Computer Update Question - SaabCentral Forums
Old 20th October 2011
BingoTap BingoTap is offline
My Saabs: 2004 9-5
Default Computer Update Question
My 04 9-5 ARC has a issue with transmission flare (rpm's increase and transmission doesn't lock up in next gear). I posted and someone mentioned they too had issues on their 04 and when they had the CPU software updated the issue was solved. I called the Saab dealer and inquired about a the most recent CPU software update as it pertains to the transmission and the tech had no idea what I was talking about. He asked if I had a tech or bulletin number. Any ideas how I can proceed to get the issue solved?
TyrannicalTy95's Avatar
TyrannicalTy95 TyrannicalTy95 is offline
My Saabs: '99 9-5 LPT;'00 9-5Aero(MT);'03 9-5 3.0t
It sounds like you're describing transmission slip. When was the last time you changed tranny fluid and how many miles do you have on current fluid? Has your tranny always done this? If not, doesn't really sound ECU-dependent to me...
The wife's '03 V6 was slipping lately, even though the dipstick showed good level and decent color. I did the 1st 3.5 qt flush last night with 3309 fluid, and was surprised how dark it actually was coming out of the bottom. It looked a bit like Willy Wonka's Chocolate River . Anyways, I took it for a spin afterwards and there was NO slip. I plan to do another 3.5 qt change tonight. Good luck.
My Saabs: 2004 9-5
Default Trans slip & Fluid change
I have just over 110K. I have only had the car since 104K. I don't know when trans fluid was changed last. Last week I had the sludge service done and the mech found the trans fluid was 1 qrt low but no leaks. He added dexronIII. I then ordered a case of Mobil 3309 and plan on doing the 3 flush change this weekend. Is it possible it is just the fluid and not the cpu? I guess I will find out.... Thanks
WHAT?! Your mechanic added DEXIII??? Yeah, my bet is the fluid!
Check your manual for fluid spec. 99-02 took DEXIII and 03-above take Mobil 3309 (same as Toyota Type IV). You need to flush ASAP with full 3x flush.
Hopefully there's no permanent damage from either low fluid or incorrect fluid, but I think you'll be OK. I would drain the first 3.5 qts tonight if I were you, and wrap up on the weekend. Remember to drive/mix in between so you're not just draining fresh fluid. Keep us posted .
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Any computer engineers can help me with a project relating to Simple RISC Computer? Ero The Lounge 0 26th April 2011 02:37 PM
RAM in the computer 900t The Lounge 33 1st August 2009 11:15 PM
computer help,,,,,sorry! Martin_9-5t The Lounge 12 31st August 2008 02:15 AM
questoin vectorX 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 0 21st March 2006 02:13 PM
EDC Computer to DCC Computer swap - Help! Bronco 9000 Workshop 23 2nd May 2004 05:23 AM
