Coolant leaking - SaabCentral Forums
Old 21-09-11
DJamesUofM DJamesUofM is offline
My Saabs: 2002 9-5 Aero
Default Coolant leaking
So this started after I had my valve covers replaced and had one of the A/C vacuum hoses replaced. At first I would probably have to fill up with 50/50 every week and a half or so. Yesterday I filled it up again mostly with water, then today after driving from school and back, and to the gym, the message for me to fill my coolant was displayed. I don't notice any leaking from the car after it has been off for a while, but I know it leaks when the car is running. There is no real noticeable burning smell that comes from my car and for it to be leaking that much doesn't seem to make sense that I would have something wrong with my head gasket. But who knows cars can be stupid.
Any ideas?
Old 22-09-11
first-saab first-saab is offline
My Saabs: Saab 9-5 V6 (1999) 180K+ miles
Do you have a 4 cyl or V6?
Old 22-09-11
vividly's Avatar
vividly vividly is offline
My Saabs: 2000 9-5 SE (Sold), 2009 Ford Focus SEL
Do you have what can be described as "milkshake" underneath your oil or coolant caps? Are you visibly losing coolant (sensor can get stuck due to sediment - hit the side of the reservoir or flush the reservoir to see if it helps)? Do you have any leaks underneath the car? Location helps narrow this down as well. Passenger side might be water pump. Driver's side might be a bypass valve.
Old 22-09-11
It's a 4 cyl...and it leaks on the passenger side. i don't see any of that under the coolant cap but i will check underneath the oil cap when i go back to my car today. And yes if I check my coolant before I go somewhere and then when I get back to the house and check my coolant again I can visibly see that I have lost coolant.
Old 23-09-11
I had a leak on the passenger side which turned out to be the radiator. These things have a weakness in cracking on the end caps, normally on the passenger side and coolant runs down the side of the radiator.
Old 23-09-11
MI-Roger MI-Roger is offline
My Saabs: 2008 9-5 Aero Sedan, 2006 9-3SC 2.0T
Default Coolant By-Pass Valve???
These are notorious for leaking without warning. You can either:
  1. Replace the valve (see write-up by Mickel in the FAQ section of this site), or
  2. Completely eliminate the valve by installling the "non-ACC" or MacKay heater hose kit as I did.
2008 9-5 Aero Sedan
2006 9-3SC 2.0T
2000 9-5 lpt Sedan, Retired at 318,000 miles
Old 24-09-11
MI-Roger...you should post links to both of those for me. Can't seem to find them.
Old 24-09-11
Heater By-Pass Valve / Coolant By-Pass Valve Replacement:
http://www.saabcentral.com/forums/sh...239#post985239
MacKay Hose Kit:
  1. Use the above set of instructions for removal of the old valve
  2. Remove the three hoses connected to the old valve
  3. Remove vacuum hose connection from the Tee close to the intake manifold to the solenoid valve strapped to the CBV. Replace Tee with straight barbed connector.
  4. Keep solenoid electrically connected to car. Do not remove/discard the solenoid.
  5. Install new hose kit. P/N #54-63-252
  6. Use tie-wraps to secure old solenoid in an out of the way location in the engine bay, mine is tied to the wiring harness cover behind the throttle body.
  7. Button things back up
  8. Job complete
2008 9-5 Aero Sedan
2006 9-3SC 2.0T
Similar Threads
coolant leaking!!! whitefang_7 Saab 9000 Workshop 6 16-02-11 08:03 PM
Leaking Coolant Lola Saab 9-3 & NG900 Workshop 3 03-06-06 12:36 PM
Leaking Coolant littco Saab 9-3 & NG900 Workshop 6 12-12-05 02:03 PM
Coolant leaking moog Saab 9-3 & NG900 Workshop 3 28-09-05 08:48 AM
Leaking coolant PMR Saab 9-3 & NG900 Workshop 6 03-05-05 07:55 PM
