Aftermarket Stereo Install - SaabCentral Forums
Old 20th September 2011
monkey_matt monkey_matt is offline
New Member
My Saabs: 2008 9-3 Saloon
Default Aftermarket Stereo Install
Quick search on google shows that this has been talked about alot, however, I couldn't find the answer to this question, so forgive me if its been covered time and time again.
Its on a mates car (9-3 Vector i believe, although my parents also have a 9-3 Aero TTID, so may be asking more questions if they have any), and is looking at installing the headunit he had in his Mini (Rover not BMW) and after getting the single DIN convertor, the cubby hole, he went to get the ISO cable. The description said for a non-amplified system, and as far as he could tell he couldn't find an Amp. However after connecting everything up, the unit wouldn't power on, and he says that the pins appear different (from what i could tell, I think he means that for example there is a wire on the male side which has no corresponding wire on the female side)
Any help on this?
Cheers
aerojon's Avatar
aerojon aerojon is offline
Welcome to SC..
what year is his car?
Is still running factory oe coils with Hirsch tune..
New Member
Sorry thought I had put it, his is 2008
stevedol's Avatar
stevedol stevedol is offline
My Saabs: MY08 9-3 Aero 2.0T Convertible
even with a wiring harness, he will still need to find an ignition controlled source of power to connect to the aftermarket headunit. None of the available Saab-ISO harness' will supply this as the Saab headunit doesn't use an igniton controlled power source to begin with.
The best place to get an ignition controlled source is the telephone connector usually sited behind the centre console on the passenger side.
See my thread Kenwood DNX5220 multimedia satnav for more info and pictures. There are also plenty of other threads on aftermarket installs in post 2007 cars too, if you can't find what you need in my thread.
2000 93 SE convertible - bought 2003 - traded in 2004 for
2003 93SS Aero - bought 2004 - traded in 2007 for
- bought 2007 - Hirsched, stage1 175BHP, pedals & dual exhaust,
- traded in 2010 for,
- bought 2010 2.5yrs old
Saabless's Avatar
Saabless Saabless is offline
My Saabs: Saabless
Yes Totally agree with using the bluetooth module...Also beware of the CANBUS module that comes with the harness. They are prone to fail and cause intermittent power probs thus I used Stevedol's method and it works like a charm...only car has to be on "On" to turn on stereo which in my case means having the headlights on...I am worknig on trying to find a dealer or indy to turn off my DRL's.
Old 21st September 2011
New Member
cheers, will give it go, will let ya know how it goes, lol
loochy's Avatar
loochy loochy is offline
My Saabs: 2007 9-3 2.0T, BSR Stage 3, Polar White
Garage
Are you sure about that? I just hooked up the connector and it worked...
stevedol's Avatar
None of the harness' I've seen provide an ignition switched source, with the exception of some of those that also contain a steering wheel controls interface.
Saabless's Avatar
My Saabs: Saabless
Mine had a switch on the CANBUS but it was the cause of problems of intermittent power on issues so I ditched the CANBUS and SWC (SWC didnt work anyway with my model stereo) in favor of having my stereo turn on when i want it to
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
New member, recent '05 9-5 Arc purchase, and aftermarket stereo install. Nagamitsu 9-5 Workshop 10 2nd August 2011 09:18 PM
Aftermarket Stereo install SaabNineThree 9-5 Workshop 0 22nd September 2010 02:49 AM
looking for aftermarket stereo sa1t C900 Workshop 1 3rd May 2008 04:09 AM
Aftermarket Stereo Q's huntw03 9-5 Performance, Mods & Tuning 8 21st March 2007 08:11 PM
1996 900S Stereo replacable with aftermarket stereo? Typoboy NG900 & OG9-3 Workshop 2 11th August 2002 09:47 PM
