pipe off turbo to cat
Turbo
Mitsubishi TE-05 16G: with 16G compressor wheel with 10˚ clipped vanes, upgraded thrust and is rated as a 300HP turbo
Wastegate running 7psi base boost
Stage 2.5 SPG9 APC running to 18psi boost
Jak Stoll Performance Talon high-flow side mount intercooler
8 inch Davies Craig thermo pull fan mounted on reverse side of intercooler with manual switch inside cabin
Saab C900 1990+ aluminium turbo intercooler ducts
Stratmosphere Forge bypass valve
K&N filtercharger
Plastic intercooler top air dam
Fuel System
Bosch 3.0 BAR fuel pressure regulator
Trionic 5 34lb injectors
Jak Stoll Performance Stage 2 ECU chip
Fuel pressure gauge situated in-line on fuel rail
Suspension
Stock Saab Aero springs and shocks
Stock Saab Aero road handling kit including front and rear sway bars
Polyair inflatable air bags inside rear springs
Wheels & Tyres
16" x 6.5" Saab Super Aero rims
Goodyear Revspec Ducaro 205/50/16 tyres
Other
Stock Saab Aero factory whaletail
Saab Aero vent covers (factory colour coded silver to match duco)
AutoMeter 30"hg to 30psi boost guage
AutoMeter air/fuel ratio guage
Saab factory rear decor panel
SaabSavior short shifter
Saab Momo leather steering wheel
3.5mm blue silicon vacuum hose
Saab Aero original Alpine surround sound 5 speaker stereo
Aero kit factory colour coded silver to match duco
Output
Estimated 190kW (250hp) at front wheels (need to do another dyno once new crate engine is run in)
Christos (VA saab meet pm me?) JZW Tuned Stage 7
http://www.eurocarswmbg.com/
Old 21-10-11
Manick Manick is offline
My Saabs: Saab 9-5 aero MY01
Garage
The red SW sleeper.
Engine
Rebuilt B235R engine complete with new bearings (summer 2010)
Forged Wössner pistons
B234E camshafts (saab T5)
AEM Dryflow air filter
Modified arifilter box for better air flow
Transmission
5 speed manual transmission completly rebuilt and upgraded summer 2010.
Quife LSD Diffrential
Spec stage 3 sinter clutch
Exhaust
3" downpipe
Race cathalyst
2,5" catback system from Simons exhaust.
Turbo
Mitsubishi TD04HL-19T turbo
#6 exhaust housing
Large intake pipe from Aero MY06->
Aluminium Intercooler from KL racing at stock position, FMIC from Forge is orderd.
Fuel System
750cc RC engineering injectors
Nuke Performance Fuel rail
Nuke Performance adjustable fuel pressure regulator @ 3 bar
Aeromotive Stealth fuel pump @ 340 liters / hour
Russel high flow fuel filter
Suspension
GE motorsport springs and shocks ( lowers 40mm)
Powerflex bushings in the whole chassi
Front strutbrace
Wheels & Tyres
17x7" Aero original three spoke with 225/45/17 bridgestone potenza tires @ summer
17x7" Aero original three spoke with 205/50/17 Pirelli Pzero Corsa R-tires for track day
16x6,5" Mille miglia 5 spoke with 205/55/16 Nokian Nordfrost tires @ winter
Brakes
EBC rotors, drilled / cut
EBC Greenstuff braking pads @ Front
Ferodo DS2500 braking pads @ rear
Other
T7 software designed by my self with T7 suite.
Auber instruments exhaust temperature gauge
Innovate LM2 wideband lambda sensor
Output
Estimated power at the time of writing: 375bhp / 530nm torque.
Old 21-10-11
MR.SAAB's Avatar
MR.SAAB MR.SAAB is offline
My Saabs: custom JZW tune 2005 9-3SS Linear
Honda eater.
Engine
GM's 2.0 liter ecotec
Exhaust
JT - 3 inch turbo back catless
Turbo
Garret GT2525
BSR intake
Custom turbo block off plate
Vibrant synapse Synchronic Blow off valve with an HKS style flange
CX racing front mount intercooler
Fuel System
9-3 Aero injectors (Green)
Suspension
Adjustable Koni Yellow struts and Shock absorbers
KAW racing springs from an Opel Vectra 45/55mm lower
Wheels & Tires
17" Sparc0 Assetto Garra 5x110 bolt pattern
Goodyear Eagle GT tires
Brakes
Calipers painted Gold with G2 caliper paint
Front: EBC redstuff
Other
JZW stage 3 tune
Sprint booster
Carbon Fiber pillar covers from State of 9
Infinity Kappa speakers
HID fogs and headlights
Aero Front spoiler
Genuine saab oil cap and brake cap
Output
JZW claimed 250hp and 280ft/lbs
jzw stage 1 tune, Bsr optiflow intake, SPRINT BOOSTER for auto tranny, led headlight strip, tail light tint, prosport digital boost gauge, infinity speakers all around
Old 21-10-11
hksaab9321's Avatar
hksaab9321 hksaab9321 is online now
My Saabs: 2003 9-3 vector
Little t 9-3
Engine
B207L 2.0t
Exhaust
Ferrita 3" cat + Magnex backbox
Turbo
Garret GT2525
Simota Aero Form II intake
Forge Actuator Red Spring
Suspension
Koni Yellow Sports Suspension
Wheels & Tires
17" AVE 5x110
15mm rear spacers
Bridgestone MY-01
Brakes
Stock
Other
CF hood
CF door handles
CF sharkfin antenna
Perforated Coil Pack Cover
Custom Vinyl "Angry Griffin" logo badge
Rear de-badges
Output
Stock 175hp
Old 22-10-11
Bruno_S Bruno_S is offline
My Saabs: SAAB 93 SportCombi Aero V6
Little t 9-3
Engine
2.8 Turbo V6
Exhaust
BSR 2.5"
Tuning
BSR stage1
Suspension
H&R springs, 45mm
Wheels & Tires
Stock 18-inch Aero 10-spoke, painted matte black
Brakes
Stock , calipers painted matte black
Other
Front bumper from SP
Custom made headlights with black inserts and LED's.
6000K Xenon low beams
Patriot badges (Swedish flag behind the griffin)
Output
290 (?) hp
SAAB 93 Aero SportCombi 2.8T
Old 22-10-11
SaabNineThree SaabNineThree is offline
Banned
My Saabs: 2001 9-5 Aero
Mod list in my garage..
Engine
stage 3 tune
Exhaust
2.5 inch turbo back
Turbo
stock lol.
Fuel System
stock
Suspension
cut springs brah
Wheels & Tyres
tsw 18x8
Other
harrroo
Output
OVER 9000!!!!!!
Old 22-10-11
sab aero's Avatar
sab aero sab aero is offline
My Saabs: 88 900 Aero (Silver Sled), 02 9-3 Aero
Why not!
Specifications
Engine
NGK BCP7EV plugs
Exhaust
Turbo
K&N filtercharger
Fuel System
Suspension
Wheels & Tyres
Other
Output
1988 900 Aero "The Silver Sled"
2002 9-3 Aero Nordic Custom Stage 4
Old 23-10-11
grkguy89's Avatar
Moderator
Garage
sab you cant copy the example*********
lol
Old 23-10-11
sab aero's Avatar
lol
You can when you own the car
Old 25-10-11
ahfunaki's Avatar
ahfunaki ahfunaki is offline
My Saabs: 2003 9³ Arc 2.0T 6-Speed
No clever name - 2003 9³ Arc 2.0T 6-Speed
Specifications
Engine
BSR Optiflow Intake
Exhaust
Stock
Turbo
A'PEXi Twin Chamber Blow Off Valve
Fuel System
Stock
Suspension
H&R Springs
Bilstein HD shocks/struts
Eibach 15mm/25mm spacers
Wheels & Tires
18" Pontiac G6 GTP Wheels
215/45-18 Cooper Zeon ZPT
Other
GenuineSaab Short Shift Kit w/solid bushings
Aeroforce Interceptor Gauge
Thule/Saab Roof Rack
08+ Ice Tail Lights
Output
Not sure
SOLD! / 2003 Saab 9³ Arc 2.0T 6-Speed / H&R Springs / Bilstein HD shocks/struts /
18" Pontiac G6 GTP Wheels / Eibach 15mm/25mm spacers / BSR Optiflow Intake /
GenuineSaab Short Shift Kit w/solid bushings / Aeroforce Interceptor /
Thule/Saab Roof Rack / 08+ Ice Tail Lights / A'PEXi Twin Chamber Blow Off Valve ///
Old 26-10-11
xbriansg36x's Avatar
xbriansg36x xbriansg36x is online now
My Saabs: 2001 Saab 9-5 V6 Stage 3 :)
Red Rocket 2001 Saab 9-5 3.0T V6 Autobox
Engine:
K&N Custom Intake
Recirc BOV
Exhaust:
Magnaflow Cat
Ebay Euro Style Muffler
Turbo:
FMIC
Replaced GT15
Fuel system:
Stock
Suspension:
Eibach Lowering Springs
Wheels:
Yokohama S4 All Season Racing
Stock Rims
Other:
HID 6k Head/Fog Lights
Smoked Tail lights
Low profile lip spoiler
Alpine Type R powered by 1000 watt Kenwood
Pioneer DVD something or another in dash
Red Under doors
Color matched trim
20% Tinted windows
"SAAB Story" Euro plate
Red Calipers
Output:
Enough that I'm content for now
[IMG][/IMG]
Old 26-10-11
grkguy89's Avatar
Moderator
Garage
5 hours and 51 min left
Old 27-10-11
Banned
if another 9-3 wins im going to cry
Old 15-11-11
lockheedsaab7 lockheedsaab7 is offline
New Member
My Saabs: 2002 9-5 Aero
Garage
Kept it simple on the details.
2002 9-5 Aero
-Bsr full catback exhaust
-3" downpipe
-Stage 3 PPC
-Taliaferro high flow intake
-Forge Motorsport piston diverter valve
300+ hp
Old 15-11-11
handsomejackuk handsomejackuk is offline
My Saabs: 9-5 aero 98,000 miles light silver
nothing to say really,
Saab 9-5 aero
Yreg 2001 MY
1 previous owner, 111,000miles. owned by me for last 4 years
all completely standard other than surface mount led marker lights integrated in to headlights.
17 inch ronal alloys
like things as standard as possible.
Al...
Old 15-11-11
grkguy89's Avatar
Moderator
Garage
entries closed earlier this month....
Similar Threads
Submission for OCTOBER'S Saab Of The Month grkguy89 SOTM Submissions & Voting 15 27-09-11 12:02 AM
Submission for SEPTEMBER'S Saab Of The Month grkguy89 SOTM Submissions & Voting 19 10-09-11 04:09 PM
ugh! bad SAAB month valbowski1980 The Lounge 31 02-10-06 06:09 PM
Bad month for my saab... please help! jin Saab 9-3 & NG900 Workshop 6 05-08-06 12:01 PM
