Damn torx screw - SaabCentral Forums
Old 29th September 2011
Adamskii Adamskii is offline
My Saabs: 1999 93
Default Damn torx screw
Hi,
I am slowly getting through replacing the lower control arm on my Saab 93 1999. The Haynes manual says it is a two spanner job, so I thought I would have a go myself (although I now realise my mechanical skills are 1 spanner! )
Anyway I am down to the torx screw and when trying to remove it (using a torx 50 size) I made a bit of a mess of the head.
Can anybody tell me what the correct size for this bolt is? 55 seemed to big and 50 too small.
Also, how should I proceed? What would be the best way to get this out?
Thanks in advance for any suggestions.
beyonce's Avatar
beyonce beyonce is offline
My Saabs: '99 93 freebaser '00 95 driveway blocker
You can start by hammering in the 55 (with a replacement on order, of course) and getting it that way.
If that doesn't work, get some vice grips on that sucker nice and tight and try that.
If that doesn't work, you might have to use a chisel on the side of it to shock it off.
Don't give me no Saab story!
fiveiron9688's Avatar
fiveiron9688 fiveiron9688 is offline
My Saabs: '98 900SE vert - GREEN!!
It's a T55, so you may have done some damage. Are you upgrading the bushings?
Scarabe green '98 900SE turbo vert - Stage 3+
My pride and joy...when she's not broken
Tweek's Turbos Tweek's Turbos is offline
My Saabs: 07 9-5 Combi, 99 9-3 Viggen, 85 900 SPG
Sometimes getting the rear stanchion arm off too and flipping the whole thing over and doing it on your terms and not the car's makes it easier too. But yes T55. I have 2 just for this job.
Old 30th September 2011
twblalock twblalock is offline
My Saabs: 1997 900S 2.3
Do you have an impact driver? I got mine for $10 at the auto parts store. It has saved my *** a few times. Try some Liquid Wrench or other penetrating fluid followed by the impact driver. If it still doesn't move you might need to use an extractor or drill it out.
busaboy busaboy is offline
My Saabs: 2000 Viggen 5-door
The impact driver is a required tool when working on motorcycles, especially their engines.
A very useful tool for anything that might have stuck screws and bolts.
bogan's Avatar
bogan bogan is offline
My Saabs: 97 900se Talladega stage 5....b234 RWD
Garage
Somthing like this will grab it. Its a plumbing tool and will grip anything that has an edge to bite on
B.L.T.H.....Brake late Turn hard
Old 2nd October 2011
My Saabs: 1999 93
Default Job done, thanks!
Hi,
Thanks for all the replies.
I thought I would try all your suggestions, starting with Beyonce´s as that didnt require me buying any more tools.
Thankfully, bashing the 55 torx into the hole worked.
I finished the job yesterday, and the new lower control arm is in place. I guess I can practise again some time soon with the other side...
Old 3rd October 2011
Tap804's Avatar
Tap804 Tap804 is offline
My Saabs: 97 3dr
Another modern devlopment from Bogan Perfomance
97 900se 3door
Old 4th October 2011
bogan's Avatar
Garage
Yes, Bogan Performance is at the cutting edge of tool technology
As I say, When you have done your best, Let your hammer do the rest
Tap804's Avatar
My Saabs: 97 3dr
"When in doubt, Find something and hit it, if that doesn't work find something bigger."
-My Dad
97 900se 3door
Old 5th August 2014
LRPharm54 LRPharm54 is offline
My Saabs: 1999 Saab Scania Turbo SE Hatchback
Question 55 Torx Bolt for control arm
I changed out my control arms and ball joints by myself. It wasn't at all that easy. I am disabled and not a mechanic, per se. I did read the articles and threads on the problems some incurred while working on the same basic suspension systems. What I didn't see was an suggestions where these Torx 55 bolts can be purchased.
It is maddening. I looked everywhere to find even one. What is shown are bolts. But you are not able to determine if they are Torx first, 55 second, and if they are even the right length for the control arm. I am certain someone must sell them, but no clues are given where I can get a replacement. I would purchase two if I could. I had to bash the one I had pretty badly to get it out. Once out, I cleaned it and filed it on two sides so a wrench can be used if necessary to remove the darn thing.
Anyone know where I can get a replacement T-55 torx bolt for a 1999 Saab 9-3 SE Hatchback would be greatly appreciated. I got the control arms, ball joints and sway bar end link kit in and the car is handling beautifully again.
Thanks. I hope to get a reply soon, but I don't really need the bolts yet, but if the price is right and I find them great. I tried Eeuroparts first, but no description that will satisfy me and I may call them. Again thanks everyone.
Old 5th August 2014
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is online now
Saabista
My Saabs: Black on black '97 Saab 3-door SE Turbo
Everything suspension-wise should be here. I suspect that it's the 7984933 part that you need... Ron
http://www.eeuroparts.com/Cars/SAAB/...tsuspension/1/
Old 5th August 2014
hapcj7 hapcj7 is offline
My Saabs: 1997 900 set Vert..JZW Stage 3+
Its very hard at times to pick out the correct part on Eeuro...
I wonder why they got rid of the diagrams??
Old 5th August 2014
BobSaabit's Avatar
BobSaabit BobSaabit is offline
Saabista
My Saabs: '97 NG900 'vert; '03 OG 9³ 'vert
I've talked with them a couple times about that over the last couple years. Some good reasons, some poor excuses, there were places some of them showed up, but still not like the old days. They recently redid the site again (in the last week) and the diagrams seem to be completely gone now. I don't think they realized how useful they are in finding parts and how important that is to their sales.
If you can find a copy of the EPC on the 'net, that's the way to go now.
Old 5th August 2014
jakejm79's Avatar
jakejm79 jakejm79 is offline
Saabista
My Saabs: 1999 9-3 Convertible
Jim Ellis Saab has the same diagrams, tho they only match up to part numbers, eEuro would list the items by diagram numbers too.
Old 5th August 2014
BobSaabit's Avatar
Saabista
FWIW, I found out that eeuro was not able to get rights to Saab diagrams. They had to have an artist recreate them by hand.
Still, they had most of them done for our cars... and they really made it easy to order.
Old 5th August 2014
EdT EdT is offline
My Saabs: 1997 900S Coupé, 2003 9-5 Linear Combi
They looked like the diagrams the parts computers at Saab dealers showed. So I can see the rights/copyright issues. Too bad; not only were the diagrams helpful, they probably helped sell extra parts. "Oh, I need #3, but #4 and #5 probably should be replaced while I'm in there."
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Stripped Torx screw gtswimmer101 9-5 Workshop 9 18th October 2012 11:29 AM
By-Pass Hose Torx screw? Willards9 NG900 & OG9-3 Workshop 7 19th August 2010 11:44 AM
By-Pass Hose Torx screw? Willards9 NG900 & OG9-3 Workshop 1 19th August 2010 10:34 AM
Torx screw problem 99S9-5BV6 9-5 Workshop 12 24th February 2009 05:50 PM
Tamper Proof Torx Screw on MAF Sensor 9-3Lee NG900 & OG9-3 Workshop 6 6th August 2008 10:00 AM
