input speed sensor fixes? - SaabCentral Forums
Old 7th September 2011
gryffingirl gryffingirl is offline
My Saabs: Silver '04 Saab 9-3t
Default input speed sensor fixes?
So i couldnt come up with a good title lol. But anyway, I have a 2004 9-3 linear. I had my input speed sensor replaced in june of this year, and about a week later the radiator replaced along with that stupid faulty o-ring. Well, it's now september and my damn input speed sensor is out AGAIN!! The car just turned over 100k miles and i doubt its had the tranny fluid changed before, so it needs it done anyway. But when we (us saab owners) replace these speed sensors (typically due to faulty o-rings in the radiator) should we just drain and replace what tranny fluid comes out or do a flush? For those of you that don't know, these sensors generally go out due to water/coolant seeping into the transmission. My thought is that if i just drain the fluid, there will still be oil/possibly coolant in the valve bodies or in the tq converter area, am i thinking right? Thanks for any input.
Bump!!
Old 8th September 2011
Old 13th September 2011
Thanks for all the replies.
not!!!!!!!!!!
Old 17th May 2012
JNRFLEXN JNRFLEXN is offline
My Saabs: 2004 Saab 9-3 Linear
Thumbs up
Hey good for you being on top of this, I have the same car with the same issues. I suggest you just drain the fluid that comes out and put in the new one, then two weeks later replace it again, repeat the process in 2 week intervals 3-4 times until the last fluid that comes out is clean.
I'm replacing my Input/Output sensors this weekend to see if I can get rid of the "Gearbox Malfunction SID" with code P0773.
If you do get back to this forum, I would like to know how your Saab is doing in regards to the coolant/trans fluid mix and any other codes.
Thanks!
Old 17th May 2012
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
When the fluid gets contaminated, there is a gelatinous build up inside the trans that draining will not remove.... described as a pinkish vasiline type substance...
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Abs light, NO L rear speed input dzlsabe 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 0 17th February 2010 08:30 PM
2003 9-3 Input Speed Sensors brooksjs 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 0 1st February 2010 02:55 PM
VSS (Speed Sensor) Input location for installation of nav - 06 9-5 SportCombi tuttiface 9-5 Workshop 0 8th July 2009 06:45 PM
Input Turbine Speed Sensor jony51999 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 15th March 2007 02:44 PM
Taping the Speed Sensor for aftermarket Digital Speed Display DevilMan 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 8 10th June 2006 12:42 PM
