An unusual problem that has me stumped!! - SaabCentral Forums
Old 11th October 2011
leebutcher leebutcher is offline
New Member
My Saabs: 9-5 arc estate
Default An unusual problem that has me stumped!!
Hi there
I am a newby so my apologies if this is a subject that has been done to death on here...please bear with me.
I have a 2002 9-5 estate, 2.3t petrol auto.
Anyway, i have recently bought this car and all seems good, it pull well and the gearbox seems to change up and down fine, there have been a couple of minor issues with the throttle body sensor but nothing to worry about.
I bought he car as a complete bargain as it had the engine management light on showing so I just reset the error code with my OBD11 and its all good now.
Anyway I am completely stumped by the following problem that was cured by the OBD reset but very occasionally comes back under specific conditions so would really appreciate some help.
The engine starts and runs just fine, the auto box engages just fine and driving is relatively smooth apart from the occasional knock from a worn suspension joint somewhere. However if during a drive wheel is spun, for example on gravel the Traction Control light comes on and stays on. From this point onward the engine is very reluctant to tick over and seems to go into a 'limp home' mode, however once the revs are up everything runs just fine again, but it does seem to use a lot more fuel.
its very strange...does anyone have any idea as to the cause?
when I bough the car the cruise control relay had been removed and placed in the glove box..I notice cruise control didn't work, replaced the relay fully expecting the dashboard to light up with a heap of warnings but it all seems to work fine.
I am pretty sure that the TC runs off the ABS sensors but there have been no brake system related errors reported at all and the brakes seem fine (though in need of replacement discs on the front)
Any ideas would be great as a friend wants to buy the car from me but is terrified of 'electrical problems'
please help.
regards
Lee
Pabllh Pabllh is offline
My Saabs: '02 9-5 2.3t - '00 9-3 Base
Welcome to the forum!
I have a Northampton (Massachusetts USA) 1/2 hour from me.
Sounds like a sensitive abs sensor and with the brakes needing to be done
I'd replace the front brake pads and rotors and see if the issue still exists. If so I'd suspect the sensor.
Good luck
Old 12th October 2011
Jssaab Jssaab is offline
My Saabs: 2000 9-5 320hp, 2003 Aero Hirsch "Clone"
Is it in Limp Home? Sounds like it... Check to see
Tags
engine malfunction light., tick over, traction control
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Any ideas on this unusual starting problem? Buffalo2003 NG900 & OG9-3 Workshop 4 8th August 2011 06:06 PM
Unusual problem Morg 9-5 Workshop 3 9th July 2009 12:19 PM
Unusual Radio Problem mrwiggles91 9000 Workshop 4 13th April 2008 11:45 PM
Unusual brakes problem - help! Rob Hill C900 Workshop 9 2nd May 2005 03:00 PM
Unusual Electrical Problem DrewBedelph C900 Workshop 3 3rd November 2001 07:21 PM
