Clutch bleeding procedure - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 29th September 2011
autoaddict autoaddict is offline
My Saabs: 1989 9000 CDt & 1983 900t 3dr
Default Clutch bleeding procedure
So I'm looking at buying a 92 9000t with a new clutch master cyl. recently installed. The owner says he spent very little time trying to bleed the clutch system, but he could not get any pressure at the pedal. (I'm a licensed mechanic and so is he) Does this system require back bleeding or pressure bleeding or just more time conventionally bleeding. Thanks. (It was a new unit and i don't know if he bench bled the master first)
chengny's Avatar
chengny chengny is offline
My Saabs: 96 9K CSE, 97 9K CS, 96 9K CS, 94 9K CSE
Purging the air out of the clutch hydraulic system is frequently a real pain. Mostly this is due to the fact that the amount of hydraulic fluid displaced by the master cylinder per stoke is tiny (compared to the master cylinder in the brake system). Maybe the location of the tap point and slope of the tubing leading down to the slave play a part as well _ I never thought too much about it.
Anyway, whatever the reason, it's not like bleeding your Brakes.
Generally, the conventional method (i.e. using the master to displace the entrained air) does not work for most people. If it does work, it requires a lot pedal pumps. And that is if the master is tight like new.
Purge from the bottom up. By that I mean find a way to supply pressurized brake fluid backwards through the slave bleeder. This will push the air and old fluid out of the slave, up the actuating line, through the master and then finally it will bubble up and escape in the reservoir.
The pressure need not be great - the master is designed to allow back flow when the piston is not being stroked in. Just get a length of tubing that fits snugly over the slave bleeder. The other end goes on your pumping device. That could be anything - a manual/thumb powered oil can, a grease gun, or a small positive displacement pump. Probably a turkey baster would work if you could find a tight one.
There is not much fluid to displace only the recesses in the slave cylinder and the volume of the tubing. By the time the air gets into the master it really has nowhere to go but bubble up and out.
That's all I can offer - I haven't bled a clutch in years. But do a search; I'll bet you'll find some much better suggestions.
Thanks for the prompt response! I was leaning towards the back bleeding method-common to Volvo liquid actuated clutches. I'm gearing up a windshield washer fluid pump as we speak to take on the task. Thanks again...I love this site! Great people offering solutions rather than more questions. Thanks again, Cheers!
benji9k's Avatar
benji9k benji9k is offline
My Saabs: 1992 9000 2.3L Turbo
When I replaced the master cylinder I bled it the manual way, one guy on the pedal, one guy on the valve. It's not the easiest, but it got the bleeding done in 15-20 min.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
9-5 clutch replacement procedure dmtinker 9-5 Workshop 42 17th February 2015 09:03 PM
Bleeding of clutch fixed problems, but few days later clutch is dead lorkp C900 Workshop 9 18th April 2008 06:23 AM
'88 900 Clutch Replacement Procedure? jbag C900 Workshop 33 17th August 2006 07:52 PM
clutch bleeding rklemm C900 Workshop 22 7th January 2006 05:50 PM
Bleeding the brakes, replacing fluid....easy procedure? step jonnycake C900 Workshop 7 16th April 2004 12:08 PM
